POV-Ray : Newsgroups : povray.news-submissions : How to avoid the artifacts about height_map? Server Time
18 Mar 2026 22:41:55 EDT (-0400)
  How to avoid the artifacts about height_map? (Message 1 to 10 of 10)
Subject: How to avoid the artifacts about height_map?
Date: 4 Jan 2013 02:55:01
Message: <web.50e68a3fa2e73d93c773fff20@news.povray.org>
I'm a rookie in pov-ray, and want to use height_map for water-simulation, I
tried to use "intersecion" on the height_map,box objects, but caused strange
artifacts, but I don't know how to solve it? Could someone help?
Here's the code:
location <-1,4,-2>
look_at <0.5,0,0.5>
angle 36
light_source { <-1, 1.30, -1> White }
plane { y, 0
//pigment {  White }
image_map {jpeg "brick.jpg"}
    rotate <90,0,0>
finish{
ambient .3
diffuse 0.7
plane { z, 1
pigment {  White }
finish{
ambient .2
diffuse 0.7
plane { x, 1
pigment {  White }
finish{
ambient .2
diffuse 0.7
box{
 <0,0,0>,<1,1,1>
 pigment{Green}
intersection{
height_field {
sys "Surface.bmp" //can be replaced by other images
smooth
box{
// <0.000001,0.000001,0.000001>,<0.999,0.999,0.999>
// <0,0,0>,<1,1,1>
// <-0.000001,-0.000001 ,-0.000001>,<1.000001,1.000001,1.000001>
//<0,0,0>,<1.000001,1.000001,1.000001>
// <0.000001,0.000001,0.000001>,<1.000001,1.000001,1.000001>
 <-0.000001,-0.000001,-0.000001>,<1.000001,1.000001,1.000001>
 texture
        pigment {   color rgbt <1, 1, 1, 1> }
        finish
            ambient 0.0
            diffuse 0.0  //
            reflection
                0.02, 1.0
                fresnel on
            specular 1
            roughness .003
interior {ior 1.333}
Subject: Re: How to avoid the artifacts about height_map?
Date: 4 Jan 2013 06:45:00
Message: <web.50e6bf9cd45462dac2d977c20@news.povray.org>
Your intersection is not serving any purpose, because the 'box' part of
the intersection is actually the same size or slightly larger than your
height_field. So the result is just the height_field itself. (If the box were
smaller, then it would successfully 'trim off' part of the height_field.) By the
way, it's usually a good idea to scale down a height_field in the y-dimension,
for example <1,.25,1>. Without scaling it, it takes up an entire 1X1X1 cubic
space, and looks very jagged and odd when it's that tall. I'm guessing that you
don't want it to be so tall.
I think what's mostly confusing the scene is the pigment{rgbt <1,1,1,1>} for the
entire intersection. I assume you want it there, in order to see through the
height_field's 'water' to the bottom plane. But if the effect has ended up
looking grainy and strange, it's a result of global_settings{max_trace_level
....}  needing a boost. (Take a look in the documentation for max_trace_level.)
The default is 5; but your height_field has reflection and ior (both at *high*
values, which may not be a good idea), so a camera ray is having to do a lot of
work on its way to the bottom plane. If max_trace_level is too low, you'll
always see dark spots, or graniness. Try a higher value.
Another suggestion would be to use as high-resolution an image as you can, to
make your height_field.
Here's your intersection code slightly re-worked:
intersection{
height_field {
sys "Surface.bmp"
smooth
scale <1,.15,1>
translate -.001*y // to eliminate any possible 'coincident surfaces' between
// height_field and bottom plane. It puts the bottom of the water slightly
// *below* the plane, but that's OK.
box{
-.1,.7 // this trims the height_field somewhat. And it's an easier way of
// writing <-.1,-.1,-.1>, <.7,.7,.7>
 texture
        pigment {color rgbt <1, 1, 1, 1> } // or simply rgbt 1
        finish
            ambient 0.0
            diffuse 0.0
            reflection
                0.02, 1.0
                fresnel on
            specular 1
            roughness .003
Date: 4 Jan 2013 22:00:01
Message: <web.50e796a0d45462da362c5d560@news.povray.org>
> intersection{
> height_field {
> sys "Surface.bmp"
> smooth
> scale <1,.15,1>
> box{
>  texture
>         finish
>             ambient 0.0
>             diffuse 0.0
>             reflection
>                 0.02, 1.0
>                 fresnel on
>             specular 1
>             roughness .003
Thank you very much, but it still has problems , for the side faces of the
intersection object no refractions came out. The front and left face seem that
they don't exist, so we can directly see the bottom as if no water is here.
from http://www.f-lohmueller.de/pov_tut/all_shapes/shapes655e.htm,
I changed the sign of D,finally this can get a good result.What shocks me is
that the sign is very important. Only <D,-D,D> works well.
