POV-Ray : Newsgroups : povray.general : How do I Rerun or Where is the Stop/Start Render? Server Time
13 May 2025 12:28:34 EDT (-0400)
  How do I Rerun or Where is the Stop/Start Render? (Message 1 to 10 of 14)
Subject: How do I Rerun or Where is the Stop/Start Render?
Date: 21 Feb 2025 16:20:00
Message: <web.67b8ed392c777d9bf9720c4baef99e11@news.povray.org>
Where is this located or how do I turn it on?:
"3.5.7.3 Start Rendering (Go!)/Stop Rendering
This is a toggle. If you are not currently rendering, the command Start
Rendering instructs POV-Ray for Windows to start rendering the currently loaded
POV file with the current settings. While POV-Ray for Windows is rendering, the
command reads Stop Rendering and will interrupt the current rendering job. You
can continue an interrupted rendering job by selecting 'Continue <filename>'
from the Rerun Menu."
Rendering a complex image on a cloud computer which will turn off after a while
if it gets no user input. I need to be able to stop, then start rendering.
Subject: Re: How do I Rerun or Where is the Stop/Start Render?
Date: 22 Feb 2025 08:57:00
Message: <67b9d7ac$1@news.povray.org>
Start the render with the «+c» flag added to the command line.
You may also add the «continue» parameter in the .ini file when you want
to continue an interrupted render.
Both will do the same thing : Resume the render where it got
stopped/interrupted.
Date: 23 Feb 2025 16:15:00
Message: <web.67bb8f735487c66efab484b3aef99e11@news.povray.org>
Are these settings different on Windows? I have no such menu. I do have
Continue_Trace=on in my povray.ini file and I have +C in the console bar.
Date: 23 Feb 2025 16:38:09
Message: <67bb9541$1@news.povray.org>
Look just at the top of the editor. You have the resolutions list, and,
just to the right, there is a box where you can write some text. That's
the command line box. You can put a «+c» to continue an interrupted
render there.
You can also use it to set the resolution, change the antialias options
and other things.
+w36000 +h1000 +a0.0001 +r4
Will result in an image that is 36000 pixels wide, 1000 pixels high, set
the antialias threshold to 0.0001 and use 4 levels of recursion.
Date: 23 Feb 2025 22:10:00
Message: <web.67bbe2335487c66ebd9b8a41aef99e11@news.povray.org>
> render there.
> and other things.
Thank you for the detailed explanation. However, I believe there might be a
misunderstanding. My current settings are '+W1280 +H720 +A0.05 +AM3 +HR +RVP +R5
+Q11 +FE +KI1 +KF36 +KFI38 +KFF73 +RS8 +BS4 +B +C'  I am inquiring about how and
why the settings or menu options differ on Windows.
There seems to be a disconnect between what is stated on in the codices official
and otherwise about options that are currently available in the windows build
GUI. If there is another place I can look for start/stop/restart of renders I
would greatly appreciate the direction.
Date: 24 Feb 2025 08:01:52
Message: <67bc6dc0$1@news.povray.org>
>> render there.
>> and other things.
It's in the box found here. Second box. The one containing the +a0.0001.
You can start a render from an *.ini file.
If you add : «continue»
alone on a line, then, when you start the render from that *ini file, it
will resume the rendering of the interrupted scene.
Download 'clipboard01.jpg' (37 KB)
Preview of image 'clipboard01.jpg'
Date: 24 Feb 2025 18:00:00
Message: <web.67bcf9d15487c66eb15a80fcaef99e11@news.povray.org>
loaded
the
while
> >> render there.
> >> and other things.
Again, I don't have any issue with putting the commands or what to do with the
input box, '+W3840 +H2160 +A0.05 +R5 +Q11 +FE +KI1 +KF36 +KFI38 +KFF73 +RS8 +BS4
+B +C' is what I'm currently using.
I can't get my render to restart where it left off, despite the proper settings
and a .ini file.
Rerun.ini:
//start
Antialias_Depth=5
Antialias=On
Antialias_Threshold=0.05
Bounding=On
Bounding_Threshold=3
Continue_Trace=On
Create_Ini="rerun.ini"
Display=On
Final_Clock=36
Final_Frame=73
Height=2160
Initial_Clock=1
Initial_Frame=38
Input_File_Name="D:\.art\WAP\marbles_dell_abstract_dark.pov"
Library_Path="C:\Users\Public\Documents\LDraw\LGEO"
Library_Path="C:\Users\Public\Documents\LDraw\LGEO\lg"
Library_Path="C:\Users\Public\Documents\LDraw\LGEO\ar"
Library_Path="C:\Users\Shadow\Documents\POV-Ray\v3.7\include"
Library_Path="C:\WINDOWS\Fonts"
Output_File_Type=E
Output_To_File=On
Quality=11
Render_Block_Size=4
Render_Block_Step=8
Verbose=On
Width=3840
Work_Threads=8
continue
//end
It starts with an image of the previous run, but it's just starting at 0% and
rendering over the last frame of the previous run, rather than starting where it
left off.
