POV-Ray : Newsgroups : povray.news-submissions : Spectral Rendering with POV-Ray Server Time
18 May 2024 01:00:23 EDT (-0400)
  Spectral Rendering with POV-Ray (Message 27 to 36 of 36)
Subject: Re: Spectral Rendering with POV-Ray: comments on the tutorial
Date: 25 Sep 2012 14:10:05
Message: <5061f37d@news.povray.org>
Am 24.09.2012 16:02, schrieb Thomas de Groot:
> Done a new render with finish{} added to the gold.
Hm, I fail to notice any improvement :(
Having not used any of the standard texture include files myself since
decades I took a quick look at golds.inc and assume you did replace the
P_Gold statements by
#declare P_Gold1 = srgb CVect1;
...and so on, right?
Well, I have sworn to keep my mouth shut on this topic but I simply
can't help it. As I have stated multiple times all "color math" works
only as expected within a linear color space (and doing this kind of
math myself very often is one of the reasons I advocate for
assumed_gamma 1.0 since decades).
Now the author of golds.inc does apply a lot of mathematical operations
on this declared color vectors afterwards - but when this vectors are
already defined as non-linear srgb values all these operations are
pretty pointless and the final textures will never look like expected.
And to get even a bit on topic ;) you might find the M_Gold macro with
its sub-macro calls that are used for *Preview* rendering useful (and
with a high reflective value like M_Gold(0.9) ) as they give under all
lighting conditions fairly realistic results.
-Ive
Date: 26 Sep 2012 03:52:18
Message: <5062b432$1@news.povray.org>
Well, I did, some... :-)
Yep.
In fact, I do not see any difference, but I see your point.
So... where is this M_Gold() located? I cannot find it  :-(
Date: 26 Sep 2012 04:13:36
Message: <5062b930$1@news.povray.org>
OK. Found it. My brain is sluggish (it's Wednesday, don't ask me why).
Date: 28 Sep 2012 04:05:15
Message: <50655a3b$1@news.povray.org>
I patched in an updated gold nugget bowl with M_Gold(0.9). I first tried
a reflectance of 0.5 to see the difference.
Thanks for pointing me to the macros. I shall return to them in future
scenes I am sure.
Date: 28 Sep 2012 08:34:17
Message: <50659949$1@news.povray.org>
Am 28.09.2012 10:05, schrieb Thomas de Groot:
Looks better, methinks ;)
The problem with most of these "old" texture definitions is not only the
rgb vs. srgb problem. They are simply designed at a time when nobody was
using radiosity or HDR-lighting (i.e. not necessarily HDRI but
light_sources with emitting values higher than 1.0). For example
golds.inc uses an ambient term for the color *calculation* but ambient
(as part of the finish) gets meanwhile switched off as soon radiosity is
used.
I'm always did find it easier to use textures that come close to real
world physics (within the limitations of raytracing) and as such do work
under all lighting conditions (conventional with/without radiosity and
radiosity only) instead of tweaking a texture every time I use it.
To me this is not so much about photorealism, it is more about laziness ;)
-Ive
Date: 28 Sep 2012 10:03:05
Message: <5065ae19$1@news.povray.org>
Yes, it does indeed.
> used.
I fully agree. Normally, I rarely use the "out of the box" textures and
prefer to brew my own. Only for those special cases like gold I am
rather unsure and tend to use something available, forgetting that they
are often far from up-to-date.
You are privileged to know what you are talking about :-)
An acceptable way of life ;-)
Date: 29 Sep 2012 21:10:02
Message: <50679bea$1@news.povray.org>
Am 28.09.2012 14:33, schrieb Ive:
+1
Date: 1 Jan 2013 16:25:01
Message: <web.50e353ce8647b6ff259be2c70@news.povray.org>
Ive <ive### [at] lilysoftorg> wrote:
> The animation feature of POV-Ray can be used to make it a spectral
> render engine. The basic idea is to render a set of gray-scale images
>   - each representing a specific wavelength - and finally combine them
> using the CIE color match function.
> To simplify this task I have created a few POV-Ray SDL scripts and some
> examples.
> You'll find the download link, some images and more explanation here:
> http://www.lilysoft.org/CGI/SR/Spectral%20Render.htm
> -Ive
Would this help POV to render caustics any faster?
I ask this because I could not after all my attempts get POV-Ray to render some
caustics scene with chromatic dispersion as fast as Lux Render did (Lux uses
spectral rendering)other than that I would have been so happy to use POV because
of so many other features, but for this particular scene, the speed issue was
really too high of a bottleneck, preventing it to keep the same quality between
the two renderers.
Date: 1 Jan 2013 17:43:44
Message: <50e366a0$1@news.povray.org>
Am 01.01.2013 22:23, schrieb Mr:
>> examples.
>> -Ive
> the two renderers.
I'm not sure how Lux does it, but here's one optimization I could
imagine, which POV-Ray currently doesn't do:
When the generated photon map is evaluated for a dispersed (and hence
monochromatic) ray from the camera, dispersed (and hence also
monochromatic) photons with a different wavelength could theoretically
be ignored (and those typically are a lot if you make ample use of
high-quality dispersion).
In POV-Ray, the fact that a photon was subject to dispersion (and hence
is monochromatic) is forgotten in the stored photons map; such photons
are instead stored just like normal non-dispersed colored photons. Thus,
POV-Ray needs to evaluate each and every photon even for monochromatic rays.
As Ive's approach only deals with one single wavelength per render
anyway, it automatically gets that optimization for free. However, for
non-dispersed rays and photons it loses a lot in terms of performance,
as it needs to trace such rays and photons over and over again for each
wavelength even though their trajectory is the same for all wavelengths.
Hard-coding this optimization into POV-Ray should be no big deal; it
doesn't even need full-fledged spectral color math to work. It would
probably increase the photons map memory footprint by 20% though.
Date: 2 Jan 2013 07:30:01
Message: <web.50e427e98647b6ff259be2c70@news.povray.org>
> >> examples.
> >> -Ive
> > the two renderers.
Thanks! Your explanation is so clear! I would vote for the speed optimization as
I have so much RAM, but I would understand if others disagree. In which case I
would never be able to finish that stupid render. It's not even pretty, just a
comparative test :-)
