POV-Ray : Newsgroups : povray.newusers : random elements in blob object Server Time
14 Jun 2026 09:23:35 EDT (-0400)
  random elements in blob object (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: random elements in blob object
Date: 2 Feb 2002 04:57:46
Message: <3c5bb819@news.povray.org>
koos <fra### [at] hotmailcom> wrote:
: I only don't get the reason why the seed declaration has to be placed
: outside the while-loop.
  If you initialize the random number generator with the same value at
each loop, you'll get the same value from rand().
  A line like:
#declare S = seed(0);
means: "Make S a random number stream with the initial value 0". Successive
rand(S) calls will take values from that seed (and they are always the same
values).
Date: 3 Feb 2002 06:32:17
Message: <3c5d1fc1@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> in news:01c1abc2$cd6f19a0$667dd383@etnica koos wrote:
> > Thanks, for the help. It really works!!
> Gaaf he.
Dutch?
#local X=20*<-2,2,5>;sphere_sweep{catmull_rom_spline 6<-8,-8>1<-8,-8>1<-8,8>1<
8,-8>1<8,8>1<8,8>1translate 20*z pigment{gradient z scale 3color_map{[0rgb<0,9
,18>][1rgb 0]}}}#local K=2*z*X-X;#local R=seed(clock);blob{#while(K.x>X.x)
#local N=X+<rand(R)rand(R)1>/3;#local X=(vlength(N-K)<vlength(X-K)?N:2*X-N);
sphere{X,1,1rotate z*90}sphere{X,1,1}#end pigment{rgbt 1}interior{media{//Nekar
emission<2,4,5>*5}}hollow scale.05}//   http://nekar_xenos.tripod.com/metanoia/
Version: 6.0.317 / Virus Database: 176 - Release Date: 2002/01/21
Date: 3 Feb 2002 06:44:26
Message: <Xns91AA81E131676seed7@povray.org>
in news:3c5d1fc1@news.povray.org Nekar Xenos wrote:
> Dutch?
Ja.
Ingo
Date: 4 Feb 2002 04:36:40
Message: <3c5e5628$1@news.povray.org>
Inderdaad ;-)
thanks for the explanation
In article <Xns### [at] povrayorg>, "ingo" <ing### [at] homenl>
>> Dutch?
> Ja.
> Ingo
Date: 4 Feb 2002 07:37:15
Message: <3c5e807b@news.povray.org>
"Koos Jan Niesink" <koo### [at] hotpopcom> wrote in message
news:3c5e5628$1@news.povray.org...
> Inderdaad ;-)
> >> Dutch?
> > Ja.
> > Ingo
Dit lyk vir my daar is heelwat meer Nederlanders hier as wat ek gedink het. Ek
vermoed hier is dalk ook 'n paar Vlaams sprekendes? Verskoon my spelling - ek is
Afrikaans.
I didn't see any [NE] on the povray.international so I never looked there
again...
Date: 4 Feb 2002 09:29:28
Message: <3c5e9ac8$1@news.povray.org>
"koos" <fra### [at] hotmailcom> wrote in message
news:01c1abbb$9437bf40$667dd383@etnica...
<snip>
Well, you've had answers to your initial problem.
Here's a subtler trap with random streams....
#declare S1 = seed(32534);
#while(1=1)
    #declare S2 = seed(rand(S1))
    object{foo translate y*rand(S2)}
Here, you get some variation for rand(S2), but not a lot. This is because the
seed to S2 is always in the range 0 -> 1, which returns a random stream with
very little variation.
Date: 5 Feb 2002 06:03:01
Message: <3C5FBC39.8BF959D6@sw-tech.com>
> #while(1=1)
> #end
Wait.  The way I'm reading this, the smaller the (absolute value of the)
seed is, the less the stream varies.
Please tell me that I'm misunderstanding.
If I'm not, can someone post a brief summary (my C is very bad) of why
(computer, not design decision) this is?
Deaken
Date: 5 Feb 2002 06:23:44
Message: <3c5fc0c0@news.povray.org>
Deaken <dwy### [at] sw-techcom> wrote:
: If I'm not, can someone post a brief summary (my C is very bad) of why
: (computer, not design decision) this is?
  Perhaps seed() takes just the integer part of the given parameter?
(I don't know, I'm just guessing.)
Date: 5 Feb 2002 06:30:58
Message: <3C5FC2C7.DEC8D4C8@sw-tech.com>
The docs for 3.1 say that seed() takes a float.  I can't find the relevant
part in the 3.5 docs.
Deaken
Date: 5 Feb 2002 11:15:22
Message: <chrishuff-54F93A.11165805022002@netplex.aussie.org>
In article <3C5FBC39.8BF959D6@sw-tech.com>, Deaken <dwy### [at] sw-techcom>
No, the less the seed varies, the less the stream varies (from other
streams, not internally). Since only the first random number of each
stream is used, this means there will be some variation, but it won't be
random.
