POV-Ray : Newsgroups : povray.general : Inverse (object) panorama Server Time
24 Feb 2026 04:51:14 EST (-0500)
  Inverse (object) panorama (Message 1 to 8 of 8)
Subject: Inverse (object) panorama
Date: 27 Dec 2025 04:05:00
Message: <web.694fa11a1565267f54975956784a083c@news.povray.org>
Still in love with the elegance of user_defined cameras. Here's the code for a
"inverse panorama", also known as an "object panorama".
// Object panorama camera
// (x,y) range from -0.5 to 0.5 each
#declare ZMIN = -0.45;            // Vertical range of camera
#declare ZMAX = 0.45;             // Determined by actual height range of the
object
#declare RANGE = 10;              // Distance of camera, wide FOV to
orthographic
#declare PANANGLE = radians(90);  // Pan panorama
   user_defined
   location {
      function { RANGE * cos(x*pi*2 + PANANGLE) }
      function { RANGE * sin(x*pi*2 + PANANGLE) }
      function { ZMIN + (y+0.5) * (ZMAX-ZMIN) }
   direction {
      function { -cos(x*pi*2 + PANANGLE) }
      function { -sin(x*pi*2 + PANANGLE) }
      function { 0 }
Instead of a slit camera at a single position rotating about a vertical axis,
one moves a slit camera on a circle around an object where the camera is looking
towards the center of the object. A bit weird, like all multi-point projections.
Some examples attached of some Chinese puppets.
Download 'example.jpg' (3316 KB)
Preview of image 'example.jpg'
Subject: Re: Inverse (object) panorama
Date: 27 Dec 2025 10:24:21
Message: <694ffa25$1@news.povray.org>
It looks interesting and unusual, how large are models of puppets ?
YB
Date: 27 Dec 2025 11:35:00
Message: <web.69500a6feff8ac8317bac71e8ffb8ce3@news.povray.org>
Slit camera's are nice, one can do strange things with them. I the past I
simulated one in POV-Ray by using a 1-3 pixel wide image and animate that around
a subject. Then stitch the images together.
for some inspiration:
https://www.flong.com/archive/texts/lists/slit_scan/index.html
Slit camera's are (also) used for photo finishes.
A fist attempt withe the user defined camera:
https://news.povray.org/povray.binaries.images/thread/%3CXnsA9DA8E84160EEseed7@news.povray.org%3E/?ttop=444438&toff=700
ingo
Date: 28 Dec 2025 02:45:00
Message: <web.6950df5aeff8ac8317bac71e8ffb8ce3@news.povray.org>
"ingo" <nomail@nomail> wrote:
> In the past I simulated one in POV-Ray by using a 1-3 pixel wide image and
> animate that around a subject. Then stitch the images together.
found it at
https://news.povray.org/povray.binaries.images/thread/%3C389290B0.58D1D188%40email.com%3E/
ingo
Date: 28 Dec 2025 03:15:00
Message: <web.6950e64aeff8ac8317bac71e8ffb8ce3@news.povray.org>
found it at
ingo
Date: 1 Jan 2026 05:10:00
Message: <web.6956479feff8ac8354975956784a083c@news.povray.org>
Physical size or data size?
Physically between 0.5m to 0.8m.
For this process I render them at 6 million triangles, but that is mostly for
the rigging and editing processes. Then can be safely reduced to about 1 million
triangles. Currently a single 64Kx64K texture map.
Textured
   https://vimeo.com/1150255426
And just geometry
   https://vimeo.com/1150255327
Date: 1 Jan 2026 05:15:00
Message: <web.69564822eff8ac8354975956784a083c@news.povray.org>
> found it at
> ingo
That's also how I did it in the past.
Date: 4 Jan 2026 08:11:37
Message: <695a6709$1@news.povray.org>
> Textured
> And just geometry
Thanks so much for this info. Now I am trying to optimize 'Metashape'
process, taking into account 6048 x 4032 resolution of my new camera.
I would like to find a balance between model quality and users
devices performance to extend potential community. Few experiments
show that texture size is a serious limit, so I am producing few
model's versions with 4K, 8K, (16k in future).
Now looking for optimal number of triangles ...
YB
