POV-Ray : Newsgroups : povray.general : Need to run POVRAY on a single thread Server Time
4 Mar 2026 14:09:29 EST (-0500)
  Need to run POVRAY on a single thread (Message 1 to 5 of 5)
Subject: Need to run POVRAY on a single thread
Date: 8 Feb 2023 00:45:00
Message: <web.63e3357b503d41c895a6cf0b78dd8b08@news.povray.org>
Hi. I tried to run povray on a single thread and for the same purpose I used the
+WT1 option. I observed the following : (Refer image attached for reference)
While the photon time was shown with 4 threads used for processing the trace
time was shown with 1 thread. Searching a bit more, found that +WT option doesnt
control the photon time related threads. I then tried to change the gather
setting in GLOBAL_SETTINGS for photon with min_gather and max_gather set to 1
and tried to check maybe if this leads to only one thread getting used. But got
similar results( i.e 4 threads were displayed along with photon time).
How can we run the povray application completely on a single thread? Kindly
share your thoughts. Thanks
Download 'povray_test.png' (25 KB)
Preview of image 'povray_test.png'
Subject: Re: Need to run POVRAY on a single thread
Date: 8 Feb 2023 02:45:00
Message: <web.63e351e3b379c51b88a828ca6cde94f1@news.povray.org>
hi,
that, likely, is a misunderstanding.  you're telling POV-Ray to run with one
worker ("render") thread.  if you use the eg 'ps' command while POV-Ray runs,
you'll see a minimum of six active threads.
if your scene code permits it, you could try and run POV-Ray version 3.6, which
aiui is the last version not "threaded".
regards, jr.
Date: 9 Feb 2023 01:50:00
Message: <web.63e49744b379c51b95a6cf0b78dd8b08@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> regards, jr.
Thanks for the reply
Based on your inputs I tried to run with and without +WT1 option and check how
many no of threads of running
I could see that multiple threads were getting opened. But with +WT1 option one
thread was having like >12% CPU utilisation and others less than < 0.01.
Meanwhile with +I options I got two threads > 12% utilisation and others < 0.01
Assuming that the CPU threads refers to the trace time, is there any similar
ways to minimise number of threads or impact of threads on photon time and
radiosity time. Screenshots of CPU Utilisation are attached for reference
Download 'with +wt1 option.png' (38 KB)
Preview of image 'with +wt1 option.png'
Date: 9 Feb 2023 03:05:00
Message: <web.63e4a84bb379c51b88a828ca6cde94f1@news.povray.org>
hi,
disclaimer - not an "expert" in things POV-Ray internals.  when you look at the
(text) output, you can see the various stages.  first parsing, that is always
one thread "working", next stage stuff I know little about like photons +
radiosity, but, as you observed, multiple threads involved.  last the actual
render, and you tell POV-Ray to use 'wt' threads at most to do that.  the
remaining threads are (the "main" thread aside) to service the console IO etc.
in a typical scene where more than just a test render is done, you'll see CPU
utilisation "at capacity" unless you use options; so eg for an old Core2 (== 4
h/ware threads), I see 397/398%, solid, until POV's done.
not that I'm aware of, but hope someone in-the-know will butt in.
regards, jr.
Date: 9 Feb 2023 07:06:28
Message: <63e4e1c4$1@news.povray.org>
While making no claims to being in the know... ;-) My understanding
matches yours jr.
I think the state of things is there is always more threads than +WTn
active though often they are not consuming time. For example, there is a
master thread sitting atop and managing the rendering threads - which
consumes little time.
I'm not sure off the top of my head how the POV-Ray reported thread
counts come about for photons and radiosity with respect to threads used
and +WTn.
Bill P.
