"ingo" <nomail@nomail> wrote:
> for the current POV-Ray situation, I'm mostly writing my own little tools "that
> do things" and then call POV-Ray on the generated scene. The opposite of POV-Ray
> should be able to do it "all". Although I would like the latter,
> ingo
Well, given "the current POV-Ray situation", I'm trying to break out of that,
since "what is tolerated is what will continue".
I suppose I have a Persistence of Vision. ;)
I'm not exclusionarily averse to things like macros and separate utilities,
however, it would be highly desireable to in some way integrate those things
into the POV-Ray "package".
An official repository on the website, a folder in the official distro, scripts
to run whatever conversion or creation needs to be done, or most preferable -
the inclusion of an additional module in the source.
I'm especially pushing for this stl module, since it appears so straightforward
a task (for a c++ programmer), and the availability of millions of free stl
files available. We don't have a modeler - but there are models.
And it there are modelers available to make/edit stls.....
- BW
"Bald Eagle" <cre### [at] netscape net> wrote:
> #declare MyObject = mesh2 {stl "MyObject.stl" make_arrays ...}
#declare MyStlObject = mesh2{stl "MyObject.stl"}
#declare MyObjObject = mesh2{obj "MyObject.obj"}
that's quite elegant, to extract from a file format, what POV-Ray understands
based on mesh2.
I'd separate extracting array into something like:
mesh2array(mySTLObject, verticesname, normalsname, facesname, uvname,
vertexcoulours etc..)
could result in a bunch of arrays declared with the given names. It should take
mesh & mesh2.
and/or
mesharrays{obj "MyObjObject.obj"} and extract everything the file supports into
arrays, even what's not understood by mesh2, like boning, face normals or non
triangle faces.
ingo
On 09/09/2025 02:32, Bald Eagle wrote:
> ........... what's that?!!!
> He provides not one but TWO .stl files . . .
Blender can import STL and export POV.
YB
On 10/09/2025 17:11, kurtz le pirate wrote:
> The wiki page shows that the structure is very simple, and I think Perl*
> is a very good candidate for this.
Finally, I spent an hour and here is my first result ;)
I found this template on the web :
<https://www.thingiverse.com/thing:7119375>. The downloaded STL file is
in binary mode. I converted it to ASCII on this website :
<https://3dcustomizer.net/tests/stl-bin-to-ascii.html>
Here is the first image to compare with the one on Thingiverse.
I also added an archive that contains :
* Stackable_crate_gridfinity-ascii.stl : the ascii stl file
* stl2pov.pl : the perl script
* Stackable_crate_gridfinity-ascii.inc : the mesh{} include file
generated by the script
* test.pov : demo scene
* test.png : the image
Of course, there are quite a few things to add such as binary format,
normals & mesh2{}, colors, etc.
kurtz le pirate
compagnie de la banquise
Download 'test.png' (376 KB)
Download 'stl2pov.tar.gz' (1239 KB)
Preview of image 'test.png'
Three more attempts always from Thingiverse.
The lack of normals is clearly visible :(
kurtz le pirate
Download 'aat.low.jpeg.jpg' (75 KB)
Download 'fish.low.jpeg.jpg' (80 KB)
Download 'lamp.low.jpeg.jpg' (65 KB)
Preview of image 'aat.low.jpeg.jpg'
Preview of image 'fish.low.jpeg.jpg'
Preview of image 'lamp.low.jpeg.jpg'
A quicky in Nim, not much tested:
#asciistl2pov.nim
import std/[math, sequtils, strformat, strutils]
type
Vec3 = array[3, float]
Face = array[3, int]
proc vec3(x,y,z: float): Vec3 = [x,y,z]
proc `+`(a,b: Vec3): Vec3 = [a[0]+b[0], a[1]+b[1], a[2]+b[2]]
proc `/`(a: Vec3, s: float): Vec3 = [a[0]/s, a[1]/s, a[2]/s]
proc dot(a,b: Vec3): float = a[0]*b[0]+a[1]*b[1]+a[2]*b[2]
proc length(v: Vec3): float = sqrt(dot(v,v))
proc normalize(v: Vec3): Vec3 =
let l = length(v)
if l > 1e-9: v / l else: vec3(0,1,0)
# Load STL, ASCII only
proc loadSTL(path: string): (seq[Vec3], seq[Face], seq[Vec3]) =
var verts: seq[Vec3] = @[]
var faces: seq[Face] = @[]
var norms: seq[Vec3] = @[]
var curVerts: seq[int] = @[]
var curNormal = vec3(0,0,0)
for line in lines(path):
let l = line.strip()
if l.startsWith("facet normal"):
let p = l.splitWhitespace()
curNormal = vec3(p[2].parseFloat, p[3].parseFloat, p[4].parseFloat)
elif l.startsWith("vertex"):
let v = vec3(p[1].parseFloat, p[2].parseFloat, p[3].parseFloat)
