POV-Ray : Newsgroups : povray.general : Animation feature request. Server Time
22 Mar 2026 08:18:14 EDT (-0400)
  Animation feature request. (Message 1 to 5 of 5)
Subject: Animation feature request.
Date: 20 Mar 2026 23:30:00
Message: <web.69be105f435354d91463fe62d568493a@news.povray.org>
I wish we had access to Subset_Start_Frame and Subset_End_Frame from within the
SDL.
We already have access to initial_frame, final_frame, frame_number, etc.
I have a inc file that reports (via #debug) animation average frame time,
estimated completion time, etc. It doesn't work if I am only rendering a subset
of an animation.
(In response to "Post something", Bald Eagle)
m@
Download 'sshot01.png' (3 KB)
Preview of image 'sshot01.png'
Subject: Re: Animation feature request.
Date: 21 Mar 2026 08:40:00
Message: <web.69be907ff7a27764e29d7fa930225ff5@news.povray.org>
It won't solve your problem, but I want to advertise my animation script
collection again at this point.
https://www.maetes.com/en/povray-os/ma_screenplay
ma
Date: 21 Mar 2026 09:30:00
Message: <web.69be9c7bf7a277641f9dae3025979125@news.povray.org>
Thanks - that's one facet of this thread - so often we're independently trying
to work something out by ourselves (which is admirable), but the solution might
elude us for some time and thwart the completion of a project.
> SDL.
> of an animation.
Yes, that would be helpful.
I don't often use animation or ini files (that's more of a jr thing)
but I'm wondering if you can do something similar to what's done with screen.inc
where the user defines the camera position and look_at vectors as SDL-visible
identifiers, and then proceeds to use them from there.
I recall that you can set identifier values from an ini file, so perhaps you can
pass the information in to the main scene file that way.
3.2.5.1 Constant
Declare=IDENTIFIER=FLOAT Declares an identifier with a float value
You can now declare a constant in an INI file, and that constant will be
available to the scene. Since INI file statements may also be laced on the
command-line, you can therefore also declare on the command-line (though there
is no switch for it).
  Declare=MyValue=24
This would be the same as a #declare MyValue=24; in a scene file. The value on
the right-hand side must be a constant float value.
A possible use could be switching off radiosity or photons from command-line:
--in INI-file / on command-line
Declare=RAD=0
--in scenefile
global_settings {
  #if (RAD)
    radiosity {
So, in your ini file you do something like Subset_Start_Frame=30
but I'm wondering if you can then do something like
Declare=SSF=Subset_Start_Frame.
If not, you could just set Declare=SSF=30 and then do Subset_Start_Frame=SSF
(if that works)
- BE
Date: 22 Mar 2026 04:00:00
Message: <web.69bf9f70f7a277641463fe62d568493a@news.povray.org>
> > SDL.
> > of an animation.
> 3.2.5.1 Constant
>   Declare=MyValue=24
> Declare=RAD=0
> --in scenefile
> global_settings {
>   #if (RAD)
>     radiosity {
> #end
> (if that works)
> - BE
Thanks for the reply, I didn't realise I could pass identifier values from an
ini file, that's useful.
Unfortunately "The value on the right-hand side must be a constant float value."
So this works:
   Subset_Start_Frame=394
   Declare=SSF=394
But these don't:
   Declare=SSF=float(Subset_Start_Frame)
   Declare=SSF=394
Declaring twice is no big hardship as long as I remember!
Thanks again,
m@
Date: 22 Mar 2026 04:50:00
Message: <web.69bfad1af7a2776448bf72fa6cde94f1@news.povray.org>
hi,
> > (if that works)
> So this works:
>    Declare=SSF=394
> But these don't:
>    Declare=SSF=394
another option, not yet mentioned, is having a (shell) script run from the
'pre_frame_command' which writes the values to a simple CSV type file that you
can read from within the scene.
regards, jr.
