POV-Ray : Newsgroups : povray.general : Povray Mandelbulbs - Isosurface and max_gradient Server Time
7 Oct 2025 00:33:40 EDT (-0400)
  Povray Mandelbulbs - Isosurface and max_gradient (Message 1 to 10 of 21)
Subject: Povray Mandelbulbs - Isosurface and max_gradient
Date: 7 May 2024 16:45:00
Message: <web.663a8fd85eb6cc2d1397ab13b2af915@news.povray.org>
Hi folks,
I recently came across Paul Nylander's website at http://www.bugman123.com.
Marvellous images of 3D fractals rendered with Mathematica.
Exceptional rendering times and amazing images!
He also published some code to render Mandelbulbs in Povray.
Here is SDL for one of the Mandelbulbs:
// Mandelbulb - power 4 - Believe me the power 6 is a vision of hell!
// Adapted from original function for power 8 by Paul Nylander at
http://www.bugman123.com;
// Trace time on an AMD Ryzen7 Eight Core using 16 threads: 7 h 54 min with
max_gradient 1000
// Trace time on an AMD Ryzen7 Eight Core using 16 threads: 2 h 34 min with
max_gradient 200
#version 3.7;
global_settings { assumed_gamma 2.2 }
// #include "colors.inc"
// #include "textures.inc"
// #include "math.inc"
camera{
 location <1.75,4,-5.5>
 look_at <0.0, 0.0, 0.0>
 up y
 sky y
 angle 25
light_source{<-20.00, 30.00, -20.00> color rgb < 1.0, 0.498039, 0.0 >} // color
Coral
light_source{<20.00, -30.00, 0.00> color rgb < 0.847059, 0.847059, 0.74902 >} //
color Wheat
#declare n=4;
#declare f=function(i,x,y,z,xc,yc,zc) {select(i>0 & x*x+y*y+z*z<4, 0,
sqrt(x*x+y*y+z*z),
f(i-1,pow(x*x+y*y+z*z,n/2)*cos(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+xc,
        pow(x*x+y*y+z*z,n/2)*sin(n*atan2(y,x))*cos(n*atan2(z,sqrt(x*x+y*y)))+yc,
        -pow(x*x+y*y+z*z,n/2)*sin(n*atan2(z,sqrt(x*x+y*y)))+zc,xc,yc,zc))};
isosurface{
 function{f(24,0,0,0,x,y,z)}
 threshold 2
 max_gradient 200 // found by Povray: 33566
 contained_by{sphere{0,1.5}}
 pigment{rgb 1}
//end
But a word of warning before you start:
DO NOT ACTIVATE any INC-FILE! When I did Povray crashes as soon as I start
rendering!
Has anyone an idea why Povray crashes?
There is only a warning in the Message Window that says something like
'iterations are not allowed in this function'.
Happy tracing - and when you do: grab a big snack and a big mug of coffee before
you do!
Droj
Download 'mandelbulb_power4.png' (1117 KB)
Preview of image 'mandelbulb_power4.png'
Subject: Re: Povray Mandelbulbs - Isosurface and max_gradient
Date: 7 May 2024 18:18:49
Message: <663aa8c9@news.povray.org>
> max_gradient 1000
> max_gradient 200
Hi, Droj !
Very interesting - thanks for sharing.
I've rendered this 800x600 image with max_gradient=1000 (No other
parameters was changed) on Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
(40 cores) for 2 min 19 sec and can't figure out how to get make it more
detailed.
Any suggestions, please !
YB
Download 'fract_01.png' (288 KB)
Preview of image 'fract_01.png'
Date: 7 May 2024 18:25:21
Message: <663aaa51@news.povray.org>
> max_gradient 1000
> max_gradient 200
Hi, Droj !
(40 cores) for 2 min 19 sec and can't figure out how to make it more
detailed.
