POV-Ray : Newsgroups : povray.newusers : Newbie error or beta bug? Server Time
20 Jun 2026 01:09:00 EDT (-0400)
  Newbie error or beta bug? (Message 1 to 3 of 3)
Subject: Newbie error or beta bug?
Date: 19 Aug 1998 01:56:55
Message: <01bdcb2e$3058c4e0$603488cf@w003132.airmail.net>
Using the unions declared below, the translate's of the form
translate *x *y *z
work as expected, however, the
translate <x y z>
does not translate correctly in the -z direction, instead it acts like a -y
translate.
Any answers to why this might be happening?
Thanks in advance,
Brett
<code snippet>
#declare wing_bone = union
cylinder {  < 0, -6.0, -1.5>,  < 0, -4.0, -0.5>, 0.2 }
cylinder {  < 0, -4.0, -0.5>,  < 0, -2.0, -0.0>, 0.2 }
cylinder {  < 0, -2.0,  0.0>,  < 0,  2.0,  0.0>, 0.2 }
cylinder {  < 0,  2.0, -0.0>,  < 0,  4.0, -0.5>, 0.2 }
cylinder {  < 0,  4.0, -0.5>,  < 0,  6.0, -1.5>, 0.2 }
#declare wing = union
 object { wing_bone scale <1.0 0.4 1.0> translate -6*x -3.0*z }
 object { wing_bone scale <1.0 0.6 1.0> translate -4*x -2.0*z }
 object { wing_bone scale <1.0 0.8 1.0> translate -2*x -1.0*z }
 object { wing_bone scale <1.0 1.0 1.0> }
 object { wing_bone scale <1.0 0.8 1.0> translate  2*x -1.0*z }
//object{wing_bone scale <1.0 0.4 1.0> translate <-6.0 0.0 -3.0>}
//object{wing_bone scale <1.0 0.6 1.0> translate <-4.0 0.0 -2.0>}
//object{wing_bone scale <1.0 0.8 1.0> translate <-2.0 0.0 -1.0>}
//object{wing_bone scale <1.0 1.0 1.0> translate < 0.0 0.0  0.0>}
//object{wing_bone scale <1.0 0.8 1.0> translate < 2.0 0.0 -1.0>}
object { wing texture { pigment { color White } } }
<end code snip>
Subject: Re: Newbie error or beta bug?
Date: 19 Aug 1998 02:06:35
Message: <35DA4EF3.DD16D1C6@pacbell.net>
> translate *x *y *z work as expected, however, the
> translate <x y z>
> translate.
> Thanks in advance, Brett
It will work correctly if you add the changes I made below.The way you are doing
it makes the transform wok in an additive evaluation.
You need instead for each to be evaluated on an individual basis. See below -->
> <code snippet>
These
>  object { wing_bone scale <1.0 0.4 1.0> translate -6*x  translate -3.0*z }
>  object { wing_bone scale <1.0 0.6 1.0> translate -4*x translate -2.0*z }
>  object { wing_bone scale <1.0 0.8 1.0> translate -2*x translate -1.0*z }
>  object { wing_bone scale <1.0 0.8 1.0> translate  2*x translate -1.0*z }
now = These -->
> <end code snip>
  K.Tyler
Date: 19 Aug 1998 10:23:50
Message: <35dad1e6.0@news.povray.org>
On 19 Aug 1998 00:56:55 -0500, Brett Kugler
        <w00### [at] mailairmailnet> wrote:
>translate <x y z>
>translate.
The problem here is that POV can't tell whether to parse "0.0 -3.0" as
"0.0-3.0" or "0.0, -3.0" and it chooses the former.  Really old versions of
POV supported vectors without commas, and the current version continues to
attempt to support them for backward compatibility, but for all new code,
you should use commas inside vectors.
