POV-Ray : Newsgroups : povray.newusers : #declaring a #declare Server Time
23 Dec 2025 15:18:56 EST (-0500)
  #declaring a #declare (Message 1 to 7 of 7)
Subject: #declaring a #declare
Date: 19 Sep 2001 14:46:24
Message: <1000928816@bigfoot.com>
I'm playing with the source to LParser to add a few new formats,
including a couple of pov-ray ones. While creating a example pov file I
came across what I would classify is unexpected behaviour.
In texture.inc Jade is declared as....
#declare Jade =
    marble
    turbulence 1.8
    color_map { Jade_Map }
if in my pov file I use
#declare texture_3  = texture {Jade}
I get a warning
Parsing.........setup.pov:13: warning: Found pigment identifier that should be in
pigment statement.
however if I use
    marble
    turbulence 1.8
I don't get a warning.
So what is going on, is this the expected behaviour, how do I get around
it.
Dave
Posted By NewsBe 1.6.4
http://www.vargol.freeserve.co.uk/newsbe/
Subject: Re: #declaring a #declare
Date: 19 Sep 2001 14:54:28
Message: <3BA8EA11.45445706@helix.nih.gov>
> #declare Jade =
> pigment {
>     marble
>     turbulence 1.8
> I get a warning
pigment statement.
> however if I use
> pigment {
>     marble
>     turbulence 1.8
> it.
> Dave
In the example Jade is a pigment not a texture.
You should be able to use
#declare texture_3 = texture { pigment { Jade } }
Dr. Lothar Esser
NIH / NCI
Tel. 301-435-6163
email les### [at] helixnihgov
Date: 19 Sep 2001 15:01:40
Message: <3ba8eb94@news.povray.org>
i think it should be:
#declare texture_3  = texture {pigment{Jade} }
for pre-3.5 versions
i.e., declared pigments need to be in pigment wrappers (textures in texture
wrappers, etc.)
-tgq
camera{location z*13look_at 0}light_source{15 15looks_like{sphere{0 10
}pigment{rgb 1}finish{ambient 15}}}union{torus{3,0.5rotate x*90}cone{y
*4,.5,-y*8,0}cone{-x*4,.5,x*8,0}pigment{rgb<.7,.6,.4>}finish{ambient 0
diffuse 0reflection{1fresnel on metallic 1}}interior{ior 25}rotate 15}
plane{y,-7pigment{checker rgb 0rgb 1scale 4}finish{diffuse.1}}//   TGQ
Date: 19 Sep 2001 19:15:59
Message: <3ba9272f@news.povray.org>
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3ba8eb94@news.povray.org...
texture
> wrappers, etc.)
Yep, and just to reiterate: keep in mind that the wrapper of each kind of
statement needs to be repeated like that when redeclaring.  object,
material, texture, pigment, normal, finish, interior, media, density and
others.  I'm not sure of the complete list but most anything with braces {},
aside from CSG union, etc., though.  Just happens to be how POV-Ray works
with them.
Probably a good time to point out that layered textures can only be declared
one time through.  If trying to add layers into a previously declared
layered texture there will be a warning and it'll stop parsing.
Bob H.
Date: 19 Sep 2001 22:38:22
Message: <3BA957B5.B6F538DF@pacbel.net>
How did you come by that knowledge, Bob?  :)
Ken Tyler
Date: 19 Sep 2001 23:28:58
Message: <3ba9627a@news.povray.org>
"Ken" <tyl### [at] pacbelnet> wrote in message
news:3BA957B5.B6F538DF@pacbel.net...
declared
Repitition... and lots of it in my case.
Bob H.
Date: 20 Sep 2001 10:44:04
Message: <slrn9qk05m.c0u.ron.parker@fwi.com>
>texture
>> wrappers, etc.)
>with them.
object is a special case.  You have to do this:
#declare Foo = sphere{0,1}
object{Foo}
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
