POV-Ray : Newsgroups : povray.general : Impossible stl file conversion! Server Time
13 Jan 2026 17:33:20 EST (-0500)
  Impossible stl file conversion! (Message 11 to 20 of 37)
Subject: Re: Impossible stl file conversion!
Date: 10 Sep 2025 12:55:00
Message: <web.68c1ac45a068c28cbe3debd925979125@news.povray.org>
"ingo" <nomail@nomail> wrote:
> for the current POV-Ray situation, I'm mostly writing my own little tools "that
> do things" and then call POV-Ray on the generated scene. The opposite of POV-Ray
> should be able to do it "all". Although I would like the latter,
> ingo
Well, given "the current POV-Ray situation", I'm trying to break out of that,
since "what is tolerated is what will continue".
I suppose I have a Persistence of Vision.  ;)
I'm not exclusionarily averse to things like macros and separate utilities,
however, it would be highly desireable to in some way integrate those things
into the POV-Ray "package".
An official repository on the website, a folder in the official distro, scripts
to run whatever conversion or creation needs to be done, or most preferable -
the inclusion of an additional module in the source.
I'm especially pushing for this stl module, since it appears so straightforward
a task (for a c++ programmer), and the availability of millions of free stl
files available.  We don't have a modeler - but there are models.
And it there are modelers available to make/edit stls.....
- BW
Date: 11 Sep 2025 04:05:00
Message: <web.68c28199a068c28c17bac71e8ffb8ce3@news.povray.org>
> #declare MyObject = mesh2 {stl "MyObject.stl" make_arrays ...}
#declare MyStlObject = mesh2{stl "MyObject.stl"}
#declare MyObjObject = mesh2{obj "MyObject.obj"}
that's quite elegant, to extract from a file format, what POV-Ray understands
based on mesh2.
I'd separate extracting array into something like:
mesh2array(mySTLObject, verticesname, normalsname, facesname, uvname,
vertexcoulours etc..)
could result in a bunch of arrays declared with the given names. It should take
mesh & mesh2.
and/or
mesharrays{obj "MyObjObject.obj"} and extract everything the file supports into
arrays, even what's not understood by mesh2, like boning, face normals or non
triangle faces.
ingo
Date: 11 Sep 2025 06:20:18
Message: <68c2a262$1@news.povray.org>
On 09/09/2025 02:32, Bald Eagle wrote:
>                   ........... what's that?!!!
> He provides not one but TWO .stl files . . .
Blender can import STL and export POV.
YB
Date: 11 Sep 2025 10:51:10
Message: <68c2e1de@news.povray.org>
On 10/09/2025 17:11, kurtz le pirate wrote:
> The wiki page shows that the structure is very simple, and I think Perl*
> is a very good candidate for this.
Finally, I spent an hour and here is my first result ;)
I found this template on the web :
<https://www.thingiverse.com/thing:7119375>. The downloaded STL file is
in binary mode. I converted it to ASCII on this website :
<https://3dcustomizer.net/tests/stl-bin-to-ascii.html>
Here is the first image to compare with the one on Thingiverse.
I also added an archive that contains :
* Stackable_crate_gridfinity-ascii.stl : the ascii stl file
* stl2pov.pl : the perl script
* Stackable_crate_gridfinity-ascii.inc : the mesh{} include file
   generated by the script
* test.pov : demo scene
* test.png : the image
Of course, there are quite a few things to add such as binary format,
normals & mesh2{}, colors, etc.
kurtz le pirate
compagnie de la banquise
Download 'test.png' (376 KB) Download 'stl2pov.tar.gz' (1239 KB)
Preview of image 'test.png'
Date: 11 Sep 2025 12:55:20
Message: <68c2fef8@news.povray.org>
Three more attempts always from Thingiverse.
