POV-Ray : Newsgroups : povray.general : #ifdef using a string expression? Server Time
20 May 2024 13:51:33 EDT (-0400)
  #ifdef using a string expression? (Message 11 to 20 of 38)
Subject: Re: #ifdef using a string expression?
Date: 19 Mar 2023 09:45:00
Message: <web.641710d898df09c99b4924336e066e29@news.povray.org>
> "Kenneth" <kdw### [at] gmailcom> wrote:
> > Yep, I get that-- if the #ifdef is seeing it as boolean, that is. But
> > here's a weird thing (well, weird to me at this point of my fuzzy
> > understanding):
> >         #ifdef(true)
> > is apparently seen as NOT defined, and falls through to the #else.
> And you get that to work without a warning?
I didn't think to look. But you're right, I get the same warning:
"Parse Warning: Tried to test whether a reserved keyword is defined..." etc.
So with a *properly*-working #ifdef instead of the current flaw in v3.8.0 beta 1
or 2 'official' versions, I'm still curious about something you mentioned: Is it
supposed to indeed be a simple boolean comparison? Or is it's operation more
complex than that?
Date: 19 Mar 2023 10:15:00
Message: <web.641717fa98df09c91f9dae3025979125@news.povray.org>
> complex than that?
Wellll.......
I suppose it depends upon what one wants the language to do or thinks it
properly "ought" to do...
One could argue that a keyword is, in some sense, "defined", and as the warning
message states, reserved.
My example (probably me reading the whole post in a haze) of 0 / 1 was really
for _#if_, not #ifdef.
I'm sure that "Real programmers" have a better take on this, and sounder reasons
than I could present.
Aside:
Rather than having to write a whole ifdef/else/end statement for every case I
wanted to test, I had the strong urge to write a macro and maybe use ParseString
to make it work, but we don't have a way to test for data type, isolate
keywords, or any of the tools to write that sort of "meta" code.
Message: <web.641718bf98df09c99b4924336e066e29@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> Alright.
> A long time ago I created a bunch of statically linked(a) versions of
> POV-Ray going back through time. Anyhow. Used these to trace the
> introduction of the str/num OK in #ifdef test bug.
> [clip]
> My BIG bet is on the following commit being the problem,
> but I don't have a static compile of it or the one prior to it to
> be sure.
Given the current mix of flaws, the use of a string literal still has me
scratching my head...
        #ifdef("...string...")
Alain's and JR's explanation of the expected behavior seems valid; but with a
properly-working #ifdef, should the comparison fail outright (fatal error)? Or
should it still be seen as defined? I'm mostly just curious ;-)
Date: 19 Mar 2023 10:45:00
Message: <web.64171f2898df09c91f9dae3025979125@news.povray.org>
One might suggest:
"Expected variable name, literal value found instead."
-or- "It is what is is." ;)
The correct answer for me has always been OPTIONS.
When everything gets locked into a one-right-answer only format, it usually just
creates new problems in the process of "solving" the old.
I was just reading some old threads concerning this type of thing, and the
degenerate triangle warning vs 0-length fatal error for cylinders was brought
up.
For some scenes it could be a critical thing to stop the render.   For others,
you might want to just ignore them all.  Usually these things are addressed by
the users with workarounds, but why not have a configuration file that states
how to handle these cases, an additional argument for the object instantiation
that provides for individual control, or an error-trapping mechanism (with error
code) that allows the user to write their own programmatic/logical solution
based on further testing and flow control, and allows the user to issue better
warnings that the cryptic ones currently hard-coded in source?
Date: 19 Mar 2023 16:30:35
Message: <641770eb$1@news.povray.org>
>> Alright.
>> [clip]
>> be sure.
I'm a little further along in looking at this. It's looking messy.
I think we need to start with the fact #ifdef, #ifndef and #undef have
ALWAYS been #ifIdDefined, #ifIdNotDefined and #undefineId. Going back to
the v3.6 documentation we have:
2.2.2.6.2 The #ifdef and #ifndef Directives
The #ifdef and #ifndef directive are similar to the #if directive
however they are used to determine if an identifier has been previously
declared.
IFDEF_DIRECTIVE:
     #ifdef ( IDENTIFIER ) TOKENS... [#else TOKENS...] #end
IFNDEF_DIRECTIVE:
     #ifndef ( IDENTIFIER ) TOKENS... [#else TOKENS...] #end
If the IDENTIFIER exists then the first group of tokens is parsed
normally and the second set is skipped. If false, the first set is
skipped and the second set is parsed. ...
So... The up front, not so good, news is the behavior of at least the
#ifdef and #ifndef keywords was partly changed back in March of 2015.
Intentional or accidental? It's not mentioned as an intended change
anywhere I have seen - and I still don't understand how it happened even
with some time reviewing the changes when it happened.
Christoph went on to add a bunch of inbuilt keywords to be considered
'defined' sometime after late November 2018 - which makes me begin to
think he too might have been considering these *def keywords in the
c/c++ coding, macro test sense.
