POV-Ray : Newsgroups : povray.general : splines-- unexpected comma requirement Server Time
15 Sep 2025 13:13:55 EDT (-0400)
  splines-- unexpected comma requirement (Message 1 to 10 of 10)
Subject: splines-- unexpected comma requirement
Date: 28 Apr 2025 09:55:00
Message: <web.680f84e59120142be83955656e066e29@news.povray.org>
[running Windows 10]
(This might be old news?)
I was playing with splines recently, and came across a strange quirk when using
negative 'index' or parameter values for some of the points: Apparently, a comma
separator is needed after those points (otherwise a fatal error when the spline
is parsed), whereas positive-parameter points need no commas. This occurs in
both v3.7.0 and 3.8 beta 1. (As far as I know, there is no caveat or restriction
about creating points with negative index values.) The type of spline used--
linear, cubic etc-- has no effect on this behavior.
The documentation at "3.3.1.11 Spline" is somewhat unclear as to a *requirement*
for commas between separate points:
"The first item gives the type of interpolation [linear, cubic, etc]...
Following this are a number of float values each followed by a position vector,
all separated by commas." But the spline example there uses no comma separators,
and my own experience is that that are usually not needed.
With negative-index points, there appears to be a pattern(?) to the behavior.
Some examples:
This spline has only ONE negative-index point-- and parses OK as-is; no commas
between the points are needed:
#declare MY_SP_1 =
spline{
     natural_spline
    -0.3, < .3, .6, .5 >
     0, < -.52, -.36, -.59>
     0.5, < -1.0, .27, .68>,
     1.0, < .6, -.95, -.15>
     2.0, < -.75, -.52, -1.5>
     2.7, <.3,.5,2>
This has TWO negative index points-- a comma is required after
the FIRST point only:
#declare MY_SP_2 =
spline{
     linear_spline
    -0.45, <.1,.3,-.1>,
     2.7, <.3,.5,2>
This one has TWO negative index points at the beginning (as above), plus
another one later-- a comma is required  after the FIRST point and another
*before* the later negative-index.
#declare MY_SP_3 =
spline{
     cubic_spline
   -0.45, <.1,.3,-.1>,
    0.5, < -1.0, .27, .68>, // comma needed here, preceding the next
                            // negative index
   -1.0, < .6, -.95, -.15>
    2.7, <.3,.5,2>
This one has THREE negative index points-- commas are required after the FIRST
and SECOND points:
#declare MY_SP_4 =
spline{
     cubic_spline
    -0.6, <.2,.1,.3>,
    -0.45, <.1,.3,-.1>,
     2.7, <.3,.5,2>
Subject: Re: splines-- unexpected comma requirement
Date: 28 Apr 2025 10:00:00
Message: <web.680f89cfd1e0268ab00a87a025979125@news.povray.org>
Because the parser has no idea if you're making another point, or subtracting a
"vector-elevated" scalar value from the preceding vector.
<1, 1, 1> - 0.25 = <1, 1, 1> - <0.25, 0.25, 0.25> = <0.75, 0.75 0.75>
- BW
Date: 28 Apr 2025 10:15:00
Message: <web.680f8c59d1e0268ae83955656e066e29@news.povray.org>
> - BW
Hmmm, that does make sense once it's dissected. But should the parser be 'fixed'
somehow, to eliminate this (seemingly) strange behavior? (i.e., unexpected
behavior from a typical user's standpoint?) One problem is with the rather
generic and misleading parse-error statement when the commas are left out:
"Parse error: No matching } , < found instead." Huh??
Date: 28 Apr 2025 10:35:00
Message: <web.680f914cd1e0268ae83955656e066e29@news.povray.org>
The easier solution would be to re-word the spline documentation, to make it
more consistent: The example there should have commas after each spline point
(whether or not they are actually needed); or, a caveat should be added about
negative-index points. Something like:
"While there is no restriction on using negative-parameter values for spline
points, be aware that the parser will have trouble distinguishing one such point
from another"-- using your dissected example to show why. :-)
Date: 28 Apr 2025 11:55:00
Message: <web.680fa3b6d1e0268ab00a87a025979125@news.povray.org>
It's not misleading at all.
You're just not following through with my explanation and seeing what the
inevitable result is once the parser does the subtraction.
It's now expecting a new scalar value along the spline, and instead, you're
providing it with a vector value.
- BW
Date: 28 Apr 2025 12:20:00
Message: <web.680faa28d1e0268a721a48e56cde94f1@news.povray.org>
hi,
> The easier solution would be ...
(in my opinion) for users to not take advantage of a "lax" parser.  if you have
a list, then well, comma-separate the items (you're not a lawyer, are you ?
</grin>).  where you '#declare', even if the statement parses without the
semicolon, be consistent and write one anyway.  "help" the parser rather than
making it work harder ;-).
($0.02 and all that)
regards, jr.
Date: 28 Apr 2025 12:30:00
Message: <web.680fabe8d1e0268ab00a87a025979125@news.povray.org>
Betterer practice I think would be to just dump it all into a mixed array, (or
array of arrays), and then use a loop to define the spline.
Single-use containers are wasteful and annoying.
Best would be if we could use arrays as actual matrices - because I'm sure some
interesting things could be done with neat matrix magic tricks.
- BW
Date: 28 Apr 2025 12:39:05
Message: <680faf29$1@news.povray.org>
I can only add to this that following strict pattern definitely
simplifies things for *my* built-in parser ;-)
OT: it reminds me how I wrote a PPM and PGM image format module in
Python. Since PNM specs are rather fluid, everybody seem to follow their
own header scheme, so I gave up thinking normally and started mangling
're' regexp pattern until it started to consider anything but image data
as image header ;-)
Ilyich the Toad
https://dnyarri.github.io/
Date: 28 Apr 2025 17:50:00
Message: <web.680ff6d8d1e0268ae83955656e066e29@news.povray.org>
Yes, I see that-- and the message does make sense...but only *after* the
parser's particular behavior with the negative-index points has been explained
;-) Prior to that, it's a mystery message. And the spline docs are completely
silent about what to expect, unfortunately.
But I agree with several others here, that it's simply better practice to use
commas after every entry-- and to ignore the docs' comma-less example.
Date: 11 May 2025 02:45:00
Message: <web.6820472ed1e0268a721a48e56cde94f1@news.povray.org>
hi,
> (whether or not they are actually needed); ...
agree.  the example has been updated to remove the ambiguity.  thanks.
regards, jr.
