POV-Ray : Newsgroups : povray.general : obj2pov.c wanted Server Time
7 Oct 2025 04:55:35 EDT (-0400)
  obj2pov.c wanted (Message 1 to 10 of 15)
Subject: obj2pov.c wanted
Date: 8 Feb 2023 13:15:00
Message: <web.63e3e5ef279d90f77eb01f2810800fb2@news.povray.org>
Hi, guys !
As a side project I am starting a ZBrush plugin for transferring mesh data to
POV. Before I will get details about ZBrush internal structures, I would like to
make a draft workflow: ZBrush->OBJ->POV, but can't find OBJ->POV converter.
Links here are dead:
https://www.povray.org/resources/links/3D_Programs/Conversion_Utilities/
ftp://mystique.servetheweb.com/pub/obj2pov/obj2pov.c
and googling gives nothing. Maybe someone keeps it in a private archive ?
Please, help !
YB
Subject: Re: obj2pov.c wanted
Date: 8 Feb 2023 14:20:00
Message: <web.63e3f573c1c6394b88a828ca6cde94f1@news.povray.org>
hi,
googling I find a same-named java utility
<https://github.com/JossWhittle/Obj2Pov>, but perhaps that's not an option?  if
you get no luck, and if the generated .obj only contains vector + face data
lines, I have an old Tcl script which could be adapted (write).
regards, jr.
Date: 8 Feb 2023 14:25:00
Message: <web.63e3f6f3c1c6394b88a828ca6cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> ... generated .obj only contains vector + face data
                                   vertex
regards, jr.
Date: 8 Feb 2023 14:40:00
Message: <web.63e3f9bec1c6394b7eb01f2810800fb2@news.povray.org>
Hi, jr
You are right - java is not for me )
> if you get no luck, and if the generated .obj only contains vector + face data
I want also colors and normals, if any in OBJ, will continue search, but thanks
in any case.
YB
Date: 8 Feb 2023 15:20:00
Message: <web.63e40372c1c6394b1f9dae3025979125@news.povray.org>
> Please, help !
You probably won't find one, but consider this:
STL is virtually mesh {}, it's just a few simple line modifications.
IIRC, Cousin Ricky and I have done our own find/replace strategies, so it should
be simple to do OBJ->STL->POV mesh
Date: 8 Feb 2023 15:30:00
Message: <web.63e40602c1c6394b7eb01f2810800fb2@news.povray.org>
Thanks, this is an option. Also I've emailed to Paul Bourke, asking him about
permissions for using his works in POV-Lab and about this converter too.
I know, he is using it.
Date: 9 Feb 2023 07:12:08
Message: <63e4e318$1@news.povray.org>
On 2/8/23 13:13, yesbird wrote:
> Hi, guys !
> Please, help !
> YB
Paying only loose attention to this thread, but I think many use the
windows program PoseRay to convert from Obj (and many other formats) to
POV-Ray SDL.
Some years ago this program ran under wine on linux for me, but I've
done nothing current with it. Plus, I'm a little unsure of the current
status of PoseRay not having seen much recent mention of it. Thomas?
https://sites.google.com/site/poseray/
Bill P.
Date: 9 Feb 2023 11:10:00
Message: <web.63e519adc1c6394b7eb01f2810800fb2@news.povray.org>
Hi, Bill !
> POV-Ray SDL.
Many thanks for your reply, I was very close to canceling this project, but now
I found exactly what I was looking for - many options and converting from
command line.
Present version (v.3.13.31 - March 2, 2021) works like a charm !
All the best,
YB
Date: 9 Feb 2023 11:41:39
Message: <63e52243@news.povray.org>
Op 9-2-2023 om 13:12 schreef William F Pokorny:
> POV-Ray SDL.
Coming too late to this thread, but yes, I would also have suggested
Poseray indeed. It works like a charm for all kind of things.
Date: 10 Feb 2023 04:35:00
Message: <web.63e60eb3c1c6394b7eb01f2810800fb2@news.povray.org>
It's true, but I am stuck on the following: trying to export data from ZBrush in
OBJ format I found that per-vertex colors are passed non-standard way - in
comments, like described in the following paper:
http://paulbourke.net/dataformats/obj/colour.html
Paul writes that _some_ converters cat read per-vertex colors from three last
numbers in line. I've done a few experiments with PoseRay (small OBJ attached),
but without success, so I am in doubt - am I doing something wrong or it's not
possible 'by design' of PoseRay ?
Thanks in advance for your answers.
YB
Download 'pm3d_plane3d_1.obj.txt' (1 KB)
