POV-Ray : Newsgroups : povray.general : Why is my POV-Ray render not matching my mesh model? Server Time
13 May 2025 08:48:31 EDT (-0400)
  Why is my POV-Ray render not matching my mesh model? (Message 1 to 10 of 13)
Subject: Why is my POV-Ray render not matching my mesh model?
Date: 7 Oct 2024 08:50:00
Message: <web.6703d83034dbd822692b25c1b1b44dfe@news.povray.org>
I'm having trouble with my POV-Ray rendering. The rendered image doesn't match
my mesh model correctly. Specifically, there's a small rectangular area in the
rendered output that looks different from the mesh.As you can see in the
attachment, mesh model is on the left and rendered output is on the right.
Does anyone know what might be causing this discrepancy? Any help would be much
appreciated!
Harry
Download '1.png' (156 KB)
Preview of image '1.png'
Subject: Re: Why is my POV-Ray render not matching my mesh model?
Date: 7 Oct 2024 09:15:00
Message: <web.6703ddb83d58ec0ef5bfc9b06cde94f1@news.povray.org>
hi,
> appreciated!
somewhere in the documentation is a proviso about order of vertices and
interior/exterior textures.  if you provide your mesh with both (interior and
external) texture, does the "discrepancy" show up coloured ?
regards, jr.
Date: 7 Oct 2024 12:25:00
Message: <web.67040acc3d58ec0ed2a18eff25979125@news.povray.org>
> appreciated!
> Harry
As jr pointed out, it may be a result of surface normal "flipping".
I would assign your texture to be something dark, and then add an
interior_texture with a bright color and finish {emission 1}, then render a
straight-down view in orthographic to see if you have any flipped triangles.
You also have some dark areas near the center of the render, which is why I'm
suggesting this specific approach.
- BW
Date: 7 Oct 2024 12:55:00
Message: <web.670411383d58ec0e17bac71e8ffb8ce3@news.povray.org>
> appreciated!
Does POV-Ray show messages about degenerate triangles?
ingo
Date: 7 Oct 2024 15:03:37
Message: <67043089$1@news.povray.org>
Am 07.10.2024 um 18:22 schrieb Bald Eagle:
>> appreciated!
>> Harry
> - BW
This should actually help to recognize flipped normals. I probably
wouldn't have had this brilliant idea...
But unfortunately, the diagnosis does not yet cure the disease and, as
far as I know, POV does not offer an option for this. With Blender,
however, you can display normals and there are several tools to invert them.
Since you are working with Blender anyway, you should repair the mesh
there and then export it to POV.
Best regards
Michael
Date: 8 Oct 2024 02:14:50
Message: <6704cdda$1@news.povray.org>
Op 07/10/2024 om 21:03 schreef MichaelJF:
>>> would be much
>>> appreciated!
>>> Harry
>> render a
>> triangles.
>> why I'm
>> - BW
> them.
> Best regards
> Michael
A very straightforward way to correct normal orientations in a mesh is
with the help of Poseray:
https://sites.google.com/site/poseray/
very easy to use and free (!)  ;-)
Date: 9 Oct 2024 08:50:00
Message: <web.67067b443d58ec0e3bb2382ab1b44dfe@news.povray.org>
> > appreciated!
> > Harry
> - BW
Dear Bw,
Thank you for your detailed suggestion on addressing the issue with the mesh
normals. I appreciate the guidance you've provided.
Initially, I was exporting a .ply file from Blender and converting it to a .pov
file using AccuTrans. I wasn't certain if the normals were preserved in that
conversion process. However, after converting the mesh to an .obj file using
MeshLab and then back to a .pov file with AccuTrans, the rendering errors in
Povray seemed to vanish.
Following your advice, I will now test the mesh to understand the root cause of
the issue. Since I'm working with a .ply file exported from Blender and then
converted to a .pov file, I'm not quite clear on how to assign textures to the
interior and exterior within Povray, especially since I've stripped all textures
from the original mesh in AccuTrans.
Could you please provide some guidance on how to apply textures to the interior
and exterior in Povray? I'm looking forward to implementing your suggestion of
using a dark texture with a bright interior_texture to check for flipped
triangles and to illuminate the dark areas in the center of the render.
Harry
Message: <web.67067ba73d58ec0e3bb2382ab1b44dfe@news.povray.org>
> > appreciated!
> ingo
Thank you for your continued assistance with this issue.
I've checked, and Povray doesn't seem to be showing any messages about
degenerate triangles.
Harry
Date: 9 Oct 2024 08:55:00
Message: <web.67067c653d58ec0e3bb2382ab1b44dfe@news.povray.org>
> >> appreciated!
> >> Harry
> > - BW
> Best regards
> Michael
Dear Michael
Thank you for your suggestion. I appreciate the thought you've put into this.
Initially, I was using a .ply file exported from Blender and then converted it
to a .pov file using AccuTrans. I wasn't certain if the normals were included in
that process. However, when I converted the mesh to an .obj file using MeshLab
and then back to a .pov file with AccuTrans, the errors in the Povray rendering
mysteriously disappeared. I will now proceed to test the mesh according to your
method to identify the cause of the issue.
As for applying textures in Povray, especially since I've removed all textures
from the original mesh in AccuTrans, I will need to revisit Blender to repair
the mesh there and then export it to POV, as you suggested .
Harry
Message: <web.67067cdc3d58ec0e3bb2382ab1b44dfe@news.povray.org>
> >>> would be much
> >>> appreciated!
> >>> Harry
> >> render a
> >> triangles.
> >> why I'm
> >> - BW
> > them.
> > Best regards
> > Michael
> Thomas
Thank you for the suggestion and the link to Poseray. I'll check it out and see
how it can assist with correcting normal orientations in the mesh. Appreciate
the help!
Harry
