POV-Ray : Newsgroups : povray.newusers : Transparent background Problem Server Time
22 Mar 2026 04:20:57 EDT (-0400)
  Transparent background Problem (Message 1 to 2 of 2)
Subject: Transparent background Problem
Date: 16 May 2002 23:22:19
Message: <1103_1021605600@news.povray.org>
Tools used: Povray 3.5RC4
Moray 3.3a
Problem:
When I render my scene with a Galaxy Plugin object in the background (and nothing
else), The background of my image is rendered as mostly transparent. I want the Black
to show up so that the stars etc.
can be easily seen. Is there any way to turn this feature off? I have tried starting
pov with the -UA switch to no avail. I'm just about ready to pull my hair out!!!! Any
help appreciated.
Subject: Re: Transparent background Problem
Date: 16 May 2002 23:33:49
Message: <3ce47a1d@news.povray.org>
> Moray 3.3a
> Problem:
nothing else), The background of my image is rendered as mostly transparent.
I want the Black to show up so that the stars etc.
tried starting pov with the -UA switch to no avail. I'm just about ready to
pull my hair out!!!! Any help appreciated.
The galaxy backgrounds (stars and nebulae) are created using the sky_sphere,
which will be transparent if you render with the alpha channel enabled.
However, if you are using the -UA switch this should not be a problem.  If
you are finding the stars are very faint and transparent-looking, try
rendering without anti-aliasing (or a higher threshold value).
