POV-Ray : Newsgroups : povray.news-submissions : Tkxture fast and GUI texture maker now available Server Time: 9 Jul 2008 15:34:41 GMT
  Tkxture fast and GUI texture maker now available (Message 1 to 10 of 10)
Subject: Tkxture fast and GUI texture maker now available
Date: 22 Apr 2008 19:00:00
Message: <web.480e346b4b6933d7b9ba94f70@news.povray.org>
Tkxture utility for fast POV-Ray patterned material texture creation is now
available for Linux and Windows at http://www.rgbterrain.com/
Subject: Re: Tkxture fast and GUI texture maker now available
Date: 22 Apr 2008 19:58:24
Message: <480e4360@news.povray.org>
  Looks cool. I am having one little problem, though: If the "800x600"
option is checked, it works ok, but if it's not checked then it renders
the image (CPU goes to 100% for a while) but the little image is not
updated.
Date: 23 Apr 2008 00:35:00
Message: <web.480e8301bc1b649fb9ba94f70@news.povray.org>
> updated.
  Well done!  Sounds like the only thing you are missing is ImageMagick.
The small image in the GUI depends on post-processing by ImageMagick "convert".
The 800x600 image does not.  See imagemagick.org, multi-platform, free.  Please
let me know if that works out.
Date: 23 Apr 2008 10:44:35
Message: <480f1313@news.povray.org>
  I do have convert.
>which convert
/usr/bin/convert
>convert --version
Version: ImageMagick 6.3.0 10/12/07 Q16 http://www.imagemagick.org
Copyright: Copyright (C) 1999-2006 ImageMagick Studio LLC
Date: 23 Apr 2008 17:35:01
Message: <web.480f71f7bc1b649fb9ba94f70@news.povray.org>
>   I do have convert.
> >which convert
> /usr/bin/convert
> >convert --version
>                                                          - Warp
Hmm - tcl/tk must be new enough to be able to display .ppm, mine looks like
version 8.4.  The big rendering makes "tkxture.png.  The small rendering option
calls convert, convert returns a file "tkxture.ppm".  That file should show up
in your directory where the rest of Tkxture lives, do you get the tkxture.ppm
file?  Do you see tkxture.png there?
If the output of POV-Ray has been redirected by a superceding script, of course
convert will fail.
Date: 23 Apr 2008 17:58:11
Message: <480f78b3@news.povray.org>
> convert will fail.
  Are you giving POV-Ray the necessary command-line parameters to tell it
to actually create the image file? I have "-f" in my povray.ini, so by
default it doesn't create images. You should give it a "+f".
Date: 23 Apr 2008 19:25:01
Message: <web.480f8cf2bc1b649fb9ba94f70@news.povray.org>
Okay, done.  Updated packages available as v00.04.  All of the Tkxture .ini
files now have +F.  Thanks, hope that works.
Date: 23 Apr 2008 20:18:13
Message: <480f9985@news.povray.org>
  Now it works.
  The color map editor is not the most intuitive or easy to use as
possible. Maybe you could improve that?
Date: 23 Apr 2008 21:05:00
Message: <web.480fa351bc1b649fb9ba94f70@news.povray.org>
>   Now it works.
Agreed, the colormap editor is just functional.  Next version that will
look a bit different, I'm working on an interface that will feel similar for
both colormaps and layered textures.  Thanks again for help & feedback!
Date: 1 May 2008 20:40:00
Message: <web.481a2a09bc1b649f1d01f1ee0@news.povray.org>
>   The color map editor is not the most intuitive...
There is now a snappy new Colormap editor in Tkxture v00.06.  Does not really
require new posting.  Cheers.
Copyright 1991-2004 POV-Team™
