POV-Ray : Newsgroups : povray.general : A little help about old vers. Server Time
11 Mar 2026 10:14:33 EDT (-0400)
  A little help about old vers. (Message 61 to 70 of 97)
Subject: Re: A little help about old vers.
Date: 12 Jun 2025 13:15:00
Message: <web.684b09efce24a8bb3ecaab5e6cde94f1@news.povray.org>
hi.
"GioSeregni" <gms### [at] hotmailcom> wrote:
> > I am going to update! ...
> Done!
> The new file is INC
thanks.  a nice car.  one (minor) gripe - the mesh resolution is very/too low, I
see "corners" even with the 'smooth_triangle's; attached.
regards, jr.
Download 'gs_not_smooth.png' (282 KB)
Preview of image 'gs_not_smooth.png'
Date: 12 Jun 2025 15:10:00
Message: <web.684b2503ce24a8bbc3bb525659126100@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi.
> > Done!
> > The new file is INC
> regards, jr.
yes, I know, I use these objects to complete architectural landscapes and
usually I try to keep them light and fast. This one, however, as I wrote, was a
simple
conversion test by my tools of a web file by Sketchup, I didn't do anything
except eliminating wrong faces with zero area ... it is a small file
BR !
G.
Message: <web.684b25dece24a8bbc3bb525659126100@news.povray.org>
Even the finish is just basic, wanting to perfect it
Date: 12 Jun 2025 15:30:00
Message: <web.684b2a64ce24a8bbc3bb525659126100@news.povray.org>
Maybe I tell you things you know, but if you want to improve the mesh, which is
clean (and it's an advantage) you can use MeshLab, without going crazy by hand.
It has many remesh options, most of the time unsuccessful, some options can
work...
Mesh step Mesh otherwise you lose the colors
Download 'clipboard02.png' (121 KB)
Preview of image 'clipboard02.png'
Date: 12 Jun 2025 15:55:00
Message: <web.684b2fbdce24a8bb650a7a8430225ff5@news.povray.org>
I like the cars, and so do the people. My expectation was not that I would be
able to zoom in properly. For reasonable scenes, you simply need many different
models, and the BMW in particular does really well.
The BMW, is that the final version?
I wanted to work on it somewhen in the next few days, split the meshes, change
Color and so on. This costs several hours, and I would not like to do it several
times for the same model.
Unfortunately, I don't know how to model, so I don't have any mesh products to
show. For me, everything consists of cylinders, boxes, spheres, with very lousy
textures around them.
We have to be that honest.
But my programming works fantastically ;)
Greetings, and I hope for more Cars and Persons.
Ma
Date: 12 Jun 2025 17:15:00
Message: <web.684b4280ce24a8bbc3bb525659126100@news.povray.org>
> Ma
Yes, you are right, it is a final version, because I have other cars and people
that I want to improve, and the BMW, although simple, is clean. Tomorrow I will
try to see if I can increase the polygons while maintaining the colors, in a few
automatic steps ... but I cannot guarantee, many transformations must be
crossed. I will let you know soon.
BR!
G.
Date: 13 Jun 2025 06:20:00
Message: <web.684bfaf0ce24a8bbc3bb525659126100@news.povray.org>
Unfortunately as I feared I tried with MeshLab to increase the resolution, but
it introduces errors.
As I thought it loses the border between the colors and also inverts (!!) some
faces.
This is the reason why I always work with my tools. I have an idea, in the next
few days I will implement a new feature. It takes the object and extracts the
files divided by color. In this way you can improve the parts that need it and
then it is easy to join them!
See you soon!
G.
Download 'clipboard01.png' (178 KB)
Preview of image 'clipboard01.png'
Date: 13 Jun 2025 07:55:00
Message: <web.684c113fce24a8bb3ecaab5e6cde94f1@news.povray.org>
hi,
> faces.
I just had a look at what installing MeshLab would entail, but the above changed
my mind :-).
still, it's true when you write "...but if you want to improve the mesh, which
is clean (and it's an advantage)...", therefore I suggest:
if you can export a mesh to a GNU/GTS, that library has loads of tools to work
with clean (and not so clean :-)) meshes.
and this is where I cannot "follow", why "by color" ?  why not "by component",
and leave texture/colourising for when the object is used ?
regards, jr.
Date: 14 Jun 2025 04:38:57
Message: <684d3521$1@news.povray.org>
> faces.
> See you soon!
> G.
Have a look at this page :
<https://www.geocities.ws/evilsnack/c2s3.html>
A Catmull-Clark Surface Subdivision Suite macros.
This may help you
kurtz le pirate
compagnie de la banquise
Date: 14 Jun 2025 21:40:00
Message: <web.684e2383ce24a8bbc3bb525659126100@news.povray.org>
> > faces.
> > See you soon!
> > G.
> This may help you
> kurtz le pirate
unfortunately there is a redirect that leads to spam or worse!
