POV-Ray : Newsgroups : povray.newusers : function on cylindrical surface Server Time
20 Dec 2025 06:16:27 EST (-0500)
  function on cylindrical surface (Message 1 to 2 of 2)
Subject: function on cylindrical surface
Date: 19 Sep 2006 20:53:58
Message: <20060920025334.34d641c4.not@available.yet>
hello,
in a new image i want to render rust on a cylindrical surface. approach until now:
rust should be a function with a pattern, pattern should be an height_field or a
normal and this should be used with a cylinder.
my readings were Chris Hormann's water tutorial and some other web-material. but the
results are bad: i even do not get a height field. using normals Povray says a numeric
expression is missing.
i thought about isisurfaces, but they are too slow.
can anybody tell me if my approach is wrong way or if i made other programming
mistakes.
more information follows if wished (tell me what, please).
best regards
the construction until now is:
#declare fn_rostbeule =
function{ pattern {
bozo turbulence 0.65
                        octaves 6  omega 0.7 lambda 2
                        rotate<10,20,0>
                        scale <0.3, 0.4, 0.2>*30
}}//pattern,function
#declare fn_rostbeule_hf =
function {
	y-fn_rostbeule(x,0,z)*0.5
object{ [..]
texture{
      pigment { [..]
}} //pigment, texture
texture{
      pigment { [..]
	normal {
		bump_map{
		function {
			fn_rostbeule_hf(x,y,z)*10
		scale 10
	translate y*3
	rotate y*-75
Subject: Re: function on cylindrical surface
Date: 20 Sep 2006 00:48:52
Message: <eLaU9DAEfMEFFwts@econym.demon.co.uk>
Wasn't it marabou who wrote:
>hello,
>now: rust should be a function with a pattern, pattern should be an height_field
>or a normal and this should be used with a cylinder.
If you want to use a normal, there's no reason to wrap the normal
function around the cylinder. Just apply the normal to the cylinder
unwrapped.
cylinder {p1,p2,r
  texture {Whatever}
  normal {bozo turbulence 0.65
    rotate<10,20,0>
    scale <0.3, 0.4, 0.2> * 30
Mike Williams
Gentleman of Leisure
