POV-Ray : Newsgroups : povray.newusers : seed Server Time
20 Sep 2025 14:08:53 EDT (-0400)
  seed (Message 1 to 6 of 6)
Subject: seed
Date: 23 Feb 2000 17:53:26
Message: <01bf7e50$a4f58320$667dd383@etnica.ibb.uu.nl>
Hello there,
I have a question about random and seed. First one have to declare seed(A).
Will random then return a value between A and A+1? If that is the case I
understood the manual correctly.
thanks, kobus
Subject: Re: seed
Date: 23 Feb 2000 17:57:31
Message: <38B46581.3005AAEB@pacbell.net>
kobus wrote:
> Hello there,
> thanks, kobus
Rand will always return a value from 0 to 1. The seed number will determine
where between 0 and 1 the value starts.
Subject: Re: seed
Date: 23 Feb 2000 18:04:16
Message: <chrishuff_99-35DFA2.18053823022000@news.povray.org>
In article <01bf7e50$a4f58320$667dd383@etnica.ibb.uu.nl>, "kobus"
<kob### [at] hotmailcom> wrote:
> Hello there,
> seed(A).
The rand() function always returns a value between 0 and 1. Specifying a
different seed will just give a different sequence of random numbers.
Most computer random number generators are actually pseudo-random. They
produce a specific sequence of numbers from each seed value. If you use
seed(444), you will get a different sequence from what you would get if
you used seed(999), and that sequence will always be the same.
Chris Huff
e-mail: chr### [at] yahoocom
Subject: Re: seed
Date: 24 Feb 2000 07:46:38
Message: <38B52852.548D6481@via.ecp.fr>
Chris Huff wrote:
> If you use, seed(444), you will get a different sequence from
> what you would get if you used seed(999), and that sequence
Yes, and thus your image will always render the same.
As for the initial question, do the following :
 s = seed(1234) ;
 [...] A+random(s) [...]
This way you will get a number between A and A+1.
And if the result is not satisfying, just change 1234 into something
else.
JM
Subject: Re: seed
Date: 24 Feb 2000 08:08:06
Message: <chrishuff_99-3AA9E6.08093024022000@news.povray.org>
In article <38B52852.548D6481@via.ecp.fr>, Jean-Michel Grimaldi
>  s = seed(1234) ;
> else.
Not "random()", "rand()". But this gives me an idea...
#macro random(Sd, Mn, Mx)
   (rand(Sd)*(Mx-Mn) + Mn)
Now, this should let you use "random(stream, min_limit, max_limit)" for
your random numbers, where stream is the variable initialized by seed().
The other two should be pretty explanatory.
I haven't had time to test it though. :-)
#declare S = seed(589743);
sphere {< random(S,-1, 2), 0, 0>, 0.1}
Chris Huff
Subject: Re: seed
Date: 24 Feb 2000 08:26:32
Message: <38B53204.92AA285A@peak.edu.ee>
Two macros that do the same, used & tested:
//Create random number of given mean and maximum deviation
//M - mean value
//D - maximum deviation
//Seed - (declared) random number seed identifier
#macro rand_ext(M,D,Seed)
        (M+(rand(Seed)-.5)*2*D)
//Give a random vector of given mean and max deviation
//M - mean (vector or float)
//D - max deviation (vector or float)
#macro v_rand_ext(M,D,Seed)
        #local MV=M+<0,0,0>;
        #local DV=D+<0,0,0>;
(<rand_ext(MV.x,DV.x,Seed),rand_ext(MV.y,DV.y,Seed),rand_ext(MV.z,DV.z,Seed)>)