The few 'keywords' I've tested these generate a warning in at least some
versions of POV-Ray. But it's weird, keywords NOT returning immediate
numbers or strings are also considered 'defined' in these versions
though they are in fact arbitrary SDL keywords.
Even this worked in the pre-backed off v3.8 release parser:
#ifdef(#declare V=99;#undef V)
Though without some other mistake it would usually die with a later
unmatched something parsing fail. That said it's not hard to get it to
parse clean - say with an added #if(). I will always die if somebody
tries use the undef'd V.
So, much more was being supported as testing true in povr/v4.0, but
still not some things like raw vectors. Though things like x,y,z are OK.
Christoph backed up the v3.8 parser and again lost the inbuilt keywords
as "defined". I do not know the reasons for the parser backup, but
perhaps this issue it - or big part of it. I don't know.
I do know, I've got a mess with these in the povr parser given my branch
point... :-(
When I test v3.7, v3.8b2 and my povr(v4.0?) code I get:
v3.7
GOOD_ID  --> This is a valid ID. (ifdef returning true)
GOOD_ID  --> This is a valid ID. (ifndef returning false)
BAD_ID   --> This is NOT a valid ID. (ifdef returning false)
BAD_ID   --> This is NOT a valid ID. (ifndef returning true)
"STRING" --> Other than an ID. (ifdef returning false)
"STRING" --> Other than an ID. (ifndef returning true)
""       --> Other than an ID. (ifdef returning false)
""       --> Other than an ID. (ifndef returning true)
1.23456  --> Other than an ID. (ifdef returning false)
1.23456  --> Other than an ID. (ifndef returning true)
0        --> Other than an ID. (ifdef returning false)
0        --> Other than an ID. (ifndef returning true)
pi       --> Other than an ID. (ifdef returning false)
pi       --> Other than an ID. (ifndef returning true)
          --> Other than an ID. (ifdef returning true)
v3.8b2
"STRING" --> Other than an ID. (ifdef returning true)        ***
"STRING" --> Other than an ID. (ifndef returning false)      ***
""       --> Other than an ID. (ifdef returning true)        ***
""       --> Other than an ID. (ifndef returning false)      ***
1.23456  --> Other than an ID. (ifdef returning true)        ***
1.23456  --> Other than an ID. (ifndef returning false)      ***
0        --> Other than an ID. (ifdef returning true)        ***
0        --> Other than an ID. (ifndef returning false)      ***
povr & likely v4.0 and other misc releases before parser backup
pi       --> Other than an ID. (ifdef returning true)        ###
pi       --> Other than an ID. (ifndef returning false)      ###
The last case with empty parens is an exposure back to v3.7. In a lot of
code the effective fall through at the #if____ will cause later parsing
problems, but the error are of the more unhelpful sort. It would be best
if the empty parens were themselves a parse error. I 'think' it's
probably also possible to fix the following parsing issues with another,
cleaning syntax (actual bad-syntax) sort of mistake.
My feeling is the right thing to do would be to take the behavior back
to what it has always been with the nearer term v3.8 release. If we want
the most backward compatibility this it. Further, the extra now being
changed currently in the v3.8 code is not consistent with respect to
things like pi - which to the parser is an immediate value of pi. And
datetime would be an example of an immediate string which would test
true, you'd think, if "string" does.
What to do... I could spend a lot of time trying to figure out the
history here, but I think the current state not completely tenable since
2015...
We need functionality which deals only with IDs.
We, perhaps, need some sort of what is in the parenthesis is 'defined'
functionality too, but the generic sort being allowed or not seems
questionable to me. Are people already using this functionality?
With povr I might do something drastic like create 'id' versions and and
'defined' versions - with all new keyword names so users would be forced
to look at potential problems with interpretation and behavior given the
old keywords wouldn't work!
Hmm... We do have new to v3.8 the local and global dictionaries. Could I
just dump the #ifdef and #ifndef keyword for something based on those. I
can't remember at the moment how they work.
Don't know... Whatever it is in povr, afraid at the moment it'll be a
lot of work - because I'll need to digest a lot of the parser code.
Guess it's time to do my taxes... :-)
Bill P.
Date: 19 Mar 2023 17:55:00
Message: <web.6417846d98df09c91f9dae3025979125@news.povray.org>
I think you're going to run into the same hamstringing that an over-concern
about backwards compatibility inevitably results in.  If any of this stuff is
going to be fixed, there needs to be a clean break, and a sane, logical,
rational, basis for moving forward.
That looks fine - given someone may have some reason to do that.  Some sort of
quick bypass workaround.
> I will always die if somebody tries use the undef'd V.
Yes.  Because V is for Victory, and undefining it results in Failure.  :P
> 2015...
I use and abuse whatever I can find as a workaround for lack of functionality.
I absolutely don't mind rewriting code to perform with a new and better version.
Currently trying to implement some geometric testing code, it's becoming
increasingly clear that we have plenty of raytracing capability, and missing
programming code to make coding the scenes easier and more capable.
