POV-Ray : Newsgroups : povray.general : Patterned Textures and Turbulence Server Time
16 Aug 2025 13:51:51 EDT (-0400)
  Patterned Textures and Turbulence (Message 1 to 9 of 9)
Subject: Patterned Textures and Turbulence
Date: 11 May 2022 10:55:00
Message: <web.627bcdc02ebc6198630ded5c5cc1b6e@news.povray.org>
I am working on some scene elements with painted wood, where the paint is
chipping away, exposing the underlying wood texture.  Since the paint and wood
have different finishes and normals, I want to use a texture_map rather than
layered textures.
If I just do scaling/rotation/translation transformations on the texture
pattern, I know how to compensate for that in the textures in the map so those
transformations apply to the overall pattern, but not the patterns of the
individual textures.  However, I can't figure out how to add turbulence to the
texture pattern without having it affect the textures in the map.
Is this even possible, or do I just need to avoid turbulence in patterned
textures?
-- Chris R.
Subject: Re: Patterned Textures and Turbulence
Date: 11 May 2022 11:58:45
Message: <627bdd35$1@news.povray.org>
> layered textures.
> textures?
> -- Chris R.
You can apply your turbulence with a negative value :
warp{turbulence -1} should undo warp{turbulence 1}
Date: 11 May 2022 14:25:00
Message: <web.627bfea99629840630ded5c5cc1b6e@news.povray.org>
> > layered textures.
> > textures?
> > -- Chris R.
Ah, thanks.  I should have thought to try that.  I was concerned about how that
would affect lambda and omega, but if I understand turbulence correctly, those
act more like multipliers on the turbulence value and should thus be negated if
turbulence is negative as well.
-- Chris R.
Date: 12 May 2022 10:15:00
Message: <web.627d163c962984031441ea85cc1b6e@news.povray.org>
> > > layered textures.
> > > textures?
> > > -- Chris R.
> -- Chris R.
So, I tried this and it doesn't seem to work.  The picture below shows an
example of an object with a gradient x texture_map with leopard and bricks as
the sub-textures.  The middle picture applies a turbulence just to the gradient
pattern.  The 3rd picture applies a negative turbulence to each of the
sub-textures first.
-- Chris R.
Download 'view.png' (77 KB)
Preview of image 'view.png'
Date: 12 May 2022 10:40:00
Message: <web.627d1c0c962984031441ea85cc1b6e@news.povray.org>
> > > > layered textures.
> > > > textures?
> > > > -- Chris R.
> > -- Chris R.
> sub-textures first.
> -- Chris R.
Just another short observation:
warp { turbulence 1 }
warp { turbulence -1 }
applied to a texture does not result in a non-turbulated texture.  I believe the
issue is that amount of turbulence applied to a point is dependent on the point
itself.  Once you apply the turbulence, and then attempt to apply turbulence
again, you are getting the turbulence from a new point, which will not be the
same as the original point.
-- Chris R.
Date: 12 May 2022 10:50:00
Message: <web.627d1e7b962984031441ea85cc1b6e@news.povray.org>
wood
> > > > > layered textures.
those
the
> > > > > textures?
> > > > > -- Chris R.
> > > -- Chris R.
> > sub-textures first.
> > -- Chris R.
> -- Chris R.
I found a solution; use a pigment_pattern for the patterned texture rather than
using the pattern directly.  Apply the turbulence to the pigment for the
pigment_pattern:
   pigment_pattern {
         gradient x
         color_map {
            [0.0 rgb 0.0]
            [0.5 rgb 0.0]
            [0.5 rgb 1.0]
            [1.0 rgb 1.0]
         warp { turbulence 0.1 }
         scale _box_size
   texture_map {
      [0.0 _t1]
      [0.5 _t1]
      [0.5 _t2]
      [1.0 _t2]
-- Chris R.
Download 'turb_pp.png' (171 KB)
Preview of image 'turb_pp.png'
Date: 12 May 2022 19:30:00
Message: <web.627d982b96298402eadabda6e066e29@news.povray.org>
> > ...However, I can't figure out how to add turbulence to the
> > textures?
I have never been able to get that kind of turbulence 'reversal' to work :-( I
just tried out some other ideas-- which failed again.
Here's an older thread that discussed some additional workarounds to the
problem...
https://news.povray.org/povray.general/thread/%3Cweb.5f5e86282e3bd598d98418910%40news.povray.org%3E/
Date: 13 May 2022 14:30:00
Message: <web.627ea33a962984031441ea85cc1b6e@news.povray.org>
> > > textures?
> problem...
It looks like they came up with the same pigment_pattern solution that I did
above.  I'm surprised this article didn't show up in my search of the newsgroup.
 It would have saved me an afternoon trying to work it out on my own.  But,
maybe it's a good thing to keep the old brain sharp...
-- Chris R.
Date: 14 May 2022 12:10:59
Message: <627fd493$1@news.povray.org>
The search engine misses a whole lot of articles.  I don't know whether
it's because the spider isn't trying hard enough, or that The Google has
taken it upon itself to decide what we consider important.