The lack of normals is clearly visible :(
kurtz le pirate
Download 'aat.low.jpeg.jpg' (75 KB) Download 'fish.low.jpeg.jpg' (80 KB) Download 'lamp.low.jpeg.jpg' (65 KB)
Preview of image 'aat.low.jpeg.jpg'
Preview of image 'fish.low.jpeg.jpg'
Preview of image 'lamp.low.jpeg.jpg'
Date: 11 Sep 2025 14:30:00
Message: <web.68c31440a068c28c17bac71e8ffb8ce3@news.povray.org>
A quicky in Nim, not much tested:
#asciistl2pov.nim
import std/[math, sequtils, strformat, strutils]
type
  Vec3 = array[3, float]
  Face = array[3, int]
proc vec3(x,y,z: float): Vec3 = [x,y,z]
proc `+`(a,b: Vec3): Vec3 = [a[0]+b[0], a[1]+b[1], a[2]+b[2]]
proc `/`(a: Vec3, s: float): Vec3 = [a[0]/s, a[1]/s, a[2]/s]
proc dot(a,b: Vec3): float = a[0]*b[0]+a[1]*b[1]+a[2]*b[2]
proc length(v: Vec3): float = sqrt(dot(v,v))
proc normalize(v: Vec3): Vec3 =
  let l = length(v)
  if l > 1e-9: v / l else: vec3(0,1,0)
# Load STL, ASCII only
proc loadSTL(path: string): (seq[Vec3], seq[Face], seq[Vec3]) =
  var verts: seq[Vec3] = @[]
  var faces: seq[Face] = @[]
  var norms: seq[Vec3] = @[]
  var curVerts: seq[int] = @[]
  var curNormal = vec3(0,0,0)
  for line in lines(path):
    let l = line.strip()
    if l.startsWith("facet normal"):
      let p = l.splitWhitespace()
      curNormal = vec3(p[2].parseFloat, p[3].parseFloat, p[4].parseFloat)
    elif l.startsWith("vertex"):
      let v = vec3(p[1].parseFloat, p[2].parseFloat, p[3].parseFloat)
      verts.add(v)
      curVerts.add(verts.len-1)
    elif l.startsWith("endfacet"):
      if curVerts.len == 3:
        faces.add([curVerts[0], curVerts[1], curVerts[2]])
        norms.add(curNormal)
      curVerts.setLen(0)
  return (verts, faces, norms)
proc vertexToFaces(faces: seq[Face], vertexCount: int): seq[seq[int]] =
  result = newSeqWith(vertexCount, newSeq[int]())
  for fIdx, f in faces:
    for vi in f:
      result[vi].add(fIdx)
proc computeVertexNormals(
  vertexCount: int, faceNormals: seq[Vec3], v2f: seq[seq[int]]
): seq[Vec3] =
  result = newSeqWith(vertexCount, vec3(0,0,0))
  for vIdx in 0..<vertexCount:
    var accum = vec3(0,0,0)
    for fIdx in v2f[vIdx]:
      accum = accum + faceNormals[fIdx]
    result[vIdx] = normalize(accum)
proc mesh2ToString(
  verts: seq[Vec3], faces: seq[Face], normals: seq[Vec3]
): string =
  var sb = newStringOfCap(verts.len * 100) # Preallocate rough size
  sb.add("#declare MSH = mesh2 {\n")
  # Vertex vectors
  sb.add("  vertex_vectors {\n")
  sb.add("    " & $verts.len & ",\n")
  for v in verts:
    sb.add(&"    <{v[0]}, {v[1]}, {v[2]}>,\n")
  sb.add("  }\n")
  # Normal vectors
  sb.add("  normal_vectors {\n")
  sb.add("    " & $normals.len & ",\n")
  for n in normals:
    sb.add(&"    <{n[0]}, {n[1]}, {n[2]}>,\n")
  sb.add("  }\n")
  # Face indices
  sb.add("  face_indices {\n")
  sb.add("    " & $faces.len & ",\n")
  for f in faces:
    sb.add(&"    <{f[0]}, {f[1]}, {f[2]}>,\n")
  sb.add("  }\n")
  sb.add("}\n")
  result = sb
proc writeMesh2(outPath: string, verts: seq[Vec3], faces: seq[Face], normals:
seq[Vec3]) =
  let s = mesh2ToString(verts, faces, normals)
  writeFile(outPath, s)
when isMainModule:
  let (verts, faces, faceNorms) = loadSTL("mesh_output.stl")
  let v2f = vertexToFaces(faces, verts.len)
  let vertexNorms = computeVertexNormals(verts.len, faceNorms, v2f)
  writeMesh2("model.inc", verts, faces, vertexNorms)
  echo "Converted STL to POV-Ray mesh2 with normals."
ingo
Date: 12 Sep 2025 13:07:20
Message: <68c45348@news.povray.org>
> [snip]
> ingo
I don't know Nim very well, but the code is interesting.
