POV-Ray : Newsgroups : povray.newusers : Lights Server Time
18 Sep 2025 20:26:32 EDT (-0400)
  Lights (Message 1 to 2 of 2)
Subject: Lights
Date: 5 Feb 1998 11:07:30
Message: <34D9E3C1.1E98DCF@midgard.liu.se>
If i have get it right, the lights in a scene "fades" the more far the
light is from the light-source, right?
Pretend i make a cylindrical light, how do i make it so the light is
constant all over the scene, from that light?
// Rikard Bosnjakovic - http://hem2.passagen.se/rikbo - ICQ: 1158217
Subject: Re: Lights
Date: 5 Feb 1998 13:44:58
Message: <34DA089F.162BA229@dhol.com>
Real world light fades, POV-Ray lights do not fade with distance unless
you tell them to.  If you do not use the "fade_distance", "fade_power"
or "atmospheric_attenuation" keywords in your light definition, they
will not fade with distance.  If you *want* fading, use them as needed.
As I said, the light will not fade with distance unless you tell it to.
If you want the edges of the cylinder (or cone for a spotlight) not to
fade, in your light definition make "falloff" equal to "radius" and set
"tightness" to 0.  Your cylinder (or cone) will then have sharp edges.
Good luck.
Jerry Anning
cle### [at] dholcom