Download 'screenshot 2025-02-24 165736.png' (242 KB)
Preview of image 'screenshot 2025-02-24 165736.png'
Date: 25 Feb 2025 05:49:41
Message: <67bda045$1@news.povray.org>
On 2/24/25 17:59, 00face wrote:
> Work_Threads=8
> continue
> //end
> left off.
I've not been following this thread closely as I don't run on windows,
but that 'continue' string caught my eye. I assume this is really
pointing to a "continue.ini" file?
Did you create that file or is it some automatic windows interface thing?
What is in it?
Prior to trying to continue, do you see a state file with a .pov-state
suffix for the frame number for which you are trying to continue the
render? It will be in the directory where you are saving your frame images.
You must be running v3.7 as you don't have v3.8's
create_continue_trace_log= ?
I'll attach my current yuqk documentation for continue_trace= / +c. The
implementation is slightly different and I'm running on linux, but I
expect the issues one might see are often similar. Maybe something
therein a help.
Bill P.
Download 'continue_trace.txt' (5 KB)
Date: 27 Feb 2025 13:15:00
Message: <web.67c0aaf65487c66ebd9b8a41aef99e11@news.povray.org>
> > Work_Threads=8
> > continue
> > //end
> > left off.
> What is in it?
> therein a help.
> Bill P.
> > Work_Threads=8
> > continue
> > //end
> > left off.
> What is in it?
> therein a help.
> Bill P.
Thank you very much for taking the time. I have been reading the documents over
and over, some for UNIX some for LINUX, have not really seen anything
specifically for Windows, so it's been trial and error for what commands work.
That said Create_Ini=rerun.ini is what I am having created from povray.ini which
updates and is assisted by pvengine.ini. I would love to see you in the Discord
channel for POV-Ray on my server.
I am currently running my render AGAIN lol, so the rerun.ini below is the
current one generated. If my daily driver wasn't virtualized in the cloud, I
wouldn't be in this situation, this wouldn't be an issue. But here we are.
Do you recommend I use the beta 3.8 over 3.7. 🖖🏼 Again thanks
for your time so far.
//global settings from marbles_dell_abstract_photons.pov START
#version 3.7;
global_settings {
    assumed_gamma 1.0
    photons {
        count 100000          // Number of photons to shoot
        gather 20, 100        // Min/max photons to gather at each point
        jitter 0.4            // Jitter for sampling light rays
        max_trace_level 5     // Same as main trace level
        media 100, 1.5        // Enable media photons with max steps of 100
    radiosity {
        pretrace_start 0.002
        pretrace_end 0.001
        count 1600
        gray_threshold 0.5
        nearest_count 1
        error_bound 0.8
        recursion_limit 1
        minimum_reuse 0.015
        maximum_reuse 0.3
        brightness 1
    max_trace_level 5
    adc_bailout 0.01/255
//global settings from marbles_dell_abstract_photons.pov END
//povray.ini START
Width = 800
; Height of image in pixels.  Accepts integer values.
Height = 600
; Sets minimum number of objects before auto bounding kicks in.
; Turn display on
Display=On
; Turn verbose mode on
Verbose=On
; Continue Settings
Continue_Trace=on
Output_File_Type=N
All_Console=On
Verbose=on
Pause_When_Done=on
//povray.ini END
//rerun.ini START
All_Console=On
Antialias_Depth=1
Antialias=On
Antialias_Threshold=0.1
Continue_Trace=On
Display=On
Height=2160
Input_File_Name="D:\.art\WAP\marbles_dell_abstract_photons.pov"
Output_File_Type=E
Output_To_File=On
Pause_When_Done=On
Quality=11
Render_Pattern=2
Sampling_Method=2
Verbose=On
Width=3840
Work_Threads=8
//rerun.ini END
//pvengine.ini START
[Permitted Input Paths]
1=%INSTALLDIR%
2=%PROFILEDIR%
3=%FONTDIR%
4="C:\Program Files\LDraw (64 Bit)\LGEO"
5="C:\Program Files\LDraw (64 Bit)\LGEO\lg"
6="C:\Program Files\LDraw (64 Bit)\LGEO\ar"
[Permitted Output Paths]
1=%PROFILEDIR%\Insert Menu
[GUIExtensions]
UseExtensions=1
[Scripting]
ReadWriteSourceDir=1
NoShellOuts=1
[RTR]
VideoSource=
[Info]
Rendering=1
[General]
RunCount=3
CommandLine=+W3840 +H2160 +AM2 +A0.1 +R1 +Q11 +FE +RP2 +C
