![](/i/fill.gif) |
A new version 0.8 of Arbaro is released. See
https://sourceforge.net/projects/arbaro/
Comparing with version 0.7 there are the following
major changes:
- pictures explaining the parameters
- direct POVRay invoking option
- using mesh output the tree consists only
of two meshes: one with all the stems and another
with all the leaves. (You can give the triangle
number of a leaf using disc1 ... discN for the
Leaf parameter, for special purposes you can use
Leaf=shpere (spherical leaf), it's aproximated
by an ikosaeder, see desert_bush.xml as an example)
Plans for the next versions:
0.9 - support multiple trunks (for bushes and shrubs)
- add leaves that aren't totally flat - e.g. for palms
...1.0 - fix all small bugs and quirks
- more realistic trunk (bumps and displaced lobes)
maybe later: blossom and fruits, more species, special
features for coniferes, e.g. needles on all stem levels.
Wolfram Diestel <wol### [at] steloj de FORIGU>
![](/i/fill.gif) |
