POV-Ray : Newsgroups : povray.newusers : Tidy way to make a billiard ball w/o image maps? Server Time
24 Dec 2025 22:48:18 EST (-0500)
  Tidy way to make a billiard ball w/o image maps? (Message 1 to 4 of 4)
Subject: Tidy way to make a billiard ball w/o image maps?
Date: 19 Jun 2000 14:40:45
Message: <01bfda1e$a03a1ba0$601ba1d0@mk>
Is there a graceful way to make a billiard ball without an image map?
I've done the image map thing, and it works great, but I was hoping to make
a
.pov file that could stand on its own and doesn't need fifteen accompanying
image files.
Something to do maybe with using text and differencing it with a sphere?
Subject: Re: Tidy way to make a billiard ball w/o image maps?
Date: 19 Jun 2000 17:41:17
Message: <tf4tksccmjh3etgumf01tfrc1tc8028agd@4ax.com>
>a
>image files.
Clip the text with the sphere, then union it with the same sphere.
Peter Popov ICQ : 15002700
Date: 19 Jun 2000 18:39:20
Message: <NYrILDAmBqT5EwFZ@econym.demon.co.uk>
>a
>image files.
If you really are talking about billiards, there are only three balls.
One is plain off-white, one is plain red and the third one has a spot
like this:-
sphere {0,1 pigment { gradient z
        colour_map {[0.000 rgb <1,1,.9>]
                    [0.997 rgb <1,1,.9>]
                    [0.997 rgb 0]
                    [1.000 rgb 0]}
       finish {phong 0.8}
If, however, you're talking about pool balls, you probably want to
investigate the "object pattern" facility in MegaPOV, something like
this:-
// The number "5" on the front side of the ball
#declare One_Five =
object{
  text { ttf "ariblk.ttf", "5", 1, 0
    align_center
    scale <1,1,-2>
    translate -0.35*y
// Two "5"s one for the front and one for the back
// (We can't just push it all the way through or it would
// be back to front on the far side)
#declare Five =
union {object {One_Five rotate y*180}
       object {One_Five}
// The gradient texture for the area outside the "5"s
#declare Yellow_White =
    gradient z
    colour_map {[0.0 rgb <1,1,0>]
                [0.8 rgb <1,1,0>]
                [0.8 rgb <1,1,0.9>]
                [1.0 rgb <1,1,0.9>]}
  finish {phong 0.8}
// The plain black texture for inside the "5"s
#declare Digit =
  pigment {rgb 0}
  finish {phong 0.8}
// The ball with the object texture pattern
sphere {0,1
    object {Five
       texture {Yellow_White},
       texture {Digit}
Mike Williams
Gentleman of Leisure
Date: 24 Jun 2000 03:19:39
Message: <3954610b@news.povray.org>
CreeD <meshe@nqi.net> wrote in message news:01bfda1e$a03a1ba0$601ba1d0@mk...
make
> a
accompanying
> image files.
How about using Intersection? Just make sure the text is deep enough for
intersecting the entire edge with the sphere...
Peter