TextColour=16777215
WarningColour=65535
ErrorColour=16776960
BackgroundColour=4128799
DropToEditor=1
LastRenderName=marbles_dell_abstract_photons.pov
LastRenderPath=D:\.art\WAP\
LastQueuePath=C:\Users\Shadow\Documents\POV-Ray\v3.7\Scenes
SecondaryINISection=[480x270, 16:9 AA 0.3]
VersionNo64=3.7.0.msvc10.win64
LastBitmapPath=C:\Program Files\POV-Ray\v3.7\Tiles
LastINIPath=C:\USERS\SHADOW\DOCUMENTS\POV-RAY\V3.7\INI
SecondaryINIFile=C:\USERS\SHADOW\DOCUMENTS\POV-RAY\V3.7\INI\QUICKRES.INI
BackgroundFile=0
SaveSettingsOnExit=1
TileBackground=0
HideNewUserHelp=0
CheckNewVersion=1
SendSystemInfo=1
ItsAboutTime=1740849436
VersionNo32=3.7.0.msvc10.win32
[Editor]
LastPath=C:\Users\Shadow\Documents\POV-Ray\v3.7\Scenes\Advanced
[ToolBar]
Band0Width=543
Band1Width=200
Band2Width=200
Band3Width=180
Band4Width=405
[MainWindow]
ShowCmd=1
NormalPositionLeft=193
NormalPositionTop=0
NormalPositionRight=975
NormalPositionBottom=740
UseToolbar=1
UseTooltips=1
[RenderWindow]
NormalPositionX=478
NormalPositionY=73
Flags=536870912
Transparency=128
Use8BitMode=0
MakeActive=1
KeepAboveMain=1
HideWhenMainMinimized=1
AutoClose=0
PreserveBitmap=1
[Messages]
FontSize=8
FontWeight=400
Font=Lucida Console
KeepMessages=0
[Renderer]
AlertSound=64
Completion=2243
Priority=2305
DutyCycle=9
AlertOnCompletion=1
AutoRender=1
PreventSleep=1
NoShelloutWait=1
SystemNoActive=1
[Sounds]
RenderCompleteSoundEnabled=1
ParseErrorSoundEnabled=1
RenderErrorSoundEnabled=1
RenderCompleteSound=C:\Program Files\POV-Ray\v3.7\sounds\Render Finished.wav
ParseErrorSound=C:\Program Files\POV-Ray\v3.7\sounds\Parse Error.wav
RenderErrorSound=C:\Program Files\POV-Ray\v3.7\sounds\Render Cancelled.wav
[LastRender]
SceneFile=povray
CurrentDirectory=D:\.art\WAP
SourceFile=D:\.art\WAP\marbles_dell_abstract_photons.pov
OutputFile=
IniOutputFile=
[DontShowAgain]
RenderwinClose=1
OutputFileLocation=1
RenderErrorSound=1
ParserErrorSound=1
RenderCompleteSound=1
DropFiles=1
[FileQueue]
QueueCount=0
Output_File_Type=N
All_Console=On
Verbose=on
Pause_When_Done=on
Vista_Buffer=On
//pvengine.ini END
Date: 27 Feb 2025 16:58:04
Message: <67c0dfec$1@news.povray.org>
It happens I have a few minutes ahead of an appointment. I re-read the
entire thread - paying more attention and I see Alain suggested adding
that 'continue' string. In the linux/unix environment (and I expect
yours too) raw strings like this cause POV-Ray to look for a
'continue.ini' file.
My bet at this moment is that he is using 'Create_Ini=continue.ini' so
adding a raw 'continue' to the command line works for him(*).
Try adding, instead, the string 'rerun' the next time you try to resume
an interrupted render(*).
Aside: One of the things you mentioned was that you saw a complete last
frame in your preview window on coming back after an interruption due
some machine virtualization(**). If this is really true, it 'might' mean
POV-Ray was sent a signal that caused it to stop immediately after the
last frame was rendered - in which case it will have cleaned up the
state file. I'm unsure how the windows v3.7 version works in that case.
I believe linux/unix will see the image file and move on to the next
frame - but It's not something I've checked in a while.
(If v3.7 is otherwise working for you, I'd say stick with it. There are
differences in behavior along with a large collection of fixes, but if
you don't need the latter...)
Bill P.
(*) - FWIW. The documentation for my yuqk fork strongly discourages
specifying files without extensions unless you use 'include_ini=rerun'.
Rather than  a 'rerun' string use: 'rerun.ini'. I felt there was too
much potential for confusing things to happen given how aggressively
POV-Ray tries to find valid matching .ini files. (A new +-ini flag was
added to the yuqk fork too as the command line flag version to include
ini files explicitly)
(**) - One would hope the virtualization was orderly rather that
something which completely crashes or stops POV-Ray rather than pauses
it. Is the virtualization crashing POV-Ray or do you find it in a
stopped or paused state when you resume working?
