POV-Ray : Newsgroups : povray.general : about #debug Server Time
16 Apr 2026 08:06:40 EDT (-0400)
  about #debug (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: about #debug
Date: 3 Apr 2026 17:30:00
Message: <web.69d03070f5eb3fcd11f50c6059126100@news.povray.org>
> (sets of three) vectors, then one could read and process those, and "line
> numbers" and eliminating unwanted triangles would become "doable" (if slow).
> with your current file format, ie fully specified meshes, POV-Ray is the wrong
> tool, imo.
> regards, jr.
Yes, POV-ray isn't responsible for editing files, but for rendering them.
But I had the idea because it can instantly identify small errors in the shape
that I'd missed when switching from double to single. So I wondered if there was
a way to have it list or correct them without having to go back and re-filter
again.....
Note :In the models I finally store, I generally save the final result in single
float with 4 decimal places.
If they're POV or INC, they're more compact and still satisfactory. If they're
3D for print, even more so, because STL requires single float.
thanks!
BR
G.
Date: 6 Apr 2026 08:10:00
Message: <web.69d3a1f0f5eb3fcdda82d88b25979125@news.povray.org>
Gio,
It sounds to me like what you want to do is read in a mesh, and perform a vector
cross product calculation.
That should identify any degenerate triangles, since the cross product will be
0.
Discard those, and write the good triangles to a new file.
- BE
Date: 6 Apr 2026 09:10:00
Message: <web.69d3af95f5eb3fcdb9ac97ab59126100@news.povray.org>
> Gio,
> 0.
> - BE
That's what I already do. I wanted to know if, alternatively (when I go from a
double float with area to a single float that becomes arealess), when POV
automatically detects and marks them, it can also do this in the file.
To avoid reprocessing all the normals in the single float.
TX
G.
Date: 6 Apr 2026 09:20:00
Message: <web.69d3b29bf5eb3fcdb9ac97ab59126100@news.povray.org>
Let's see if I can make myself understood with a simple example.
I have a triangle.
<1,1,1><2,1,1><2,1,1.00000009>
this is a valid triangle
ok?
but if I made automatically a pov ray file that uses the format ###.####,
writing the pov file , the triangle becomes with
the vertex 3 becomes = vertex 2
and the triangle is invalid
obviously !!!
If I want to avoid re-checking for every triangle in the formatted file, is it
possible to have POV Ray remove them from my file?
In a new, clean file
or, returning a list of the triangles to delete.
Date: 6 Apr 2026 09:25:00
Message: <web.69d3b31bf5eb3fcdda82d88b25979125@news.povray.org>
It cannot.
That sort of file processing is left to the user.
At present, we have what we have been given in our little open-source collection
of modules.
And as clipka was fond of saying: "POV-Ray is a raytracer".  And so there's not
a lot of "extraneous" capability tied in to the parser.
And we all know clipka's legendary love for the parser.
So, you either need to write a processor yourself in SDL,
or as a 3rd-party tool in some other language,
or write something that can perform that task and be integrated into source.
IIRC, I think MeshLab will detect all the bad triangles, close any holes, and
save a good file.
- BE
Date: 6 Apr 2026 10:00:00
Message: <web.69d3bb53f5eb3fcd17bac71e8ffb8ce3@news.povray.org>
> I've studied the #debug feature a bit, but I don't understand. Is there a way to
> tell PovRay to generate a file with only the incorrect entities, or to rewrite
> my file to clean them up?
> It would save me some often long and tedious work.
The mesh2 files are not accessible as arrays, so you can't loop over the content
and check for vertices being ~equal.
Options:
- manually or using a script turn your mesh-file into a file of arrays. Then you
can loop over them and check
- write a small mesh2 parser in a scripting language. There then loop over the
triangles. I once wrote a mesh2 to obj converter in Python. It may still be
somewhere in the newsgroups. I myself lost it.
- use a mesh cleaner. May have to convert to an other format first, or if you
use an other format before converting to mesh2, use that file format to clean.
- check what PoseRay can do (for you) in this regard. I really don't know, it's
been a long time since i used it.
ingo
Date: 6 Apr 2026 10:10:00
Message: <web.69d3bd68f5eb3fcdb9ac97ab59126100@news.povray.org>
> It cannot.
> of modules.
> save a good file.
> - BE
OK, now I'm sure there's no way; studying the #debug function, I couldn't figure
out if it was possible.
I'll implement an additional control filter in my parser, along with the
formatting function I use when generating the pov and inc files.
Note: I normally use MeshLab, but be careful with filters. Sometimes, when
closing holes, and especially in decimation, it introduces intersections that
become tedious to track down. If I use these functions, I then test and ask the
entire shape to normalize again, to verify that no bugs have been generated.
Decimation is really dangerous.
Date: 6 Apr 2026 10:45:00
Message: <web.69d3c647f5eb3fcdb9ac97ab59126100@news.povray.org>
ok, thanks to all
my trouble was about the format of vertex only on ####.#### that can to
degenerate triangle losing last decimals ...
if the #debug cannot try them out, I have to control the triangle again after
the formatting procedure of my parser
no proble... this is my parser working
sketch-up , cad, pov STL ..
Download 'screenshot 2026-04-06 163214.png' (546 KB)
Preview of image 'screenshot 2026-04-06 163214.png'
Date: 6 Apr 2026 12:00:00
Message: <web.69d3d839f5eb3fcdda82d88b25979125@news.povray.org>
> ok, thanks to all
Is there a way to filter out those triangles from the start?
Are they even necessary / visible?
You can probably test just the fractional portion of your double/float by using
modulo.
#if (mod(Number, 1) < threshold) then ignore triangle #else keep it #end
- BE
Date: 6 Apr 2026 12:30:00
Message: <web.69d3de5ef5eb3fcdb9ac97ab59126100@news.povray.org>
> > ok, thanks to all
> modulo.
> - BE
Unfortunately, it's more complicated. If the mod exists beyond a certain decimal
point, the parser must first clean up the vertex by the small part of float,
then check if a twin face exists.
I'll have to create a twin face search loop after writing the mesh with
formatting that trims small decimal points... that is, a loop nested within
another loop... a lot of runtime.
povray forgives a duplicate face, but the other formats I use do not (for an STL
this is a serious mistake)
