POV-Ray : Newsgroups : povray.general : Importing an image to use on pov ray and overlaying a line Server Time
4 Mar 2026 15:41:03 EST (-0500)
  Importing an image to use on pov ray and overlaying a line (Message 1 to 10 of 12)
Subject: Importing an image to use on pov ray and overlaying a line
Date: 17 Jul 2022 11:45:00
Message: <web.62d42d79b67b6e84eb0f47cfb08dd02@news.povray.org>
Good evening,
I'm new to pov ray, so I need help with some issues.
1. how do I import an image into pov ray so I can overlay an object on it. I
have tried and used various threads. one suggested using something called screen
inc. the issue I'm having with this, is when I try to edit the camera it doesn't
seem to take any effect. so I was wondering if there's any other way of doing
this or could explain how the screen inc works.
2. if I do import the image how do I draw a simple line overlayed on the image.
also, I have looked at many threads. they too suggested drawing a very tin box.
is there another way to do this?
thank you.
Subject: Re: Importing an image to use on pov ray and overlaying a line
Date: 17 Jul 2022 14:30:00
Message: <web.62d45459df954fb91be3cd4b6cde94f1@news.povray.org>
hi,
"6digit" <eob### [at] gmailcom> wrote:
> Good evening,
one way is using an 'image_map' as a pigment, something like:
  plane {
    z, 1
      image_map {"myimg.jpg" once map_type 0}
and scale the object (or the pigment) to reflect the image dimensions.
<https://wiki.povray.org/content/Reference:Image_Map>
cylinders, usually, for a line.  afaik, no, you "only" have the choice from
<https://wiki.povray.org/content/Reference:The_Object_Zoo>.  hth.
regards, jr.
Date: 17 Jul 2022 21:25:00
Message: <web.62d4b5cedf954fb9d8145616fb08dd02@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > Good evening,
>   plane {
>     z, 1
>     pigment {
> regards, jr.
Thank you jr it worked fine but it appears theres a shadow as it is hard to see
the image.
Date: 18 Jul 2022 03:40:00
Message: <web.62d50d79df954fb91be3cd4b6cde94f1@news.povray.org>
hi,
> the image.
ok, there are two ways, essentially[*], to deal with a shadow: adapt the
light_source or the object.  there are 'shadowless' (lights) and 'no_shadow'
modified objects; you can get the details from this page:
<https://wiki.povray.org/content/Reference:Keywords>
[*] but bear in mind that many of the regulars here know a _lot_ more about
POV-Ray than I do :-).
also meant to mention, re cylindrical lines, there's a 'sphere_sweep' primitive
which folks here use to good effect to make "lines", recently eg Dave Blandston.
regards, jr.
Date: 18 Jul 2022 03:50:09
Message: <62d510b1$1@news.povray.org>
On 17.07.2022 17:40, 6digit wrote:
> Good evening,
To overlay a 2D line over a 2D image and (as you said later in this
thread) not wanting shadows suggests you have the wrong tool for the
job. POV-Ray is a 3D rendering software, and not really suitable for 2D
image composition. The best way to manipulate 2D images in a
programmatic way is probably ImageMagick, which is open source and
freely available at https://imagemagick.org/
Thorsten
Date: 18 Jul 2022 08:40:00
Message: <web.62d553b8df954fb94eb0f47cfb08dd02@news.povray.org>
> hi,
> > the image.
> regards, jr.
Thank you mr jr i was able to get rid of the shadow. the scaling is what im
trying to fix now.
Message: <web.62d553dedf954fb94eb0f47cfb08dd02@news.povray.org>
> > Good evening,
> Thorsten
thank you thorsten i will check it out.
Date: 18 Jul 2022 09:25:00
Message: <web.62d55e79df954fb94eb0f47cfb08dd02@news.povray.org>
> hi,
> > the image.
> regards, jr.
Thank you jr. the info youve giving me its more than enough i am making
considerable progress with this little info.
Date: 18 Jul 2022 11:55:00
Message: <web.62d58142df954fb91be3cd4b6cde94f1@news.povray.org>
hi,
> I'm new to pov ray, ...
glad you got "on top of it".  and hope you will find your future "POVing"
rewarding.
regards, jr.
Date: 18 Jul 2022 22:00:00
Message: <web.62d60f42df954fb9d8145616fb08dd02@news.povray.org>
> hi,
> > Good evening,
>   plane {
>     z, 1
>     pigment {
> Could you please advise on scaling the object because I am having trouble scaling
it.
> regards, jr.