#declare D = 0.00001;
intersection{
height_field {
sys "Surface.bmp"
smooth
   translate<0,D,0>
box{
 <D,-D,D>,<1+D,1+D,1+D>
 texture
        pigment {   color rgbf <1, 1, 1, 1> }
        finish
            ambient 0.0
            diffuse 0.0  //
            reflection
                0.02, 1.0
                fresnel on
            specular 1
            roughness .03
interior {ior 1.33
//  dispersion  1.01
Date: 5 Jan 2013 13:50:01
Message: <web.50e8752bd45462da7312b7a90@news.povray.org>
Meshes are not the best approach for water simulation (a height_field is a very
simple kind of a mesh). That does not mean that meshes are not suited
completelly to simulate water (see La Lument by Marc Lacquier, POV-Comp 2004,
who shows impressive results with meshes). Better suited are isosurfaces. Chris
Hormann has given an excellent tutorial about this issue:
http://www.imagico.de/pov/water/index.php?lang=de
Best regards,
Michael
Date: 5 Jan 2013 13:55:00
Message: <web.50e87701d45462da7312b7a90@news.povray.org>
> Best regards,
> Michael
Sorry, I must correct myself, Marc used an isosurface too.
Best regards,
Michael
Date: 5 Jan 2013 14:00:01
Message: <web.50e8778dd45462da7312b7a90@news.povray.org>
Michael
> Best regards,
> Michael
But still impressive...
Date: 5 Jan 2013 16:14:33
Message: <50e897b9$1@news.povray.org>
Isosurfaces can make good water but they are time consuming to render.
It might be an idea if Terry looked at Tim Nikias's No Lights site. Tim
created a set of macros to simulate an animated liquid surface.
http://www.nolights.de/downloads.html#lssm
It adds up to a complete system where the waves will reflect off
boundaries or be created by raindrops, there might even be a "stomp"
feature which starts the waves by simulating a shock to the boundaries.
I am a bit vague because it is a long time ago that I did some testing
for him. It creates a mesh (of a sort) for each frame, which can be
converted to a PovRay Mesh by using his MMM Macros.
http://www.nolights.de/downloads.html#MMM
They are complicated but there are detailed help files.
Here is one of his examples:
http://youtu.be/QEzkFhQEk6g
Regards
Date: 5 Jan 2013 18:20:01
Message: <web.50e8b38ed45462dac2d977c20@news.povray.org>
Oh, now I see what you are trying to do. (Sorry, I was confused about what your
problem was. Your link to Freidrich Lohmuller's page made it clear.)
His page actually has some small mistakes, in his use of D there. I had to work
that out too.
To get what you want, your box needs to be made *smaller* on all sides than the
height_field (*except* for the top and bottom surfaces of the box.) This is what
creates the solid 'sides' of the height_field, in an intersection. If the box is
made smaller on the TOP, it will cut away some of your water waves (but they
will still be solid.) If it is made smaller on the BOTTOM, the intersection may
not be solid in certain places there--it is just like using water_level. (The
'top' and 'bottom' of a height_field behave differently in an intersection.)
But here is something interesting, and useful to know: A height_field, by
nature, actually has an *infinite* depth in -y. It is invisible, but it is
there. Because of this, the bottom of your intersection box could have a large
NEGATIVE value for y, and the intersection will still be 'solid', way down in
-y.
Here is your code again. I have added a few things, to make it more useful for
you. Now, you can make your water any 'depth' that you want, and it will remain
solid on all sides. Note that the water depth and the height_field scale are two
separate things now.
#declare water_depth = .3; // any positive value
#declare HF_y_scale = 0.55; // for the scale of the 'top surface' of the
// water; any positive value
intersection{
height_field {
sys "Surface.bmp"
smooth
scale <1,HF_y_scale,1>
translate <0,water_depth,0>
box{
 <D,-D,D>, // the bottom y-value can be anything now, + or -, but no higher
// than water_depth
<1-D,water_depth + HF_y_scale + D,1-D> // x and z are *smaller* than the
// height_field, not larger.
 texture
        pigment {color rgbf <1, 1, 1, 1>} // Here, rgbf does the same as rgbt
// because the water has no 'color.' Try changing it to rgbf <.85,.90,1,1>
        finish
            ambient 0.0
            diffuse 0.0
            reflection
                0.02, 1.0
                fresnel on
            specular 1
            roughness .03
interior {ior 1.33}
Date: 5 Jan 2013 21:10:01
Message: <web.50e8dbf4d45462dac2d977c20@news.povray.org>
By the way, D = 0.00001  serves TWO purposes here: To make the intersection box
smaller, AND to eliminate any tiny 'floating-point errors' between the box and
the height_field. Floating point errors can make the flat sides of your
intersection look 'grainy', as I mentioned before. When two flat surfaces
exactly overlap, you may see such problems.
Date: 5 Jan 2013 22:00:01
Message: <web.50e8e7abd45462dac2d977c20@news.povray.org>
> If it is made smaller on the BOTTOM, the intersection may not be solid in
Sorry, I was mistaken about that. I will try to explain it better: If the image
you use to make your height_field has any pure black or very dark colors, then
those parts of the height_field will be at or very close to the bottom surface
(y = 0.) If the bottom of your intersection box cuts into the height_field
*above* that distance, it will create holes in the bottom of the
height_field/intersection at those places (although the remainder of the bottom
surface will still be solid.)
