POV-Ray : Newsgroups : povray.general : polygon not visible Server Time
13 Jan 2026 14:12:51 EST (-0500)
  polygon not visible (Message 1 to 6 of 6)
Subject: polygon not visible
Date: 29 Nov 2024 18:25:00
Message: <web.674a4c31296bdfa2e3cbe740b3ec8729@news.povray.org>
I'm trying to render a simple script:
polygon { 5, <15.45085, 0, 47.55283>, <15.11321, -3.212412, 47.55283>,
<24.45369, -5.197792, 43.30127>, <25, 0, 43.30127>, <15.45085, 0, 47.55283>
texture { pigment { color rgb <1, 0, 0> } } }
sky_sphere { pigment { color rgb <1, 1, 1> } }
camera { look_at <15, -3, 47> location <0, 0, 100> }
light_source { <0, 0, 100> color rgb <1, 1, 1> }
The red polygon is not visible. Any ideas why?
Subject: Re: polygon not visible
Date: 29 Nov 2024 20:55:20
Message: <674a7088$1@news.povray.org>
On 11/29/24 18:20, folkert wrote:
> Hi,
The polygon is set up as a 2D object sitting in an x,y plane somewhere
along z.
The normal way to specify it is to use 2D vectors of <x,y> or <u,v>
values.
You can specify 3 coordinates, but the z values must all be the same. If
not, the parser is supposed to issue an error because the polygon code
won't work. However, it looks like that checking got dropped at some point.
I see this as a parser bug.
Bill P.
Date: 30 Nov 2024 04:05:00
Message: <web.674ad4ab665357ecad5190bdb3ec8729@news.povray.org>
> along z.
Ah ok!
Thanks for clarifying. Do you know if there's an other way of defining
polygon-alike structures in povray?
I'll submit an issue in github.
Date: 30 Nov 2024 05:05:00
Message: <web.674ae2b2665357ecb2e841a6cde94f1@news.povray.org>
hi,
> > along z.
> Ah ok!
POV-Ray does have (pretty decent) documentation, see eg:
<https://wiki.povray.org/content/Reference:Polygon>
<https://wiki.povray.org/content/Documentation:Contents>
hth.
regards, jr.
Date: 30 Nov 2024 05:10:00
Message: <web.674ae447665357ecad5190bdb3ec8729@news.povray.org>
> > > along z.
> > Ah ok!
That doesn't tell me how to go from a 3D polygon to something PovRay
understands.
But for now I triangulate my polygons and put them in a mesh2 object.
Date: 30 Nov 2024 05:50:00
Message: <web.674aed2c665357ecb2e841a6cde94f1@news.povray.org>
hi,
> > > > along z.
> > > Ah ok!
> > > Thanks for clarifying. ...
> understands.
"language barriers" :-)  polygon, the dictionary tells me:
1. (geometry) A plane figure bounded by edges that are all straight lines.
you, otoh, appear to be talking "polyhedron":
1. (geometry) A solid figure with many flat faces and straight edges.
mesh2 seems a good choice.
regards, jr.
