POV-Ray : Newsgroups : povray.newusers : very frustrated!! Server Time
25 Dec 2025 19:17:42 EST (-0500)
  very frustrated!! (Message 1 to 5 of 5)
Subject: very frustrated!!
Date: 4 May 1998 15:54:44
Message: <354E1D04.63CDD43C@msn.com>
How/where do I use switches for wondows 95?
I want to have files saved as.png.  But I have read and re-read and
cried and tried.
I need to be led by the hand on this one.
Subject: Re: very frustrated!!
Date: 4 May 1998 21:39:34
Message: <01bd77c6$e0ab6200$4e7a89d0@reboot>
I wasn't aware that POV-Ray could output a PNG file.  The easiest way would
be to download Paint Shop Pro and use it to convert TGA's to PNG's.
-Gary.
k <21e### [at] msncom> wrote in article <354E1D04.63CDD43C@msn.com>...
> cried and tried.
Date: 4 May 1998 18:00:08
Message: <354E3A68.452D38EB@msn.com>
ok.  But still...what about TGA's.  I cant even get it to do that.  Will only
save as POV, INC, TXT or ALL.
> -Gary.
> > cried and tried.
Date: 5 May 1998 00:54:17
Message: <6im2pb$64n$1@oz.aussie.org>
k <21e### [at] msncom> wrote in message <354E3A68.452D38EB@msn.com>...
only
heh...
whenever it renders, it outputs a .TGA file by default.
Look in the directory that contains your scene files.
HOWEVER, you CAN force it to output a .PNG format, by using the command-line
switch +FN
Alternatively, you can put this in your povray.ini:
Output_File_Type=N
This will force the .PNG output.
You can also put
Output_File_Name=C:\images\
to force it to output it to C:\images
Twyst================================
EFnet and NewNet #povray Channel Operator
Website: http://www.geocities.com/~twystedmynd
E-Mail: twy### [at] v-wavecom
Date: 5 May 1998 20:38:36
Message: <354FB10B.F626AFC@ou.edu>
The command line switches are stored in the "Render -> Edit Settings/Render"
menu.  Or you can get to it by alt+c.  OR, you can get to it by pressing the
first render button (has a picture of a menu, camera, and an arrow going down to
a scene.)
---Mike---
> only
> heh...
> switch +FN
> Output_File_Type=N
> You can also put
