POV-Ray : Newsgroups : povray.general : Help With Image Server Time
19 May 2024 20:47:32 EDT (-0400)
  Help With Image (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Help With Image
Date: 1 Apr 2022 04:32:54
Message: <6246b8b6$1@news.povray.org>
On 29/03/2022 20:54, Craig Lindley wrote:
> Any help or suggestions would be appreciated. If anyone has access to the actual
> POV file for this image I would love to have it.
I made this kind of picture.
I just found this old code in my archives.
#declare index=0;
#declare nBilles=32; //64;
#declare dAngle=4;
#declare dRayon=0.50;
#declare rayon = 1-dRayon;
#declare xPos=0;
#declare rot=0;
#declare spirale = union {
 #declare index=0;
 #while(index<nBilles)
  #declare rayon=rayon+dRayon;
  #declare rot=rot+dAngle;
  sphere {
   <0,0,0>, rayon
   translate xPos*x
   rotate rot*y
  #if(debugging) #debug concat("Rayon = ",str(rayon,7,2)," xPos =
",str(xPos,7,2)," Rot = ",str(rot,7,2),"\n") #end
  #declare xPos=xPos+rayon;
  #declare index=index+1;
#declare theColor = rgb <0,0,0>;
#declare index=0;
#while(index<360)
 #declare theColor = rgb CH2RGB(index);
 object {
  spirale
  rotate index*y
  pigment { color theColor }
 #declare index=index+10;
Hope that help
Kurtz le pirate
Compagnie de la Banquise
Date: 1 Apr 2022 10:40:00
Message: <web.62470e532a8c6bc6fc0c8de6cde94f1@news.povray.org>
hi,
"heavy, man.  psychedelic."  ;-)
regards, jr.
Download 'klp.png' (578 KB)
Preview of image 'klp.png'
Date: 16 Apr 2022 13:30:00
Message: <web.625afc6b2a8c6bc62f73d2b2bc520638@news.povray.org>
"Craig Lindley" <cal### [at] gmailcom> wrote:
> Hello,
> I came across the attached image the other day that I thought was beautiful so I
> decided to look at raytracing again. I hadn't done any raytracing since about
> 1993 so the POVRAY program has changed quite a bit. I am using the 3.8 version
> of POVRAY and it is amazing. I retraced one of my old images that took 33 hours
> in the 1990's and today on my Mac it took about 10 minutes.
> Anyway. I would like to understand how this image was produced because I would
> like to do something like it for this years Christmas card.
> It seems to be made up of Fibonacci spirals but I am not sure. I looked at the
> POVRAY documentation for these types of spirals but I cannot seem to duplicate
> the image accurately. I would guess that each color is its own Fibonacci spiral
> but how they are positioned so they don't interfere with each other escapes me.
> Thanks in advance.
After struggling with Doyle circle packing code for a week I finally have an
image which is close to the original image I posted. I've attached the image and
a POV file in case anyone wants to play around with it. I wrote the circle
packing code in Java and then transferred the generated spheres into a POV file.
If anyone is interested in the Java code, let me know and I can get it to you.
Craig Lindley
Download 'spheresdoyle.png' (692 KB)
Preview of image 'spheresdoyle.png'
Message: <web.625afcdf2a8c6bc62f73d2b2bc520638@news.povray.org>
> Hello,
> Thanks in advance.
And here is the poverties file
Download 'spheresdoyle.pov.txt' (10 KB)
Date: 17 Apr 2022 13:15:00
Message: <web.625c4a5a2a8c6bc6cf1917686cde94f1@news.povray.org>
hi,
worth it, I think.
(best viewed through sunglasses perhaps :-))
thanks.  have no interest in Java but wouldn't mind knowing why you chose it
over SDL when you implemented the code (given that geometrical calculations are
SDL's "bread-and-butter").
regards, jr.
Date: 17 Apr 2022 20:05:00
Message: <web.625ca9d32a8c6bc62f73d2b2bc520638@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> worth it, I think.
> regards, jr.
I did it in Java because there is a lot of math involved. It is necessary to
solve the initial-value problem of differential equations using the Runge-Kutta
method which I am sure could
be done in SDL but there would be many pages of macros/functions to do so. Also
Java is easier to debug.
Date: 18 Apr 2022 10:45:00
Message: <web.625d789e2a8c6bc62f73d2b2bc520638@news.povray.org>
> > hi,
> > worth it, I think.
> > regards, jr.
Here is another image using the same data after I worked on the sphere's
texture/pigment
Download 'spheresdoyle.png' (1601 KB)
Date: 18 Apr 2022 12:30:00
Message: <web.625d91e62a8c6bc62f73d2b2bc520638@news.povray.org>
> hi,
> regards, jr.
I tried to render this image but ended up with this. Is this a bug in poverty
3.8?
Download 'kip.png' (187 KB)
Preview of image 'kip.png'
Date: 18 Apr 2022 16:00:00
Message: <web.625dc22d2a8c6bc62f73d2b2bc520638@news.povray.org>
> > hi,
> > regards, jr.
> 3.8?
Never mind. When I restarted pov the problem went away
Date: 19 Apr 2022 03:25:00
Message: <web.625e63002a8c6bc6cf1917686cde94f1@news.povray.org>
hi,
> > 3.8?
nice "glitch" :-).  (I use command-line only, no UI)
regards, jr.
