POV-Ray : Newsgroups : povray.general : Help: How to create a bolt? Server Time
11 Mar 2026 01:38:55 EDT (-0400)
  Help: How to create a bolt? (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Help: How to create a bolt?
Date: 8 Mar 2026 00:20:00
Message: <web.69ad06ab9c1bf2d94b3090d75f41e3cc@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> function{
>       f_helix1(
>          x,y,z,
>          1,    // number of helixes, (1 = single helix, 2 = double helix
> etc.)
>          22,   // period,      turns on the length of 2*pi
>          0.07, // minor radius,
>          0.80, // major radius,
>          1,    // shape parameter,
>          0.3,  // cross section type, (0.0 to 1.0 = square ... rounded
> to circle
>                //     over 2.0 to 3.0 = rounded to diamond and concave
> diamond
>          0     // cross section rotation angle
> shape in degree.
> The 9th parameter let you change the shape.
The 9th parameter. I'm distracted.  I turned 90 degrees and saw no change. ))) I
should have been 45!!! Thank you so much!!!
Date: 8 Mar 2026 00:45:00
Message: <web.69ad0ba99c1bf2d94b3090d75f41e3cc@news.povray.org>
"Jeff Reifel" <jef### [at] gmailcom> wrote:
> "LanuHum" <Lan### [at] yandexru> wrote:
> > Hi! I am interested in the question: is it possible to create a thread without a
> > mesh of triangles? We need a smooth surface of the thread in the picture
> > 38400x21600 (4K * 10)
> Here is a simple idea.
> #declare i=0;
> #while(i<18 )
> cone{0,.5,y*-.5,0 translate < .4,-2>  rotate y*360*i translate -y*i*.5
> pigment{blue 1}}
>  cone{0,.5,y*.5,0 translate <.4,-2>  rotate y*360*i translate -y*i*.5
> pigment{red 1}}
> #declare step=.01 ;
> #declare i=i+step;
> #end   translate <0,9,0>}
Thanks, it's a good idea, but for a big picture you need to increase the number
of steps many times. Otherwise, defects are visible :(
Download 'scene.png' (101 KB)
Preview of image 'scene.png'
Date: 8 Mar 2026 10:00:00
Message: <web.69ad80a19c1bf2d91f9dae3025979125@news.povray.org>
> > without a mesh of triangles?
"Cousin Ricky" <rickysttATyahooDOTcom> wrote:
> https://news.povray.org/5eec257c%241%40news.povray.org
There is also this thread:
http://news.povray.org/povray.general/thread/%3Cweb.64ff068eb373d57cf00fef66b571e5b2%40news.povray.org%3E/
Always do a search for "prior art" when trying to accomplish a task.
"povray screw threads" or similar.
I'm sure there are several similar projects in the newsgroups - I know that I
have modeled screw threads and drill bits, and other helical shapes in the past.
- BE
Date: 9 Mar 2026 04:40:00
Message: <web.69ae87539c1bf2d916086ed06830a892@news.povray.org>
Hi, Also, though it may be less physically accurate with respect to its
geometry,
this scene on Jaime Vives Piqueres site still works out of the box and features
a nice lighting and composition setup:
http://ignorancia.org/uploads/zips/boltstill.zip
....If you just drop all of the lightsys macro files within the same folder :
http://ignorancia.org/uploads/zips/lightsys4b.zip
Download 'boltstill.png' (374 KB)
Preview of image 'boltstill.png'
Date: 9 Mar 2026 13:40:00
Message: <web.69af05889c1bf2d94b3090d75f41e3cc@news.povray.org>
> - BE
Thanks. I tried to search, but immediately the word spiral thread is associated
with the hyper threads of a computer processor. )))
Date: 9 Mar 2026 14:35:00
Message: <web.69af11bd9c1bf2d94b3090d75f41e3cc@news.povray.org>
> geometry,
Hi! Thanks, I saw a height_field in the file. This is a bad decision for my
purpose. Scattering media with photons example + drum kit. 2 Up pictures from
documentation and demo scenes. I want to create a real scene based on two
examples from the documentation. The camera will be in different locations. In
some cases, this spiral thread will be perfectly visible.I need clear, smooth
lines with no signs of a low-poly gamedev.
Download 'idea.jpg' (188 KB)
Preview of image 'idea.jpg'
Date: 10 Mar 2026 08:50:00
Message: <web.69b009759c1bf2d916086ed06830a892@news.povray.org>
> > geometry,
Why do you mention low poly? it's non-mesh... also the heightfield is used only
for the head, which you don't need.
But anyway many other answers before I mentioned Jaime's offer other non-mesh
alternatives so by now, you end up having too many options, so you need more
time to just pick one of them :-P The scene will be awesome!
Date: 10 Mar 2026 10:55:00
Message: <web.69b030a39c1bf2d960e0cc3d949c357d@news.povray.org>
> Thank you. I understand macros very poorly, but I can create a spiral from a
> sphere_sweep. Then subtract the spiral from the cylinder. But, I want to achieve
> a realistic profile.
Either of the isosurface solutions Robert Munyer and I posted would satisfy this
profile.
https://news.povray.org/875zph8073.fsf%40munyer.com
Date: 10 Mar 2026 11:50:00
Message: <web.69b03d4c9c1bf2d94b3090d75f41e3cc@news.povray.org>
My dear friend, I need a version that will be included in our Pov@ble addon. You
have to understand that I'm not going to write a pov file with my hands, but I'm
going to get it from a blender.
Date: 10 Mar 2026 12:00:00
Message: <web.69b03ef59c1bf2d9f625f77c25979125@news.povray.org>
"To create threads in Blender, enable the built-in "Bolt Factory" add-on in Edit
> Preferences > Add-ons. Once active, press Shift+A, select Mesh, and choose
Bolt to generate customizable threaded bolts or nuts. Adjust settings like
Major/Minor Pitch for size and Crest/Root for shape."
- BE
