POV-Ray : Newsgroups : povray.newusers : Torii Trouble Server Time
23 Mar 2026 08:54:29 EDT (-0400)
  Torii Trouble (Message 1 to 4 of 4)
Subject: Torii Trouble
Date: 15 Aug 1998 12:34:32
Message: <35D5AB3A.DFEA3C10@airmail.net>
I'm a fairly new user who just can't seem to get this.  Here's the
scenario.  I've got three torii in a row (the other shapes in the image
aren't important:  I didn't use unions or differences or anything
fancy).  I want to make the torii glow blue.  I tried placing all kinds
of halos in them (glowing, attenuating, etc.).  I made sure that the
torii were hollow. (Am I supposed to remove the PIGMENT keyword from the
torii?)  Is it possible to place a halo into a torus, or am I a nitwit
and didn't read the docs correctly?  Well, thanks in advance.
Melissa Mathis
gle### [at] airmailnet
Subject: Re: Torii Trouble
Date: 17 Aug 1998 13:01:38
Message: <35d853e2.0@news.povray.org>
Glenn Mathis wrote in message <35D5AB3A.DFEA3C10@airmail.net>...
It should be. There was an image in the IRTC once of a fusion reactor (or
something like that), which used a halo in a torus, if I am correct. It was
somewhere in the winning ranges, so it shouldn't be too hard to find:
http://www.irtc.org
Look for the "Great engineering achievements" round. If you are lucky, it
comes with sourcecode :-)
Now a wild guess:
You say, "the other objects are not important..."
Now: Is by any chance one of these objects a plane? because planes have an
"inside" too: Everything on one side of the plane is defined as being
"outside", everything on the other side is defined as being "inside". And
since a plane has an "inside" too, it too needs to be made hollow, or it
will kill every halo that is on its wrong side (the "inside"-side).
Hope it helps,
Johannes.
Date: 18 Aug 1998 00:45:43
Message: <35D8F8E4.236E192A@flash.net>
The magic number here is 3....
When light passes through at least 5 surfaces, by default
transparency becomes disabled.  Make sure
global_settings { max_trace_level 12 }
(or whatever -- something at least as big as the maximum
number of transparent surfaces you will have along a line
of site)
Dan
http://www.flash.net/~djconnel/
Date: 18 Aug 1998 17:36:09
Message: <35D9F40F.88D3A91B@spiritone.com>
What type of halo are you using? My best advise is to create the object
aroudn the origin, make sure that the transmit and/or filter values in the
pigment are high, make sure it's hollow, and then translate the final shape
to the desireed location.
Also, make sure you're rending at +q8.
Josh English
eng### [at] spiritonecom
www.spiritone.com/~english
> Melissa Mathis