Example:
I'm testing for an intersection.  What do I do in SDL if there's a) none, or b)
more than 1?   Or if I'm looking at parallel or skew lines.  Or the user or the
circumstances require the endpoints of a line to be the same (a point)?
I'm dreaming up workarounds like mixed arrays with succeed/fail flags followed
by the variable number of results (line/line | line/circle | circle/circle).
For data type cast, I'm thinking I need a 2D mixed array with the [0] holding
the data type as a string, and the actual data in the 1[].
It would be so much easier to code these things (and faster) if we had some
tools to deal with variable results.
null, NaN, variable type detection, error trapping, etc.
It would make testing with #ifdef a little more sane if #ifdef (keyword)
returned a versatile value that I could make use of in a broad number of
circumstances.
First - I think POV-Ray needs to sort out keywords vs values, scalars vs
vectors, vs parse/render/function space variable names.  It's confusing, and is
contributing directly to the mess you're trying to sort out. You can't.  It's
all inextricably mixed.  clipka correctly pointed out that all of this stuff
needs to get disentangled in the parser.
So, I would say that "if" should return a value that denotes keyword,
whereas "pi" should return a value that denotes a reserved value.  "CONST", or
whatever that compiler one is.  "PRAGMA"
It's "nice" that I can swizzle things all over the place between vectors and
colors, etc.  But it makes for lazy / bad programming practices.  Better the
ability to recast a value from a scalar to a vector to a color, etc.
It would probably take me a month, tops, to adapt to the new requirements, and
I'd be able to write better, shorter, more easily understood and maintained
code.  Further, if there were sufficient programmatic capability, "fixes" for
old scenes could be coded, much like TOK and I code custom functions and macros
to handle pow (0, 0), factorial, N choose M, mod () crossing the origin, etc.
Just change the keyword in the old scene to a capitalized version ("We love you,
jr!") and boom - you have a macro that could possibly handle a lot of the
backward compatibility with a simple find/replace on the old scene file.
The first rule of holes is: when you find yourself in one, stop digging.
The second is: climb out.
I'd rather suffer now, and profit later.
Date: 19 Mar 2023 23:45:00
Message: <web.6417d58798df09c99b4924336e066e29@news.povray.org>
Thanks for doing such a detailed series of tests and an examination of the
various code versions! I can imagine that it was a lot of drudgery.
> [clip]
> ...but the generic sort being allowed or not seems
> questionable to me.
I agree; IMO, #ifdef etc. should adhere to the much more strict behavior
described in the docs. Admittedly, I am not as sophisticated a user of these
functions as some others are, but the current behavior seems quite lax and could
lead to unintended scene errors or coding 'mysteries'.
And I would be happier if my silly string-literal example produced a fatal
error! Otherwise, I can't imagine a scenario where a 'naked' string would even
be used there.
I also think that using an *actual* zero or a float (while having some meaning
as boolean values) does not really represent a 'valid ID' as per docs, and so
should fail outright as well. My opinion ;-) HOWEVER... I can see a scenario
where 0 or 1 could be used simply to test whether a scene's specific #ifdef
construct is working properly or not-- in other words, without relying on an
actually-defined identifier for the test. On the other hand...it would be a
simple matter to pre-define a temp dummy identifier for the same use.
Actually, it's not clear to me why any keywords at all would or should be valid
'parameters' for an #ifdef comparison-- but I'm rather naive at present about
what might be such a useful coding scenario. For example, my own rather
meaningless(?) test of
               #ifdef(true)
appears to be a flat-out mistaken use of the function, since the comparison will
(or rather, *should*) always invoke the first clause, never the #else. In other
words, this construct should use #if or #while or #switch or etc, not #ifdef.
I am obviously not seeing why a keyword could be meaningfully used there.
In general, I think that most of not all of the non-fatal error messages re:
#ifdef should be changed to fatal-- if only as a guard against using entities
that don't belong there and need changing. Personally, I'm lazy about taking
note of non-fatal messages.
Date: 20 Mar 2023 03:20:00
Message: <web.641808dd98df09c94301edef6cde94f1@news.povray.org>
hi,
> 'parameters' for an #ifdef comparison ...
one use I see, though I have never tried/used it, is determining whether a given
keyword (already) exists in the POV-Ray version doing the parsing; if it worked
for, eg, 'tau'.  also, fwiw, agree that parsing (generally) should be "strict".
regards, jr.
Date: 20 Mar 2023 11:11:17
Message: <64187795$1@news.povray.org>
> One might suggest:
> up.
Or even a global_settings entry, such as :
Ignore_degenerate true|false //default to false
Date: 20 Mar 2023 21:20:00
Message: <web.6419062498df09c99b4924336e066e29@news.povray.org>
> > be valid 'parameters' for an #ifdef comparison ...
> for, eg, 'tau'.
Ah! Yes, I see the usefulness of that. Thanks. That totally escaped me. My
#ifdef(true) example was a bad choice to illustrate the situation.
> > even be used there.
