![](/i/fill.gif) |
The tree generation tool Arbaro is now ported to Java.
(So speed is ok now).
You will find the release 0.6 on the sourceforge server here:
http://sourceforge.net/projects/arbaro/
Beside porting to Java, some more features are added
and bugs fixed. Lobes and Mesh output are added since the
0.4 release. There are more tree definition files.
A dozen of rendered example trees you will find here:
http://arbaro.sourceforge.net/
With interested people I would like to discuss some
specific problems, like:
- would it better for Povray memory usage to put leaves in
a big mesh instead of a union of discs
- a splitted trunk looks somewhat strange, should the
trunk radius be smaller for clones or is this a problem
with mesh creation
- would a more evenly splitting algorithm be preferable
Wolfram.
Wolfram Diestel <wol### [at] steloj de FORIGU>
![](/i/fill.gif) |
![](/i/fill.gif) |
A mesh should be definitely better.
I don't know if it will make a big difference in memory usage/rendering
time if you have one single tree, but if you copy the same tree several
times in your scene it should definitely have a great impact in memory
usage.
![](/i/fill.gif) |
