POV-Ray : Newsgroups : povray.newusers : A Question about Bending Server Time
21 Sep 2025 16:07:30 EDT (-0400)
  A Question about Bending (Message 1 to 3 of 3)
Subject: A Question about Bending
Date: 22 Apr 1998 03:08:28
Message: <01bd6dbd$54e6cba0$17f239d1@wykan.siscom.net>
I have obtained a copy of Chris Colefax's Object Bender Include File
(Bend.inc). I was hoping that I might use it to bend an object after
applying an image map to it (to save me the trouble of bending the image
map before application; see the posting "A Question about Image Maps").
However, if I am understanding the included text (and it is quite possible
that I am not -- I am new at this), the Bend.inc is only used with
animation. Is this right?
If this is correct, a second question suggest itself: What happens if you
animate (bend) an object with an image map on it? Will the image map
distort as the object bends, or bend with it?
Subject: Re: A Question about Bending
Date: 22 Apr 1998 03:31:44
Message: <6hk6em$ap2$1@oz.aussie.org>
Wykan wrote in message <01bd6dbd$54e6cba0$17f239d1@wykan.siscom.net>...
Hi. I've never used the bend.inc (only looked at it), so I can't really
answer your second question.
But I see no reason why it shouldn't work with stills. From my short look it
seemed that it simply takes the "to-be-bent" object and cuts it into many
pieces/copies that it puts back together in the bend shape (that right?).
This should work with stills just as fine. And after all, what is an
animation, if not a series of stills...
Now, to your second question again: If my assumption of above is right, then
it might very well work with your image-map problem.
Johannes.
Date: 22 Apr 1998 07:52:48
Message: <353DDA10.D947CBBB@aol.com>
I've used it a few times and Johannes is right, bend.inc just slices up the
object to bend it.  I have used it before with blobs that have different colors,
so I would think it would work with image_maps.  It is difficult to understand
how to use it at first, and it's been awhile for me, so I really couldn't
explain it for you.  The way I learned to use it when I did was by playing with
the included sample scenes.  I remember that once you get into  it, it makes
pretty good sense.  It does have it's limitations, but it comes in handy now and
then.  I did an animation for the irtc called monarch in which I used bend.inc.
You're welcome to look at the source I included with it if you can read it.
> Johannes.
