POV-Ray : Newsgroups : povray.general : vrotate question Server Time
4 Mar 2026 15:42:18 EST (-0500)
  vrotate question (Message 1 to 8 of 8)
Subject: vrotate question
Date: 21 Jul 2022 10:30:00
Message: <web.62d961bff5740dfe1be3cd4b6cde94f1@news.povray.org>
hi,
reading the reference for 'vrotate()'[*], I understood that all components of
'B' are used to rotate the point.  yet, with the code below, both points are
identical for a given 'i_'.  I expected different values of 'B' to result in
different "orbits", so, what am I doing wrong?
[*] <https://wiki.povray.org/content/Reference:Vector_Expressions#Functions>
regards, jr.
-----<snip>-----
#version 3.7;
global_settings {assumed_gamma 1}
box {0,1}
#for (i_,0,359)
  #local p1_ = vrotate(<5,0,0>,<0,i_,45>);
  #local p2_ = vrotate(<5,0,0>,<45,i_,45>);
  #debug concat("#",str(i_,0,0)," p1 <",vstr(3,p1_,",",0,6),">.\n")
  #debug concat("#",str(i_,0,0)," p2 <",vstr(3,p2_,",",0,6),">.\n")
-----<snip>-----
Subject: Re: vrotate question
Date: 21 Jul 2022 11:52:05
Message: <62d97625$1@news.povray.org>
On 21/07/2022 3:25 pm, jr wrote:
> hi,
> regards, jr.
> -----<snip>-----
> #version 3.7;
> box {0,1}
> #for (i_,0,359)
> #end
> -----<snip>-----
You moved the point along the x axis then rotated it by 45 degrees in x.
The 45 degree rotation has no effect as the point is still at y = 0, z = 0
Date: 21 Jul 2022 13:15:00
Message: <web.62d98877132fa4421be3cd4b6cde94f1@news.povray.org>
hi,
"m@b" <sai### [at] googlemailcom> wrote:
(thanks for swift reply)
no visible effect for the first point, agree, but I thought the rotation would
(should!) still exist and propagate when subsequent points are calculated.
the next question, then, is how to specify a point <5,0,0> and corresponding
vrotate()s to give me two separate X-axis rotations (as I tried with the two
rotation vectors)?  do I have to pre-compute some point not-on-axis beforehand,
or is there a "clean" way?
regards, jr.
Date: 21 Jul 2022 15:09:21
Message: <62d9a461@news.povray.org>
On 21/07/2022 6:10 pm, jr wrote:
> hi,
> regards, jr.
This is hurting my brain a bit.
Reading the docs, the rotations are around the origin (<0,0,0>) so
   sphere{p2_, 1}
is equivalent to:
   sphere{<0,0,0>, 1 translate<5,0,0> rotate<45,i_,45>}
Not quite sure what you want to achieve.
m@
Date: 21 Jul 2022 15:25:00
Message: <web.62d9a772132fa4421be3cd4b6cde94f1@news.povray.org>
hi,
oops, replied to the email, sorry.
regards, jr.
Date: 21 Jul 2022 16:05:22
Message: <62d9b182@news.povray.org>
On 21/07/2022 8:22 pm, jr wrote:
> hi,
My fault - I meant to reply on here, hit the wrong button.
> regards, jr
thanks for yr interest.  so, point at <5,0,0>, I want to "orbit",
around Y, at an incline of 45°.  rotating that amount in Z gives me
that, but the point/sphere crosses the Z axis in two places.  adding a
rotation of +-X _should_ to my thinking, incline the orbit such that
it goes "over" +Z and "under" -Z, or vice versa.  so I try to have
multiple orbits around origin, without them crossing/touching the
respective axis.  (hope that makes sense)  cheers.
I think what you want is this:
   sphere{0, 1 translate<5,0,0> rotate<0,i_,45> rotate<45,0,0>}
i.e. apply the x rotation after the i_ thing. I don't think it is
possible using vrotate.
If you need to define the points in advance you could try this:
   #local p2_ = transform {translate<5,0,0> rotate<0,i_,45> rotate<45,0,0>};
   sphere{0, 1 transform p2_ }
Date: 21 Jul 2022 16:40:00
Message: <web.62d9b858132fa4421be3cd4b6cde94f1@news.povray.org>
hi,
ah, ok, need separate rotations.  (the "i_ thing" was just a placeholder for
frame_number)
thank you for the 'transform' reminder!  I currently write 'sphere
{vrotate(...),...}' in the scene, so need to re-organise the sphere centres etc.
 think I can make the transform into a macro :-).  cheers.
regards, jr.
Date: 21 Jul 2022 18:20:00
Message: <web.62d9d086132fa4421be3cd4b6cde94f1@news.povray.org>
> ah, ok, need separate rotations.  ...
works as envisaged.  thanks again.
regards, jr.
