POV-Ray : Newsgroups : povray.news-submissions : UberPOV stand-alone installer released Server Time
16 Apr 2024 06:40:52 EDT (-0400)
  UberPOV stand-alone installer released (Message 1 to 1 of 1)
Subject: UberPOV stand-alone installer released
Date: 26 Jul 2014 04:31:50
Message: <53d36776@news.povray.org>
UberPOV now has its own installer! Yay!
 From now on, UberPOV will come in two flavors:
- The classic version (e.g. 1.37.0.0-beta.7) that comes as a raw .exe to
be dropped into an existing installation, and shares POV-Ray's entire
ecosystem of sample scenes, include files, settings and what-have-you.
- A ".stalone" version (e.g. 1.37.0.0-beta.7.stalone) coming as a
full-fledged installer, to set up its own ecosystem and neither require,
nor mess with, any existing POV-Ray installation.
I'd be happy if some people would give the ".stalone" installer a test
drive; you can download it from here:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.0.0-beta.7
(Aside from being available as a stand-alone version, beta.7 should be
virtually identical to beta.6.)
Subject: Re: UberPOV stand-alone installer released
Date: 26 Jul 2014 08:33:28
Message: <53d3a018$1@news.povray.org>
the .stalone version works flawlessly (see image in p.b.i.). Only thing
I have not been able to do is install the editor. Do I have to run the
installer inside the UberPOV folder maybe?
Date: 26 Jul 2014 13:47:08
Message: <53d3e99c$1@news.povray.org>
Am 26.07.2014 14:33, schrieb Thomas de Groot:
No; if you have an existing POV-Ray installation, it turns out you'll
have to copy the files manually.
It also turns out that the editor - being a genuine POV-Ray component -
still uses POV-Ray's part of the registry; I guess I'll have to roll my
own version of that as well, but I'm somewhat wary of the legal side of it.
Date: 27 Jul 2014 03:04:14
Message: <53d4a46e$1@news.povray.org>
no problem.
Understood.
Date: 28 Jul 2014 05:03:21
Message: <53d611d9$1@news.povray.org>
Am 26.07.2014 10:31, schrieb clipka:> UberPOV now has its own installer!
Yay!
 > a test drive; ...
Thank you very much! Great work!
After copying the missing editor dlls for POV-Ray - no problems.
Tested your example files of the new features!
Every thing seems to be alright!
I'm missing: an example for blink feature!
I tried to invoke the motion blur effect but ... failed :-(
By the way:
I have corrected the include file "shapes3.inc"
(elimated a transformation error in one shape!)
I append it to this email.
It would be nice if you can integrate this corrected version
of the "shapes3.inc" in your UberPOV now, so it will have
the chance to be updated also in an update of the official POV-Ray 3.7.0
(... hope within the current century ;-) ).
Friedrich
Download 'windows-1252' (55 KB)
Date: 28 Jul 2014 07:15:10
Message: <53d630be@news.povray.org>
Try this:
//With a James Holsenback metallic texture:
#macro MetalMat (Color)
material {
     pigment {srgb Color*1.5}
     finish {
       brilliance 4
       diffuse 0
       metallic
       specular 0.80
       roughness 1/40
       reflection {srgb Color roughness 1e-5}
   interior {
     ior 1.5
//the calls: MetalMat (<0.65, 0.15, 0.25>) MetalMat (<0.5, 0.65, 0.25>)
MetalMat (<0.25, 0.5, 0.65>)
#local Ovus =
ovus {
   1.00, 0.65 // base_radius, top_radius  with: top_radius< base_radius!
   translate 0.5*y
   scale 0.5
#local DeltaT = 0.1;
union {
   #for (T, 0.0, 1-DeltaT, DeltaT)
   object {Ovus rotate <0, 0, 2/T> blink 0, T+DeltaT}
   object {Ovus rotate <0, 0, -2/T> blink 0, T+DeltaT}
   translate <-1.00, 0.0, -1>
union {
   sphere {
     <T, 0.25, -1.2>, 0.25
     blink 0, T+DeltaT
Date: 28 Jul 2014 07:44:32
Message: <53d637a0$1@news.povray.org>
Am 28.07.2014 11:03, schrieb Friedrich:
> Yay!
>  > a test drive; ...
Thanks. Love to hear that.
Looks like I goofed that one. You should be able to find one called
"blink.pov" in the GitHub repo, right here:
https://github.com/UberPOV/UberPOV/tree/master/distribution/scenes/uberpov
Apparently the revision I built was not the one tagged
"v1.37.0.0-beta.7", but the commit right before that (83d4165).
Fortunately the missing sample scene is the only thing that's different
between the two.
> By the way:
I won't do that. UberPOV is intended to be a collection of patches, not
of fixes. If it's broken in POV-Ray, that's where it should be fixed.
I'll therefore submit it to the POV-Ray repo.
If you intend to provide more fixes, samples, templates etc., feel free
to create your own fork of the POV-Ray repo on GitHub, make changes on
that fork as you see fit, and then submit those changes as a pull
request. Once you have gone through setting up that fork and installing
a Git client (I'd recommend Atlassian SourceTree), I think that's the
easiest procedure for all involved.
