On Wed, 14 Oct 1998 20:39:38 -0700, Pcoldspr
<KMa### [at] coldsprings reno nv us> wrote:
>Is there anyway to move a checkered floor so the squares at the bottom
>are slightly off center?
I think what you're looking for is the 'translate' keyword. If you put
it inside your texture block, you'll move just the texture by the amount
specified. So, if you put 'translate <.2,0,0>' it'll shift the floor .2
units to the right (assuming you're using the camera position POV
defaults to when you choose 'camera' from the insert menu)
A little time reading and following along with the tutorial in the manual
would probably help you immensely. This and lots of other beginner topics
are covered in exquisite detail.
