POV-Ray : Newsgroups : povray.newusers : random elements in blob object Server Time
19 Sep 2025 14:35:52 EDT (-0400)
  random elements in blob object (Message 1 to 10 of 24)
Subject: random elements in blob object
Date: 2 Feb 2002 02:30:37
Message: <01c1abbb$9437bf40$667dd383@etnica>
Hello all,
I am trying to create a blob object with a number of sphere, but I am
trying to place them at random. Now the following problem occurs, all
sphere are placed at the same position. The objection, of course, is to see
all the spheres. My code is as follows:
#declare bubbles = blob
  threshold 0.5
  #declare i = 0;
  #while (i<50)
    #declare S = seed(3415765);
    #declare X = rand(S);
    #declare Y = (rand(S)*2)+0.5;
    #declare Z = rand(S);
    sphere { <X, Y, Z>, 0.4, 0.55
      pigment { color rgb <0.8, 0.3, 0.6> }
    #declare i = i + 1;
Any help would be appreciated,
Koos Jan Niesink
Subject: Re: random elements in blob object
Date: 2 Feb 2002 03:00:32
Message: <Xns91A95BEAD1569seed7@povray.org>
>   threshold 0.5
>   #declare i = 0;
>   #while (i<50)
Mogge,
Take "#declare S = seed(3415765);" out of the while loop and put it above
"#declare bubbles=".
Ingo
Date: 2 Feb 2002 03:22:19
Message: <01c1abc2$cd6f19a0$667dd383@etnica>
Thanks, for the help. It really works!!
I only don't get the reason why the seed declaration has to be placed
outside the while-loop.
greetings/groeten, Koos Jan Niesink
ingo <ing### [at] homenl> schreef in artikel
<Xns### [at] povrayorg>...
> >   threshold 0.5
> >   #declare i = 0;
> >   #while (i<50)
> Mogge,
> Ingo
Date: 2 Feb 2002 03:50:18
Message: <Xns91A9645ADF8A2seed7@povray.org>
Gaaf he.
#declare S= seed(7) intialises a random stream.
#declare Nr1= rand(S) takes the first random number from the stream.
#declare Nr2= rand(S) takes the second.
#declare Nr3= rand(S) the third.
Note that every time you render your scene Nr1 alway gets the same
value. Now if you put #declare S= seed(7) inside a loop, it gets
initialised every time the loop passes it. Thus the value of Nr1 will
always be the same.
Put the seed outside the loop, it is only initialised once. On the first
loop we will get the above result. On the second loop:
#declare Nr1= rand(S) takes the fourth random number from the stream.
#declare Nr2= rand(S) takes the fifth.
#declare Nr3= rand(S) the sixth.
etc.
The order of random numbers for a given seed is always the same.
Ingo
Date: 2 Feb 2002 04:57:46
Message: <3c5bb819@news.povray.org>
koos <fra### [at] hotmailcom> wrote:
: I only don't get the reason why the seed declaration has to be placed
: outside the while-loop.
  If you initialize the random number generator with the same value at
each loop, you'll get the same value from rand().
  A line like:
#declare S = seed(0);
means: "Make S a random number stream with the initial value 0". Successive
rand(S) calls will take values from that seed (and they are always the same
values).
Date: 3 Feb 2002 06:32:17
Message: <3c5d1fc1@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> Gaaf he.
Dutch?
#local X=20*<-2,2,5>;sphere_sweep{catmull_rom_spline 6<-8,-8>1<-8,-8>1<-8,8>1<
8,-8>1<8,8>1<8,8>1translate 20*z pigment{gradient z scale 3color_map{[0rgb<0,9
,18>][1rgb 0]}}}#local K=2*z*X-X;#local R=seed(clock);blob{#while(K.x>X.x)
#local N=X+<rand(R)rand(R)1>/3;#local X=(vlength(N-K)<vlength(X-K)?N:2*X-N);
sphere{X,1,1rotate z*90}sphere{X,1,1}#end pigment{rgbt 1}interior{media{//Nekar
emission<2,4,5>*5}}hollow scale.05}//   http://nekar_xenos.tripod.com/metanoia/
Version: 6.0.317 / Virus Database: 176 - Release Date: 2002/01/21
Date: 3 Feb 2002 06:44:26
Message: <Xns91AA81E131676seed7@povray.org>
in news:3c5d1fc1@news.povray.org Nekar Xenos wrote:
> Dutch?
Ja.
Ingo
Date: 4 Feb 2002 04:36:40
Message: <3c5e5628$1@news.povray.org>
Inderdaad ;-)
thanks for the explanation
In article <Xns### [at] povrayorg>, "ingo" <ing### [at] homenl>
>> Dutch?
> Ja.
> Ingo
Date: 4 Feb 2002 07:37:15
Message: <3c5e807b@news.povray.org>
"Koos Jan Niesink" <koo### [at] hotpopcom> wrote in message
news:3c5e5628$1@news.povray.org...
> Inderdaad ;-)
> >> Dutch?
> > Ja.
> > Ingo
Dit lyk vir my daar is heelwat meer Nederlanders hier as wat ek gedink het. Ek
vermoed hier is dalk ook 'n paar Vlaams sprekendes? Verskoon my spelling - ek is
Afrikaans.
I didn't see any [NE] on the povray.international so I never looked there
again...
Date: 4 Feb 2002 09:29:28
Message: <3c5e9ac8$1@news.povray.org>
"koos" <fra### [at] hotmailcom> wrote in message
news:01c1abbb$9437bf40$667dd383@etnica...
<snip>
Well, you've had answers to your initial problem.
Here's a subtler trap with random streams....
#declare S1 = seed(32534);
#while(1=1)
    #declare S2 = seed(rand(S1))
    object{foo translate y*rand(S2)}
Here, you get some variation for rand(S2), but not a lot. This is because the
seed to S2 is always in the range 0 -> 1, which returns a random stream with
very little variation.