YB
Date: 7 May 2024 19:35:07
Message: <663abaab@news.povray.org>
Agree with you - sometimes it looks horrible ...
camera{location <-2.5,5,5> look_at <-0.5,0,0.3> up z sky z angle 25}
light_source{20*z,1}
sqrt(x*x+y*y+z*z),
f(i-1,(x*x-y*y)*(1-z*z/(x*x+y*y))+xc,2*x*y*(1-z*z/(x*x+y*y))+yc,-2*z*sqrt(x*x+y*y)+zc,xc,yc,zc))};
isosurface{function{f(24,x,y,z,x,y,z)} threshold 0.5 max_gradient 1000
contained_by{sphere{<-0.5,0,0>,2}} pigment{rgb 1}}
YB.
Download 'fract_02.png' (163 KB) Download 'fract_02_1.png' (117 KB)
Preview of image 'fract_02.png'
Preview of image 'fract_02_1.png'
Date: 9 May 2024 09:25:00
Message: <web.663cce5da9c49b654e7519d73b2af915@news.povray.org>
> detailed.
> YB
Hi yesbird
as I can see you have no problem with the rendering time as I have.
You can increase max_gradient.
When I rendered it the max_gradient Povray found was 33566.
So give it a go.
Droj
Date: 9 May 2024 09:40:41
Message: <663cd259$1@news.povray.org>
On 09/05/2024 16:23, Droj wrote:
> So give it a go.
Hi, Droj.
Thank you, I will try.
YB
Date: 9 May 2024 11:44:09
Message: <663cef49@news.povray.org>
It took 15m59,185s for rendering with max_gradient=33566, and n=6,
but I see, that your image looks more smooth and pretty.
What's the secret ? Antialiasing, maybe ... Could you please post
all rendering parameters ?
This teddy bear don't looks like real daemon, but some sort of inferno
is present, no doubt ...
YB
Download 'mand_pow_6_1600x1200.png' (1117 KB)
Preview of image 'mand_pow_6_1600x1200.png'
Date: 9 May 2024 18:10:00
Message: <web.663d4867a9c49b65e85adf843b2af915@news.povray.org>
Hi YB
Oh man you make me weep! 16 min with max_gradient=33566 ... if I try my image
will be finished next week.
Here are the settings of the ini-file I use:
Width = 1600
Height = 1200
Antialias = On
Sampling_Method = 1
Antialias_Threshold = 0.0010
Jitter = Off
Antialias_Depth = 9
Output_To_File = On
Output_File_Type = N
Display = On
Verbose = Off
Quality = 11
Input_File_Name =
Output_File_Name =
Initial_Frame = 0
Final_Frame = 0
Subset_Start_Frame = 0
Subset_End_Frame = 0
Test_Abort = On
Test_Abort_Count = 100
Have you ever seen Edvard Munk's painting 'The Scream'? It's disturbing but
Mandelbulb power 6 is worse.
Hope the ini settings will help.
Droj
Date: 9 May 2024 19:37:06
Message: <663d5e22@news.povray.org>
On 10/05/2024 01:04, Droj wrote:> Oh man you make me weep! 16 min with
Hi, Droj.
Please, don't cry: I noticed, that your setting are too 'aggressive':
; Antialias_Depth = 9
; Antialias_Threshold = 0.0010
See: https://www.povray.org/documentation/view/3.6.1/223/
making less depth and threshold can seriously improve performance with
almost the same quality.
Thanks for setting, you've saved a lot of time for me.
> Have you ever seen Edvard Munk's painting 'The Scream'?Yes, sure, this is a famous
painting, but I see something close to
Francisco Goya. :)
Happy poving,
YB
Download 'fract_03_800x600.png' (95 KB)
Preview of image 'fract_03_800x600.png'
Date: 9 May 2024 19:40:22
Message: <663d5ee6$1@news.povray.org>
Hi, Droj.
Yes, sure, this is a famous painting, but I see something close to
Francisco Goya. 🙂
Happy poving,
YB