verts.add(v)
curVerts.add(verts.len-1)
elif l.startsWith("endfacet"):
if curVerts.len == 3:
faces.add([curVerts[0], curVerts[1], curVerts[2]])
norms.add(curNormal)
curVerts.setLen(0)
return (verts, faces, norms)
proc vertexToFaces(faces: seq[Face], vertexCount: int): seq[seq[int]] =
result = newSeqWith(vertexCount, newSeq[int]())
for fIdx, f in faces:
for vi in f:
result[vi].add(fIdx)
proc computeVertexNormals(
vertexCount: int, faceNormals: seq[Vec3], v2f: seq[seq[int]]
): seq[Vec3] =
result = newSeqWith(vertexCount, vec3(0,0,0))
for vIdx in 0..<vertexCount:
var accum = vec3(0,0,0)
for fIdx in v2f[vIdx]:
accum = accum + faceNormals[fIdx]
result[vIdx] = normalize(accum)
proc mesh2ToString(
verts: seq[Vec3], faces: seq[Face], normals: seq[Vec3]
): string =
var sb = newStringOfCap(verts.len * 100) # Preallocate rough size
sb.add("#declare MSH = mesh2 {\n")
# Vertex vectors
sb.add(" vertex_vectors {\n")
sb.add(" " & $verts.len & ",\n")
for v in verts:
sb.add(&" <{v[0]}, {v[1]}, {v[2]}>,\n")
sb.add(" }\n")
# Normal vectors
sb.add(" normal_vectors {\n")
sb.add(" " & $normals.len & ",\n")
for n in normals:
sb.add(&" <{n[0]}, {n[1]}, {n[2]}>,\n")
sb.add(" }\n")
# Face indices
sb.add(" face_indices {\n")
sb.add(" " & $faces.len & ",\n")
for f in faces:
sb.add(&" <{f[0]}, {f[1]}, {f[2]}>,\n")
sb.add(" }\n")
sb.add("}\n")
result = sb
proc writeMesh2(outPath: string, verts: seq[Vec3], faces: seq[Face], normals:
seq[Vec3]) =
let s = mesh2ToString(verts, faces, normals)
writeFile(outPath, s)
when isMainModule:
let (verts, faces, faceNorms) = loadSTL("mesh_output.stl")
let v2f = vertexToFaces(faces, verts.len)
let vertexNorms = computeVertexNormals(verts.len, faceNorms, v2f)
writeMesh2("model.inc", verts, faces, vertexNorms)
echo "Converted STL to POV-Ray mesh2 with normals."
ingo
> [snip]
> ingo
I don't know Nim very well, but the code is interesting.
Even Yoda agrees ;)
kurtz le pirate
Download 'test_yoda.jpeg.jpg' (233 KB)
Preview of image 'test_yoda.jpeg.jpg'
> Even Yoda agrees ;)
Hahaha. Well, for Yoda then, one that reads binary stl, rather untested again,
import std/[streams,math, sequtils, strformat]
type
let l = length(v)
proc readVec3(s: Stream): Vec3 =
result[0] = s.readFloat32()
result[1] = s.readFloat32()
result[2] = s.readFloat32()
proc loadBinarySTL(path: string): (seq[Vec3], seq[Face], seq[Vec3]) =
## Parse binary STL, returning vertices, faces, and per-face normals
var f = newFileStream(path, fmRead)
defer: f.close()
discard f.readStr(80) # skip header
let triCount = f.readUint32()
var faceNorms: seq[Vec3] = @[]
for i in 0..<int(triCount):
let n = readVec3(f) # face normal
let v1 = readVec3(f)
let v2 = readVec3(f)
let v3 = readVec3(f)
discard f.readUint16() # attribute byte count
let base = verts.len
verts.add(v1)
verts.add(v2)
verts.add(v3)
faces.add([base, base+1, base+2])
faceNorms.add(normalize(n))
return (verts, faces, faceNorms)
# adjecent vertises
for fi, f in faces:
for vi in f:
result[vi].add(fi)
# Vertex normals by averaging face normals
proc computeVertexNormals(vertexCount: int, faceNormals: seq[Vec3], v2f:
seq[seq[int]]): seq[Vec3] =
for vi in 0..<vertexCount:
for fi in v2f[vi]:
accum = accum + faceNormals[fi]
result[vi] = normalize(accum)
proc mesh2ToString(verts: seq[Vec3], faces: seq[Face], normals: seq[Vec3]):
string =
sb.add("mesh2 {\n")
for v in verts: sb.add(&" <{v[0]}, {v[1]}, {v[2]}>,\n")
sb.add(" }\n")
for n in normals: sb.add(&" <{n[0]}, {n[1]}, {n[2]}>,\n")
sb.add(" }\n")
for f in faces: sb.add(&" <{f[0]}, {f[1]}, {f[2]}>,\n")
sb.add(" }\n")
sb.add("}\n")
result = sb
proc writeMesh2(path: string, verts: seq[Vec3], faces: seq[Face], normals:
seq[Vec3]) =
writeFile(path, mesh2ToString(verts, faces, normals))
when isMainModule:
let (verts, faces, faceNorms) = loadBinarySTL("model.stl")
echo "Binary STL converted to POV-Ray mesh2."
They realy should have/get a decent command line interface...
ingo
hi,
thanks, it helped me to find a bug; two, if I count your code </grin>.
according to the Wikipedia page, "An ASCII STL file begins with the line:
solid name
where name is an optional string (though if name is omitted there must still be
a space after solid, for compatibility with some software).
<en.wikipedia.org/wiki/STL_(file_format)>
my code got tripped up by the missing space in the data.
regards, jr.
