POV-Ray : Newsgroups : povray.general : Automatically named identifiers Server Time
29 Mar 2026 14:20:39 EDT (-0400)
  Automatically named identifiers (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Automatically named identifiers
Date: 5 Nov 2024 08:05:00
Message: <web.672a17d8523ee1846563700825979125@news.povray.org>
"Thomas Fester" <tfe### [at] scivitde> wrote:
> Hello everybody: I have got a (seemingly) simple programing question: Suppose I
> I want to declare a number of splines in a loop-process with one spline per
> loop. The splines should have identifiers like SplineXA, SplineXB, SplineXC and
> so on. Is there a way to automatically generate such names within the loops?
You're going to have to use parse_string to make the variable name in each
iteration.
Concat "SplineX" with the char corresponding to the letter you want.
I'm hoping there are some examples if you search for them.
- BW
Date: 5 Nov 2024 08:55:07
Message: <672a23bb$1@news.povray.org>
> so on. Is there a way to automatically generate such names within the loops? At
> the moment I am only able to explicitely generate every identifier on its own.
> To make it more clear: Is it possible to have a loop for:
Would an array of splines serve your purpose?
#for (I, 0, 3)
  #declare SplineXs[I] = spline {
    cubic_spline
Date: 5 Nov 2024 12:15:00
Message: <web.672a5258523ee18491c33a706e066e29@news.povray.org>
> iteration.
My own initial (naive) approach to this would be to try and use the Parse_String
macro to the *left* of the = sign, in a #declare. (The macro -- in "strings.inc"
-- takes a string like "MY_VALUE" or "1.5", writes it to an external .tmp file
but without the double quotes, then immediately returns it to the scene.)
So a *simple* example of such a construct would seem to be...
#include "strings.inc"
#declare Parse_String("MY_VALUE")= 27;
I would naively expect this to be the equivalent of...
#declare MY_VALUE = 27;
but it doesn't work: ""Expected 'undeclared identifier', macro identifier found
instead."
I tried other iterations of this and they all fail.
Maybe there are other (more complex?) ways of using Parse_String to accomplish
what the OP wants-- *as* the #declared variable names-- but I don't have a clue
as to how.
Date: 5 Nov 2024 16:20:00
Message: <web.672a8b41523ee184a196c5bf712fc00@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> > iteration.
> instead."
> as to how.
Parse_String("#declare I")=4;
#debug concat("I =",str(I,0,0),"\n")
works fine  on win3.7 version
Parse_String("#declare I=4;") also works ok
Have Fun!
Date: 6 Nov 2024 15:50:00
Message: <web.672bd56a523ee18491c33a706e066e29@news.povray.org>
> > a clue as to how.
Aha! So a variable name CAN be auto-generated. Excellent. (These also work
successfully in v3.8 beta 1.) I didn't think to try your iterations earlier; I
was, uh, rushed for time yesterday :-[  (Well, that's my excuse anyway, ha)
Unfortunately, even these would not solve Warren's initial query of
auto-creating *multiple* #declares, at least not efficiently.
Here's a #for-loop example that might *seem* to be a way to do it. Even though
it works code-wise as SDL, the result is not what might be expected:
[I used simple vectors here instead of Warren's splines]
#declare My_Vector_Array=array[3] // 'bins' 0 to 2 inclusive
#declare My_Vector_Array[0]= <.1,.3,.6>;
#declare My_Vector_Array[1]= <.2,.4,.7>;
#declare My_Vector_Array[2]= <.3,.5,.8>;
#for(i,1,3)
Parse_String(concat("declare MY_VECTOR_",str(i,0,0)," = <",
vstr(3,My_Vector_Array[i-1],", ",0,1),">;"))
This actually creates only ONE #declare, the final one:
#declare MY_VECTOR_3 = <.3,.5,.8>;
The Parse_String macro always #writes its result to a *single* file named
parse_string.tmp  (in Windows anyway); so in the for-loop, each result simply
gets over-written by the next one.
It would be an interesting exercise to try and re-code the macro itself, to see
if it could be made to deal with multiple entries...and to create multiple
written .tmp files as well.
Date: 6 Nov 2024 16:20:00
Message: <web.672bdc61523ee1846c6071e48a2a825f@news.povray.org>
> > > a clue as to how.
> #for(i,1,3)
> #end
Wow - I'm thrilled so many answers! Thank you all!
Date: 7 Nov 2024 04:31:53
Message: <672c8909$1@news.povray.org>
Have you looked my method ?
kurtz le pirate
compagnie de la banquise
Date: 7 Nov 2024 11:55:00
Message: <web.672cef10523ee18491c33a706e066e29@news.povray.org>
> > to see if [the Parse_String macro] could be made to deal with multiple
> > entries...and to create multiple written .tmp files as well.
Oh! You already solved that, wow. And *without* creating multiple .tmp files. I
apologize for not grasping what what your code does; I took only a cursory
glance at it while I was working out my own tests. (The beginning of your code
kind of threw me off...
       // name of include file containing splines
          #declare FileName = "Splines.inc";
I mistakenly thought that you were somehow manipulating the *original*
splines.inc include file; sorry!)
So your code actually writes *multiple* #declares to the same .tmp file (called
Splines.inc), to be used later. Excellent.
Thanks for (re-)calling my attention to it. ;-)
BTW: Sorry, Thomas, for calling you Warren. I don't know where *that* came from!
:-O
Date: 7 Nov 2024 13:10:00
Message: <web.672d025b523ee18491c33a706e066e29@news.povray.org>
> #for(i,1,3)
> #end
Actually, that one #declare would mistakenly be...
(no hash symbol at the beginning)
The Parse_String line above should have been this:
Parse_String(concat("#declare MY_VECTOR_",...
Sorry for the syntax mistake.
Date: 9 Nov 2024 06:26:45
Message: <672f46f5$1@news.povray.org>
> I mistakenly thought that you were somehow manipulating the*original*
Sorry for my clumsy choice for the file name.
kurtz le pirate