Even Yoda agrees ;)
kurtz le pirate
Download 'test_yoda.jpeg.jpg' (233 KB)
Preview of image 'test_yoda.jpeg.jpg'
Date: 12 Sep 2025 14:10:00
Message: <web.68c46188a068c28c17bac71e8ffb8ce3@news.povray.org>
> Even Yoda agrees ;)
Hahaha. Well, for Yoda then, one that reads binary stl, rather untested again,
import std/[streams,math, sequtils, strformat]
type
  let l = length(v)
proc readVec3(s: Stream): Vec3 =
  result[0] = s.readFloat32()
  result[1] = s.readFloat32()
  result[2] = s.readFloat32()
proc loadBinarySTL(path: string): (seq[Vec3], seq[Face], seq[Vec3]) =
  ## Parse binary STL, returning vertices, faces, and per-face normals
  var f = newFileStream(path, fmRead)
  defer: f.close()
  discard f.readStr(80)           # skip header
  let triCount = f.readUint32()
  var faceNorms: seq[Vec3] = @[]
  for i in 0..<int(triCount):
    let n = readVec3(f)           # face normal
    let v1 = readVec3(f)
    let v2 = readVec3(f)
    let v3 = readVec3(f)
    discard f.readUint16()        # attribute byte count
    let base = verts.len
    verts.add(v1)
    verts.add(v2)
    verts.add(v3)
    faces.add([base, base+1, base+2])
    faceNorms.add(normalize(n))
  return (verts, faces, faceNorms)
# adjecent vertises
  for fi, f in faces:
    for vi in f:
      result[vi].add(fi)
# Vertex normals by averaging face normals
proc computeVertexNormals(vertexCount: int, faceNormals: seq[Vec3], v2f:
seq[seq[int]]): seq[Vec3] =
  for vi in 0..<vertexCount:
    for fi in v2f[vi]:
      accum = accum + faceNormals[fi]
    result[vi] = normalize(accum)
proc mesh2ToString(verts: seq[Vec3], faces: seq[Face], normals: seq[Vec3]):
string =
  sb.add("mesh2 {\n")
  for v in verts: sb.add(&"    <{v[0]}, {v[1]}, {v[2]}>,\n")
  sb.add("  }\n")
  for n in normals: sb.add(&"    <{n[0]}, {n[1]}, {n[2]}>,\n")
  sb.add("  }\n")
  for f in faces: sb.add(&"    <{f[0]}, {f[1]}, {f[2]}>,\n")
  sb.add("  }\n")
  sb.add("}\n")
  result = sb
proc writeMesh2(path: string, verts: seq[Vec3], faces: seq[Face], normals:
seq[Vec3]) =
  writeFile(path, mesh2ToString(verts, faces, normals))
when isMainModule:
  let (verts, faces, faceNorms) = loadBinarySTL("model.stl")
  echo "Binary STL converted to POV-Ray mesh2."
They realy should have/get a decent command line interface...
ingo
Date: 15 Sep 2025 10:35:00
Message: <web.68c82368a068c28c6ddd22546cde94f1@news.povray.org>
hi,
thanks, it helped me to find a bug; two, if I count your code </grin>.
according to the Wikipedia page, "An ASCII STL file begins with the line:
solid name
where name is an optional string (though if name is omitted there must still be
a space after solid, for compatibility with some software).
<en.wikipedia.org/wiki/STL_(file_format)>
my code got tripped up by the missing space in the data.
regards, jr.
Date: 16 Sep 2025 05:11:28
Message: <68c929c0$1@news.povray.org>
Glad to be of help.
I gather that you speak Perl too ?
I feel less lonely...
kurtz le pirate
