POV-Ray : Newsgroups : povray.general : Empty value for variable Server Time
13 Jul 2025 21:56:14 EDT (-0400)
  Empty value for variable (Message 1 to 10 of 15)
Subject: Empty value for variable
Date: 4 Feb 2023 05:30:00
Message: <web.63de3370cfe1936a4ad5859710800fb2@news.povray.org>
Hi, guys !
Is there a way to assign an empty value to variable, using something like 'None'
in Python or NULL in C ? I would like to use it while passing parameters to
macros, for more compact notation.
Can not find any info in docs about it.
Thanks in advance,
YB
Subject: Re: Empty value for variable
Date: 4 Feb 2023 05:45:00
Message: <web.63de36ff5d560c7488a828ca6cde94f1@news.povray.org>
hi,
not that I can think of[*].  as a workaround, if the argument is optional and
not supplied, you can '#if (!defined(local.varName))' in the macro, to check, if
not supplied == NULL?
[*] however, two .. misfires already, this morning :-(
regards, jr.
Date: 4 Feb 2023 06:35:00
Message: <web.63de425a5d560c744ad5859710800fb2@news.povray.org>
Hi, jr.
Your answer assumes that macros can accept variable number of arguments, but
docs states following:
https://www.povray.org/documentation/3.7.0/r3_3.html#r3_3_2_8
3.3.2.8.2 Invoking Macros
You invoke the macro by specifying the macro name followed by a list of zero or
more actual parameters enclosed in parentheses and separated by commas. The
number of actual parameters must match the number of formal parameters in the
definition.
I only want to pass 'None' values to some of them to exclude their values from
object definitions, using system defaults for them and having more compact
notation finally.
Looks like it's not possible :(.
YB
Date: 4 Feb 2023 07:35:00
Message: <web.63de4ff35d560c7488a828ca6cde94f1@news.povray.org>
hi,
it does, sort of.  eg
#macro foo(a, optional b)
  #if (!defined(local.b))
    /* no b given on call */
foo(1,2)
or
foo(1,)
presuming that a "misisng" when called can be used for your purpose.
(have a look at the 'queues.inc' for use of optional args)
regards, jr.
Date: 4 Feb 2023 08:00:00
Message: <web.63de55eb5d560c744ad5859710800fb2@news.povray.org>
Thanks a lot, it really works ! (on ver. 3.8 only),
but I can't find this file anywhere, where did you get from ?
YB
Date: 4 Feb 2023 08:10:00
Message: <web.63de58a35d560c7488a828ca6cde94f1@news.povray.org>
hi,
ah, yes, forgot, sorry.  'optional' was new in 3.8.
my own, on the wiki.  however, there's also a macro in 'pvars.inc' (on wiki)
which has only optional arguments.
regards, jr.
Date: 4 Feb 2023 08:25:00
Message: <web.63de5c185d560c744ad5859710800fb2@news.povray.org>
Thanks, I've found it, moreover structures are very useful itself :)
YB
Date: 4 Feb 2023 09:45:00
Message: <web.63de6e4f5d560c741f9dae3025979125@news.povray.org>
> Hi, guys !
> Thanks in advance,
> YB
As jr pointed out, there are work-arounds.
I find the optional keyword, and its required commas to be awkward and clunky.
Can you store your macro parameters in an array?
Then the array will exist, but it might not have certain elements defined.  Then
you test each element in the size of the array
#declare SizeOfArray = dimension_size (Array, 1)-1;
#for (i, 0, SizeOfArray)
     #if (!defined (Array[i])
Just another option.
Date: 4 Feb 2023 11:05:00
Message: <web.63de81675d560c744ad5859710800fb2@news.povray.org>
Good idea, but 'optional' works fine for me, as I prefer to simplify the passing
process.
Date: 6 Feb 2023 13:30:00
Message: <web.63e146b35d560c7480f94ee210800fb2@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
Looks like there is some limitation on number of optional args:
#macro _vector(optional p1, optional p2, optional p3)
_vector(1, 2, 3) // OK
_vector(1, 2,  ) // OK
_vector(1,     ) // Error
I wonder how is your code works ?
YB
