POV-Ray : Newsgroups : povray.general : A little help about old vers. Server Time
16 Jul 2025 18:20:09 EDT (-0400)
  A little help about old vers. (Message 8 to 17 of 97)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: A little help about old vers.
Date: 25 Apr 2025 06:45:46
Message: <680b67da$1@news.povray.org>
Le 2025-04-23 à 10:33, Bald Eagle a écrit :
> "GioSeregni" <gms### [at] hotmailcom> wrote:
>> DEF GOLDDARK Material {diffuseColor 0.81 0.71 0.23 ambientIntensity 0.5
>> specularColor 1 1 1 shininess 1}
> my guess:
> #declare GOLDDARK = material {texture { pigment {rgb <0.81, 0.71, 0.23>} finish
> {ambient 0.5 specular 1} } }
> I would probably replace ambient with diffuse, and drastically decrease
> specular, or at least keep diffuse + specular < 1.
> - BW
It's diffuse + ambient that should be kept under 1.
So :
finish
{diffuse 0.5 ambient 0.5 specular 1} } }
Normally, ambient should be kept under 0.2. As it's a metal, it's better
to set it at zero. So, my suggestion will be :
finish
{diffuse 0.7 ambient 0 specular 1 metallic} } }
Or :
finish
{diffuse 0.5 ambient 0 specular 1 metallic reflection{ 0.7 metallic} } } }
Date: 25 Apr 2025 07:17:18
Message: <680b6f3e$1@news.povray.org>
Le 2025-04-23 à 10:01, GioSeregni a écrit :
> Hi all,
> I am sorry.
> I don't understand the complex explanation of some changes made after version
> 2.x, but I'm "reverting" some of my files.
> I would appreciate if someone could translate these instructions because my old
> compiler got from the CAD layer name and wrote something like this, which is now
> not valid.
My take.
#declare GOLDDARK = material{
	pigment{rgb<0.81, 0.71, 0.23>}
	finish{diffuse 0.5 ambient 0 specular 1 metallic roughness 0.01
		reflection{0.6 metallic}
	}// This is a metal.
The metallic key word cause the highlight and reflection to take the
colour of the surface.
Need an environment to show in the reflection.
> DEF POLIBLUE Material {emissiveColor 0 0 0 diffuseColor 0.05 0 0.50
> ambientIntensity 0.4 specularColor 0.8 0.8 0.8 shininess 0.625}
#declare POLIBLUE = material{
	pigment{rgb<0.05, 0, 0.5>}
	finish{diffuse 0.7 ambient 0.1  specular 0.8 roughness 0.375}
	// That's a rather dull surface.
Make roughness smaller to make the highlight tighter.
> DEF DEMIRED   Material {ambientIntensity 0.4 diffuseColor 0.6 0.1 0.1
> specularColor 0.6 0.1 0.1 shininess 0.8 transparency 0.3}
#declare DEMIRED = material{
	pigment{rgbt<1, 0.8, 0.8, 0.6>}//transparent pigment.
	finish{diffuse 0.5 ambient 0 specular 0.8 fresnel roughness 0.1
		reflection{ 1 fresnel}
	interior{ior 1.5// required for fresnel to work
	dispersion 1.02// blue refract more than red by that amount
	fade_color rgb<0.6, 0.1, 0.1>//Actual colour
	fade_distance 0.1//Define how the thickness affect the colour
	fade_power 1001 //a standard value
That's a transparent material. Made it have a colour that depends on the
thickness. Adjust fade_distance as needed. fade_distance depends on the
scale of your scene.
Need an IOR for the fresnel reflection to work. Will show refraction.
Fresnel highlight and reflection are minimal when the surface is viewed
perpendicularly and maximum at grazing angles.
Need an environment to show in the transparency and the effect of
refraction.
> Thanks in advanced!
> G.
