POV-Ray : Newsgroups : povray.general : odd behavior of photon reflection/refraction defaults Server Time
13 Jan 2026 19:14:57 EST (-0500)
  odd behavior of photon reflection/refraction defaults (Message 21 to 24 of 24)
Subject: Re: odd behavior of photon reflection/refraction defaults
Date: 3 Jan 2026 15:26:37
Message: <69597b7d$1@news.povray.org>
On 1/3/26 13:41, Alain Martel wrote:
> When you use count, the count value is the total number of photons to be
> shot, distributed between all targets and all lights. The area, or
> angular size, of the targets also play a role. A big target will tend to
> get more photons than a small target next to it.
> The photon shooting always try to keep the photon density constant
> between all targets.
> count 1 000 000
> two lights and two targets of roughly the same size, and each light will
> shoot about 250 000 photons at each target.
> Have three targets, and you shoot about 166 666 photons per light at
> each target.
Thank you, Alain. More I didn't know! :-)
Bill P.
Date: 5 Jan 2026 09:50:00
Message: <web.695bce6d874e57e8e83955656e066e29@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 1/2/26 20:44, Kenneth wrote:
> > However: Given two (or more) 'target' objects in a scene, the photon behavior
> > for each can be unexpectedly different, depending on whether 'count' vs.
> > 'spacing' is used:
> > A) With 'count':
> > [snip]
> > B) With 'spacing':
> > [snip]
> Re: (A) Interesting & news to me. I thought the count applied
> independently to each target. Thanks for digging into the behavior!
It was also a new discovery for me...as were Alain's comments when using
*multiple* lights and photon targets. In most of my old photon scenes, I used
'count' out of simplicity-- totally unaware of its various 'if/then/else'
results.
I'm beginning to think that 'count' should be deprecated going forward(!), since
'spacing' easily produces **expected** results, especially with the useful
numerical multiplier for a 'target'.
BTW (and a bit off-topic):
Just out of curiosity, I tried adding the typical no_shadow and no_image flags
to my photon 'target' object, to see what would happen...and either flag
*eliminated* the caustics on my 'collector' object's surface (in both v3.7 and
3.8). That does not *seem* to be an expected result to me-- based on what those
flags are usually supposed to do-- but I'm still trying to wrap my brain around
the logic it. IF those flags are operating correctly in this case, are photons
'shadow-based' in some way? That is, should photon caustics be regarded as
light/SHADOW effects?
But what definitely seems strange is that adding no_shadow to my *collector*
object eliminated the caustics too.  My understanding of
no_shadow is that it's only supposed to eliminate shadows that are cast *from*
an object (my collector in this case) onto other objects.
Whether or not this is the designed/expected behavior of the two flags when
photons are used, the practical result is that those objects will exhibit
unexpected absence-of-photon effects in a scene (given that 'collect ON' is the
default for all objects when a global photons block is present).  And the use of
no_shadow and no_image for scene 'workarounds' will not work without eliminating
the caustics as well.
Date: 5 Jan 2026 10:43:31
Message: <695bdc23@news.povray.org>
>>> 'spacing' is used:
>>> A) With 'count':
>>> [snip]
>>> B) With 'spacing':
>>> [snip]
> results.
Then, we must remember that shadowless lights never case photons.
 From your test, it seems that disabling shadows also disable photons.
Date: 5 Jan 2026 22:54:30
Message: <695c8776$1@news.povray.org>
> results.
The last time I used 'count' was around 20 years ago, back when I was
using a 1996 vintage laptop.  When I bought a new laptop in 2006, I
found new freedom with lots of RAM, and have been using only 'spacing'
for new scenes ever since.
