POV-Ray : Newsgroups : povray.newusers : Problem with variables Server Time
21 Mar 2026 21:24:05 EDT (-0400)
  Problem with variables (Message 1 to 6 of 6)
Subject: Problem with variables
Date: 27 Oct 2002 07:11:43
Message: <1fkpnlf.dx0416mokegiN%kaveh@delete_this.focalimage.com>
Sorry if the subject to this posting is vague. I am not sure of the
technical term for what I am trying to do. Consider the following simple
file:
#declare Pigment = pigment{color rgb <1,1,1>}
#declare Ambient = 0;
#declare Diffuse = .2;
#declare Specular = .8;
sphere {
  0, 1
  pigment {Pigment}
  finish {
        ambient     Ambient
        diffuse     Diffuse
        specular    Specular
In order to get a better idea of the effect of each of this attributes,
I want to have a loop that produces a range of values of a selected
attribute. There is one place I am stuck in. I want to say something
like:
#declare variable = "Ambient";
at the beginning of the file, and the program would then use all the
other values given, but vary the value of Ambient, say 5 times, and draw
the 5 resulting spheres.
The only way I have come up with so far is rather ugly. I would use:
#if (strcmp(variable, "Ambient") = 0)
But it is verbose, and also if I introduce a new variable, I have to
have a new conditional.  I really want variable to 'think' it is Ambient
from that point on.
Grateful for any hints.
Kaveh
Subject: Re: Problem with variables
Date: 27 Oct 2002 08:04:24
Message: <3dbbe458@news.povray.org>
You could use an integer to represent the value you want to vary, like this:
#declare VaryAmbient = 1;
#declare VaryDiffuse = 2;
#declare VarySpecular = 3;
#declare WhichValueToVary = VaryAmbient;
#declare Variable = ... // Vary this
finish {
  ambient (WhichValueToVary == VaryAmbient) ? Variable : 0.1;
  diffuse (WhichValueToVary == VaryDiffuse) ? Variable : 0.6;
  specular (WhichValueToVary == VarySpecular) ? Variable : 1.0;
Date: 27 Oct 2002 08:28:25
Message: <1fkprmu.h5llq52t5zpbN%kaveh@delete_this.focalimage.com>
> finish {
Thanks Johannes. I haven't come across this construction, and can't find
it in the manual. Can you give me a hint as to where I can find more
information on this?
Kaveh
Date: 27 Oct 2002 08:55:18
Message: <3dbbf045@news.povray.org>
You mean the ? : ternary operator? Basically, it works like a simple
if/else construct:
 #if(<expression>) <do_this> #else <do_that> #end
is the same as:
 (<expression>) ? <do_this> : <do_that>
That is, if <expression> returns true, it executes the <do_this> part,
otherwise the <do_that> part.
In the POV manual:
6.1.3.3 Float Operators
http://www.povray.org/documentation/view/137/
Date: 27 Oct 2002 09:55:23
Message: <1fkpvur.194ifw61yxczkeN%kaveh@delete_this.focalimage.com>
> if/else construct:
> is the same as:
> In the POV manual:
Got it. Except you had == which according to the manual should be =. I
did a search for == but couldn't find it. I would have guessed == too!
Kaveh
Date: 27 Oct 2002 10:06:54
Message: <3dbc010e@news.povray.org>
Oops, sorry... Too much C++ lately, I guess :)