Date: 26 Apr 2025 08:20:00
Message: <web.680ccdc7ce24a8bb7e2ea33059126100@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> > Hi all,
> > I am sorry.
> > not valid.
> My take.
> refraction.
> > Thanks in advanced!
> > G.
Thanks!
but sorry, "material" is exactly my trouble. I used it in the far 2002, but now,
it is
not anymore working for me
So, if I use your suggestion for declare
I get:
Parse Error: No matching } in 'material', pigment found instead
Render failed
Date: 26 Apr 2025 09:15:00
Message: <web.680cdbd9ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> I get:
> Render failed
POV-Ray is looking for a 'texture{}' to wrap the pigment and finish, see:
<https://wiki.povray.org/content/Reference:Material>.  hth.
regards, jr.
Date: 26 Apr 2025 10:10:00
Message: <web.680ce921ce24a8bb7e2ea33059126100@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > I get:
> > Render failed
> regards, jr.
Yes, this is exactly the page by me indicated previously, if you see the whole
topic.
This page is very confusing to me.
I would like to find a way to update the old definitions as faithfully as
possible.
This "material" way is a suggestion I had, but I already knew it didn't work.
Thanks!
Date: 26 Apr 2025 10:25:00
Message: <web.680ceb9fce24a8bb1f9dae3025979125@news.povray.org>
> topic.
> possible.
> Thanks!
What happened is that texture used to have interior as part of it.
Then interiors became it's own thing - separate from texture.
So to apply both to an object, you need to put them in a material {} statement.
material {} does accept a pigment {} statement directly.
So just do
material {
     texture {pigment {}}
and that will work.
- BW
Message: <web.680cec47ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> > POV-Ray is looking for a 'texture{}' to wrap the pigment and finish,...
> topic.
> possible.
> Thanks!
the code below runs for me using a beta.2.  hth.
regards, jr.
-----<snip>-----
#version 3.8;
global_settings {assumed_gamma 1}
#declare mat_ = material {
      color rgb <.81, .71, .23>
    finish {
      diffuse .5
      ambient 0
      specular 1
      roughness .01
      reflection {.6 metallic}
      metallic
  /* put an interior here */
box {
 0,1
 material {mat_}
light_source {<-1,1,-1>*1e3 color rgb 1 parallel}
  location <0,0,-5>
  right x * (4/3)
  up y
  look_at <0,0,0>
Date: 26 Apr 2025 13:25:00
Message: <web.680d160bce24a8bb7e2ea33059126100@news.povray.org>
> hi,
> > topic.
> > possible.
> > Thanks!
> regards, jr.
> -----<snip>-----
> #version 3.8;
>   texture {
>     pigment {
>     finish {
>       diffuse .5
>       ambient 0
>       specular 1
>       roughness .01
>       metallic
> box {
>  0,1
>  material {mat_}
> camera {
>   location <0,0,-5>
>   right x * (4/3)
>   up y
>   look_at <0,0,0>
Many thanks!
I thought texture encapsulation was more complicated, now it works!
Date: 26 Apr 2025 14:00:00
Message: <web.680d1eb3ce24a8bb7e2ea33059126100@news.povray.org>
GREAT!
I restored the old declare!
Left = a car silver from my old render 2002 vers.2.??
Center = BAD !!! my attempt to restore the old code into vers 3.7
right = very well for me ! with your help
Many thanks to all!
PS. I don't have a great ability to render realistically. I dedicate myself to
geometry, code and projects, usually, but this for my needs is more than
satisfying!
Download 'clipboard01.png' (469 KB)
Preview of image 'clipboard01.png'
Date: 27 Apr 2025 02:30:00
Message: <web.680dce21ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> Many thanks!
excellent.
> to geometry, code and projects, usually, but this for my needs is more than
> satisfying!
nice models, a forecourt (like a car dealer) or a parking lot, just .. an
overview, would be v cool though (I suspect you've "a collection" :-)).
regards, jr.
