POV-Ray : Newsgroups : povray.newusers : .jpg => POV??? Server Time
12 Apr 2026 04:55:15 EDT (-0400)
  .jpg => POV??? (Message 1 to 5 of 5)
Subject: .jpg => POV???
Date: 10 May 1998 18:46:05
Message: <35562E2D.8AA221F7@worldnet.att.net>
I know it's a long shot but...
Does anyone know of a way to take a normal JPG, possibly scanned in
using a 30-bit scanner, and "reverse engineer" it into a set of objects
readable by POV or Moray?  I just ordered Photoshop and Illustrator..
would Photoshop do something like this?
-mike
Subject: Re: .jpg => POV???
Date: 30 May 1998 15:42:43
Message: <6ksehn$1ul$3@oz.aussie.org>
Nope.
This is along the lines of those "Computer Enhancements" shown on TV shows
that magically make someone's face appear out of a muddy, blurred photo...
-aardvarko
Ken Penner wrote in message <35562E2D.8AA221F7@worldnet.att.net>...
Date: 31 May 1998 20:40:31
Message: <3571F87E.90D12EB6@ssvec.org>
Just a wild notion that occuredto me, but maybe you could use something
along the lines of OCR to do it.  I've never heard of a program that would
do this, but if you could make one that was capable of analyzing the shapes
in a pic.  (like the find edges function in paint programs) maybe you
could.
    But, to answer your  question, I'm pretty sure that right now there are
no such programs on the market..
KillFile
> -mike
Date: 1 Jun 1998 11:17:19
Message: <6kuglv$41u$3@oz.aussie.org>
Ken Penner <kpe### [at] worldnetattnet> wrote:
: Does anyone know of a way to take a normal JPG, possibly scanned in
: using a 30-bit scanner, and "reverse engineer" it into a set of objects
: readable by POV or Moray?  I just ordered Photoshop and Illustrator..
: would Photoshop do something like this?
  That's completely impossible.
  When you project from 3D to 2D, you loose information.
  - There is information in the 3D space which ends up hidden in the 2D
    projection, and you have no way to get that information back, apart
    from guessing (artifficial intelligence?) (and even human guessing is
    far from perfect).
  - The projection is not unambiguous: Completely different 3D-objects may
    produce identical 2D-projections. You have no way to tell which one of
    those objects was the original 3D-object.
  - The projection is not unambiguous even if you have several projections
    of the same 3D-object (at least not always). Of course several projections
    make guessing easier.
  - You don't even have depth information. There may be two pixels in the image
    with identical colors, but one of them may be extremely near to the camera
    and the other at 1 billion kilometers. You have no way to know that (apart
    from guessing).
                                                              - Warp. -
Date: 3 Jun 1998 06:59:59
Message: <6l3abf$a65$1@oz.aussie.org>
In article <6kuglv$41u$3@oz.aussie.org>,
	Nieminen Mika <war### [at] assaricctutfi> writes:
Eh, I wouldn't quite agree with you on that... under cirtain circumstances
of course.
From just a single JPG, no. That is for the guys in Mission Impossible to
play with. 3D requires *LOTS* more information then 2D. In theory,
infintally more. In reality, it depends on your resolution. If you
have a 1000x1000 picture and want about the same resolution in 3D, you
need 1000 times as much data. You simply can't magically extract that much
info from a single picture unless there are very special circumstances.
In the movies however, anything is possible.
From two photos however you might do it. The computer can, just like the
human brain, extract depth information if it has two pics to work with.
I accorance what I said in the previous paragraph, this method will not
give you 1000 times as much info, it will just detect the surfaces for you.
/Michael
