POV-Ray : Newsgroups : povray.newusers : Atmosphere and BLACK window Server Time
14 Jul 2026 04:14:12 EDT (-0400)
  Atmosphere and BLACK window (Message 1 to 4 of 4)
Subject: Atmosphere and BLACK window
Date: 16 Apr 1998 13:10:33
Message: <35363B88.BE9A12D7@pacbell.net>
(Still) going through the tutorial...
The scene is in a room with a window with sunlight and
blue sky showing through. I am learning to use the
"atmosphere" keyword.
Notice the blue sky through the window with "atmosphere"
code commented out.  But the window turns BLACK with the
"atmosphere" code in.
Neither "background" nor "sky_sphere" show through
the atmosphere, regardless of the values of "distance"
and "scattering".  You can have a very thin atmosphere
with almost no scattering. Still, "background" and
"sky_sphere" colors are blocked.
Would someone please save me a lot of work and tell me
how to stop the window from being black when I add the
atmosphere?
The doc. indicates that you should see the background
through the atmosphere.  In section 7.7.1, it says:
  The light passing through the atmosphere (either coming
  from light sources or the background) is filtered by the
  atmosphere's color if the specified color has a non-zero
  filter value.
    location <-10, 8, -19>   look_at <0, 5, 0>    angle 75
light_source { <-.3, 19, .3> color rgb 0.5 atmosphere off }
// background { color rgb <0.2, 0.4, 0.8> }
sky_sphere{ pigment {color rgb <0.2, 0.4, 0.8> } }
  light_source {
    <40, 25, 0> color rgb <1, 1, .8>
    spotlight
    point_at <0, 5, 0>
    radius 20
    falloff 20
    atmospheric_attenuation on
 union {
    difference {
      box { <-21, -1, -21>, <21, 21, 21> }
      box { <-20, 0, -20>, <20, 20, 20> }
      box { <19.9, 5, -3>, <21.1, 15, 3> }
    box { <20, 5, -0.25>, <21, 15, 0.25> }
    box { <20, 9.775, -3>, <21, 10.25, 3> }
    pigment { color red 1 green 1 blue 1 }
    finish { ambient 0.2 diffuse 0.5 }
// Comment the atmosphere out to see the blue sky thru the window
   atmosphere {
    type 1
    samples 5 // very low value to speed rendering for test
    distance 80
    scattering 0.01
// x-y-z axes
cylinder { -100*x, 100*x, .03  pigment {Gold} finish {ambient .8}}
cylinder { -100*z, 100*z, .03  pigment {Gold} finish {ambient .8}}
cylinder { -100*y, 100*y, .03  pigment {Gold} finish {ambient .8}}
Alan
Subject: Re: Atmosphere and BLACK window
Date: 17 Apr 1998 05:40:24
Message: <6h784h$5ta$1@oz.aussie.org>
I am not sure, but I guess this is the reason:
The sky sphere has an infinite distance from the origin. So no matter how
thin the atmosphere is, over this inifinite distance it still accumulates to
block all light.
Try using a real (hollow) sphere instead of the sky sphere. Make it very
large and center it around the origin, so that it contains your scene. Use
your sky texture for it. Then you can vary it's radius until it shines
through the atmosphere just the way you want it.
Johannes.
Date: 17 Apr 1998 06:49:06
Message: <6h7c32$60a$1@oz.aussie.org>
Johannes Hubert (jhu### [at] algonetse) wrote:
: Try using a real (hollow) sphere instead of the sky sphere. Make it very
: large and center it around the origin, so that it contains your scene. Use
: your sky texture for it. Then you can vary it's radius until it shines
: through the atmosphere just the way you want it.
  Another thing to try is to put a totally transparent hollow room-sized
box with a dust halo inside it, into the room. AFAIK dust halo works like
atmosphere. This way you limit the dust into the room (and this is often
the real world analogue situation).
                                                              - Warp. -
Date: 22 Apr 1998 07:19:39
Message: <353DD24B.909FC99D@aol.com>
Here's a simple rewrite that fixes the problem.  Just look for the ***:
  light_source {
    spotlight
    point_at <0, 5, 0>
    radius 20
    falloff 20
 union {
    difference {
   atmosphere {
    type 1
    color rgbt <1, 1, 1, .8> /*** adding some tranparency will keep the
background from being washed out*/
    distance 80
    scattering 0.01
// x-y-z axes
