POV-Ray : Newsgroups : povray.newusers : image_map question Server Time
12 Feb 2026 22:55:11 EST (-0500)
  image_map question (Message 1 to 7 of 7)
Subject: image_map question
Date: 20 Aug 2000 17:07:37
Message: <01c00aea$acf471e0$667dd383@etnica.ibb.uu.nl>
Hello,
How can one e.g. map an image of the earth correctly around a sphere? When
I changed the position of the camera the camera I discovered the rest of
the image wasn't mapped upon the sphere. Instead I found a mirror-like
image.
I hope you can help me with this problem.
thanks, koos
Subject: Re: image_map question
Date: 20 Aug 2000 17:29:59
Message: <39a04dd7$1@news.povray.org>
Make sure you're using the proper map_type (I think map_type 1 for
spherical),
and make sure to include the map_once keyword so it uses one copy of the
map instead of tiling it.  Then you may need to scale it (I thnk it defaults
to a 1 unit
wide square image).  If that fails, there's always UV Mapping.
Doug Eichenberg
http://www.getinfo.net/douge
dou### [at] nlsnet
Date: 20 Aug 2000 19:37:27
Message: <39a06bb7@news.povray.org>
"Doug Eichenberg" <dou### [at] nlsnet> wrote in message
news:39a04dd7$1@news.povray.org...
| spherical),
| image
defaults
| to a 1 unit
| wide square image).
map_type 1 is indeed the thing for spheres.  0 is default and maps to the xy
plane.
No need to use tiling for type 1 though, only for types 0 and 2 (planar and
cylindrical). since only those two can go beyond the 1 unit bounds of their
parent shape.  For cylinders it can extend upward and downward yet still not
wrap around anymore than just the one time as with spheres.
Scaling is another matter, you can scale (and translate) any type and get
mixed results.  But planar (less so cylindrical) is the kind most befitting
scaling and translating and use of the 'once' (sorry Doug :-} no "map_" part
on that one) keyword.
map types 3 and 4 don't exist, btw; type 5 is for toroidal or donut shape.
It will get more obvious as you go along.
Date: 20 Aug 2000 20:52:13
Message: <39a07d3d$1@news.povray.org>
I know you had the docs in front of you for that one Bob... I was going by
memory.
Thanks for the corrections though.
- Doug Eichenberg
  dou### [at] nlsnet
Date: 21 Aug 2000 00:22:41
Message: <39A0AE0C.76A360C4@pacbell.net>
> memory.
That's all simple newbie stuff. Bob and I have answered this question
so many times before that we could answer it in our sleep.
Date: 21 Aug 2000 11:17:53
Message: <39a14821$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:39A0AE0C.76A360C4@pacbell.net...
by
| > memory.
You're right Ken, I didn't even take a look at the Doc for that one, which
always worries me a little if I don't because I can't trust I'll be
perfectly right.  Especially as things are ever-changing.  I'm in the habit
of confusing well known things anyhow.
Date: 21 Aug 2000 18:08:28
Message: <39a1a85c@news.povray.org>
You know you've been raytracing too long when...
Doug Eichenberg
dou### [at] nlsnet
