POV-Ray : Newsgroups : povray.general : Overlaying object over an image Server Time
13 Jan 2026 21:02:06 EST (-0500)
  Overlaying object over an image (Message 1 to 10 of 11)
Subject: Overlaying object over an image
Date: 23 Jul 2022 08:35:00
Message: <web.62dbea13c23a6d94eb0f47cfb08dd02@news.povray.org>
Good evening
I have implemented the codes belonging to the 2 and 3 messages in this
threadhttp://news.povray.org/povray.general/thread/%3Cweb.62d84daeafca4da4d8145616fb08dd02%40news.povray.org%3E/
what the codes basically do is import an image to fit the output screen.
all I want to do is overlay a line over the image that was imported into povray.
when I use povrays primitive objects they seem not to be behind the imported
image. I say this because they are not coming up at all.
so how do I make the object show over the imported image
thank you
Subject: Re: Overlaying object over an image
Date: 23 Jul 2022 08:45:00
Message: <web.62dbec6e8506b8624eb0f47cfb08dd02@news.povray.org>
"6digit" <eob### [at] gmailcom> wrote:
> Good evening
> when I use povrays primitive objects they seem to be behind the imported
> thank you
sorry had to rewrite the question
Date: 23 Jul 2022 09:25:00
Message: <web.62dbf6528506b8621be3cd4b6cde94f1@news.povray.org>
hi,
conceptually:
    | box w image_map    |
    | "box" for line(s)  |
           \ /  camera
(where I'm "looking" down the Y axis.  the quoted "box" is not a primitive, but
simply to highlight the space.
if you posted a (simplified) version of your code, I/we could, likely, provide
better advice.
regards, jr.
Date: 23 Jul 2022 15:45:00
Message: <web.62dc4efa8506b8621be3cd4b6cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> conceptually:
a simple example (I did have a little time on my hands :-)):
-----<snip>-----
#version 3.7;
global_settings {assumed_gamma 1}
#declare pigment_ = pigment {
  image_map {
    png "tinai.png"
    once
    map_type 0
    interpolate 2
  scale <2.048,1.519,1>
#declare box_ = box {
  0, <2.048,1.519,.1>
    pigment {pigment_}
    finish {ambient 0}
#declare line_ = cylinder {0,<2.048,0,0>,.05 no_shadow};
light_source {<-1,1,-1>*1e3 color srgb 1 parallel}
  location <1,.75,-5>
  right x * (4/3)
  up y
  angle 35
  look_at <1,.75,0>
object {box_ translate <0,0,1>}
object {line_ pigment {color rgb x} translate <0,.5,0>}
-----<snip>-----
note that the image dimension (2048x1519) and such should all be stored in
variables, "magic numbers" in the code invariably lead to more work)
regards ,jr.
Download '6digit.png' (16 KB)
Preview of image '6digit.png'
Date: 23 Jul 2022 15:46:02
Message: <62dc4ffa$1@news.povray.org>
On 23/07/2022 1:31 pm, 6digit wrote:
> Good evening
> thank you
ghere is mt previous anwser rotated into the x, z, plane:
#declare image_width = 2592;
#declare image_height = 1944;
// perspective (default, not required) camera
   orthographic
   location  <image_width/2, 10000, image_height/2,>
   look_at   <image_width/2, 0, image_height/2>
   right     x*image_width/1944   // aspect
   //direction<3129.6857,3102.3533,0>
   focal_point < 563.2927, 0, 1366.9001>
   aperture 3.6171875
   // direction z                        // direction and zoom
   angle 16                           // field (overrides direction zoom)
box{<0,0,0>,<1,1,0.001>
     pigment {image_map {"D:/Files/Photos/Historic boats/027.JPG" once
map_type 0 interpolate 2 } }
     finish {ambient 1 diffuse 0}
     scale <image_width, image_height, 1>
     rotate<90,0,0> // Rotate into the x,z plane
box{<0,0,0>,<900,2,-80>        // Size
     pigment{rgb<1,0,1>}           // Colour
     finish {ambient 1 diffuse 0}  // Make it visible
     translate<88,1,88>          // Move it about (the y*1 puts it above
the image box)
Date: 24 Jul 2022 05:55:42
Message: <62dd171e@news.povray.org>
It has been pointed out that "image_width" and "image_height" are
built-in POV-Ray variables.
Here is a corrected version of my answer:
> here is mt previous answer rotated into the x, z, plane:
#declare Image_W = 2592;
#declare Image_H = 1944;
   orthographic
   location  <Image_W/2, 10000, Image_H/2,>
   look_at   <Image_W/2, 0, Image_H/2>
   right     x*Image_W/1944   // aspect
   aperture 3.6171875
   angle 16                           // field (overides direction zoom)
     scale <Image_W, Image_H, 1>
the image box)
Date: 25 Jul 2022 14:01:18
Message: <62deda6e$1@news.povray.org>
Also, in POV-Ray 3.7 and later, you can read the dimensions directly
from the pigment:
  #declare P = pigment
  { image_map
    { jpeg "D:/Files/Photos/Historic boats/027.JPG"
      once map_type 0 interpolate 2
  #declare Image_W = max_extent (P).x;
  #declare Image_H = max_extent (P).y;
> [snip]
Did you omit the #version at the top of the scene deliberately?  POV-Ray
3.7 and POV-Ray 3.6 render it differently; if you include #version 3.7,
the image turns out too pale.  Also, you omitted the jpeg keyword in the
image_map; POV-Ray 3.7 renders it to completion, but 3.6 halts, looking
for PNG image.
If the scene is intended for POV-Ray 3.7 or later, then the finish
statement should be:
  finish {ambient 0 diffuse 0 emission 1}
This will be important if 6digit decides to use radiosity.
If the scene is intended for POV-Ray 3.6, the finish statement must
remain as you wrote it, and the image dimensions cannot be read from the
file; but the jpeg keyword needs to be included in the image_map statement.
Date: 27 Jul 2022 16:24:33
Message: <62e19f01$1@news.povray.org>
> from the pigment:
>    { image_map
That's useful, thanks.
>> [snip]
> for PNG image.
6digit wrote it :-)
Good point re the jpeg keyword.
I answered as I did because I was trying to keep my answer as close to
the original question as possible. As I didn't know what version 6digit
might be using I thought is best not to include a version number
assuming he would post my code into his programme.
Date: 30 Jul 2022 18:00:00
Message: <web.62e5a8d88506b86234c05824fb08dd02@news.povray.org>
> camera {
>    orthographic
>    aperture 3.6171875
> the image box)
Good evening im hoping any one can see this message i notice something when
scrolling through this code.
i notice the predefined width and height were divided by 2. why ? and what does
it do exactly. thank you
Date: 31 Jul 2022 11:50:57
Message: <62e6a4e1$1@news.povray.org>
Because we want the camera over the middle of the image.  If we don't
divide by 2, we end up over the upper right corner.
