POV-Ray : Newsgroups : povray.general : cyclone fence Server Time
4 Mar 2026 15:41:03 EST (-0500)
  cyclone fence (Message 1 to 9 of 9)
Subject: cyclone fence
Date: 13 Aug 2022 09:15:00
Message: <web.62f7a2a6b4110b7d1c1b6180a57e0@news.povray.org>
I did a render of my high school but didn't add the cyclone fencing because the
thought of that many calculations frightens me. Is there a way to cheat a
cyclone fence since the school is seen from a distance?
Subject: Re: cyclone fence
Date: 13 Aug 2022 10:10:00
Message: <web.62f7b07dc97524821f9dae3025979125@news.povray.org>
A standard chain link fence seems to be just interlocking spirals of wire.
You could make 2 spirals, 1 for each "offset" and then just repeat those 2
objects.
If want to try to fake it, maybe either just do a criss-cross grid of cylinders,
or use an image map with an alpha channel.
What calculations do you think you need to do?
This was done with just spheres:
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5781842fa68f756e5e7df57c0%40news.povray.org%3E/?ttop=43821
8&toff=750
- Bill
Date: 13 Aug 2022 10:35:40
Message: <62f7b6bc$1@news.povray.org>
Op 13-8-2022 om 15:09 schreef David Kraics:
Not sure what a cyclone fence is  ;-)  as I am not living in the US, but
BaldEagle's suggestions are an excellent suggestion. See also this
ancient (but very important) site through the WayBackMachine, which may
suggest a solution to you:
https://web.archive.org/web/20060820230007/http://www.econym.demon.co.uk/holetut/index.htm
Date: 13 Aug 2022 21:55:00
Message: <web.62f85581c97524821f9dae3025979125@news.povray.org>
Quick and dirty, but accurate and to scale.
Should give a solid start.   :)
#version 3.8;
global_settings {assumed_gamma 1.0}
#include "shapes3.inc"
    location  <0, 48, -96>
    look_at   <0, 24, 0>
light_source {<-140, 200, -300> rgb 1 shadowless}
#declare RH =
union {
 object {Segment_of_Torus (
    0.15, // radius major,
    0.15/2, // radius minor,
    -90  // segment angle (in degrees)
 rotate  y*45
 rotate -x*45
 translate -x*0.15
 //cylinder {<0, 0, 0.15>, <-2, 0, 0.15> 0.15/2}
 cylinder {<0, 0, 0.15>, <-2, 0, 0.15> 0.15/2 rotate -z*45}
#declare LH =
union {
  rotate -y*90
  rotate -y*45
  rotate  x*45
  translate x*0.15
 cylinder {<0, 0, 0.15>, <2, 0, 0.15> 0.15/2 rotate z*45 translate -z*0.15*3/2}
 //scale <1, 1, -1>
#declare Coil1 =
union {
 #for (n, 1, 17)
  object {RH translate y*n*1.4*2}
  object {LH translate y*(1.4 + n*1.4*2) translate -x*1.4}
 pigment {rgb <1, 0.7, 0>}
#declare Coil2 = object {Coil1 scale <-1, 1, 1>}
#declare Pair =
union {
 object {Coil1}
 object {Coil2 translate -x*0.15}
#for (N, -20, 20)
 object {Pair translate x*(1.4-0.15)*N*2}
Date: 14 Aug 2022 02:14:57
Message: <62f892e1$1@news.povray.org>
And finally, for the lazy, from a site I highly recommend:
http://www.f-lohmueller.de/pov_tut/objects/obj_160e.htm
http://www.f-lohmueller.de/pov_tut/x_sam/sam_160e.htm
Date: 14 Aug 2022 08:25:00
Message: <web.62f8e873c97524821f9dae3025979125@news.povray.org>
> Thomas
But of course.
I should have known, and should have remembered.
Lohmueller's site is like some ancient shrine, the Hall of Records beneath the
Sphinx's paws, a vast store of knowledge waiting to yield its secrets to those
who ask and only need know where to look.
Thanks for the link, again, Thomas.
Date: 15 Aug 2022 02:19:15
Message: <62f9e563@news.povray.org>
Op 14/08/2022 om 14:20 schreef Bald Eagle:
>> Thomas
> But of course.
You are welcome :-)
I often tend to forget to visit when in need of some object or other. It
is an incredible collection which I increasingly address for my own
benefit. Friedrich's death in 2017 has been a great loss for all of us,
but first of all for Andrea of course.
Date: 15 Aug 2022 13:55:00
Message: <web.62fa87a6c97524821f9dae3025979125@news.povray.org>
Yes, there's _SO_ much stuff that he's done, that some of the info inevitably
gets pushed off the end of the grey-matter memory stack.
I would concur about his loss - on both points.   As much as those of us who
only knew him from his technical accomplishments and contributions felt his
loss, Andrea must have suffered a loss a million times larger.  They certainly
seemed to be a team who shared many interests and worked together on many common
projects.
That said, I would like to again petition the site manager(s) to create a
special section where an independent archive Of Friedrich Lohmueller's work can
be accessed in its entirety.
As Mike Williams' website is down, and no one has heard from him in quite some
time, I fear that he also has passed on.  The full archive of his invaluable
work ought be made fully available again here as well.
There are also a number of interesting repositories of work that have been lost
due to any number of reasons, and likely would make a handsome addition to a
special archive section of the website.  Chris Colefax comes immediately to
mind, and surely there are others....
Date: 16 Aug 2022 08:49:51
Message: <62fb926f$1@news.povray.org>
Op 15-8-2022 om 19:51 schreef Bald Eagle:
Yes indeed. I was late in coming across and use, for instance, his
railway tracks. A challenge!
> projects.
Yes indeed.
I strongly agree with this.
Certainly.
