POV-Ray : Newsgroups : povray.general : Is it possible to warp the UV coordinates of a 2D texture map? Server Time
13 Jan 2026 22:38:26 EST (-0500)
  Is it possible to warp the UV coordinates of a 2D texture map? (Message 1 to 6 of 6)
Subject: Is it possible to warp the UV coordinates of a 2D texture map?
Date: 14 Jan 2022 15:15:00
Message: <web.61e1d8a1565413375c8e85ceb98f01db@news.povray.org>
I have a sphere that I want to apply a 2D texture to, using UV mapping.  But I
want to distort the UV coordinates such that the texture looks like it's pushed
away from a hole that I'm CSG-subtracting from the sphere.  Basically, given
some (u,v) that povray generates when a ray intersects with the sphere, is it
possible to "post-process" the coordinates with some functions f, g, so that the
texture is looked up at coordinates (f(u), g(v)) instead of (u,v)?
Is it possible to do this, or do I have to somehow distort the texture itself?
Subject: Re: Is it possible to warp the UV coordinates of a 2D texture map?
Date: 15 Jan 2022 03:04:35
Message: <61e28013$1@news.povray.org>
As per the sphere object itself, the UV mapping are hard-coded (not even
in memory, just computed when needed)
But I wonder if there is something that would stop you from applying
warp to the texture.
Date: 17 Jan 2022 14:50:00
Message: <web.61e5c77838c4a65d5c8e85ceb98f01db@news.povray.org>
Warping the texture would also be an option... is there a way to specify an
arbitrary mapping function to remap texture values?  What I have in mind is to
use maybe a standard texture pattern as the basis, but have some kind of
function on top of it to distort it in specific ways.
Is this possible?
Date: 17 Jan 2022 19:00:00
Message: <web.61e6015138c4a65d4cef624e6e066e29@news.povray.org>
> Is this possible?
I'm no expert at using functions, but from simple syntax tests, it looks like a
'bare' function cannot be used to distort a pigment pattern. I.e., this
simplistic example does not work, fatal error:
#declare FUNC =
function(x){6*sin(2*pi*x)}; // *this* works OK
object{...
pigment{
    cells
    FUNC(.7).x // this fails; other syntax variations that I tried also fail
But it can successfully be used *in* a scale, or a turbulence, or etc:
 scale <1, FUNC(.7).x,1>
Again, these are just syntax tests; the actual results of my examples might
be... questionable, ha.
From your description of what you are trying to accomplish, maybe a 'black hole'
warp would work (with its 'inverse' keyword)?
Date: 18 Jan 2022 05:35:00
Message: <web.61e696ea38c4a65db9690bef89db30a9@news.povray.org>
> Is this possible?
Hi tutki
It is possible to distort or remap pigments and patterns with functions before
using them in UV-mapped textures.
There's some relevant code here:
Subject: Source code for "Using functions to distort images"
Date: 2006-05-21 18:48:59
http://news.povray.org/povray.text.scene-files/thread/%3C4470ee5b%40news.povray.org%3E
The pigment in the ImageFn() function (also shown below) does not have to be an
image_map; it can be any pigment.
    #declare ImageFn =
       function { pigment { image_map { "Image.png" } } }
You can also have a look at the FunctionsPigmentRGB() macro etc. in the
Gaussian_Blur.inc file, here:
    https://github.com/t-o-k/POV-Ray-gaussian-blur
If you need to distort textures on a sphere it may be possible to make a sphere
shaped "solid mesh" with your own "pre-distorted" UV-coordinates.
    http://www.povray.org/documentation/view/3.7.0/292/
It should then be possible to use that mesh in CSG constructions.
Tor Olav
http://subcube.com
Date: 18 Jan 2022 06:55:00
Message: <web.61e6a9fb38c4a65d1f9dae3025979125@news.povray.org>
> > Is this possible?
> #declare FUNC =
> object{...
> pigment{
>     cells
Right, because you're just appending a function statement to the pigment
specification.
What you need to do is define a function that uses the cells pattern, and then
using another function that controls the coordinates, pass those coordinates
into the cells pattern fuinction call so that it uses those distorted
coordinates, not the raw basis vector coordinates.
So just to give you the idea:
So #declare F = function {pigment {cells}}
object {
function {F (FUNC(x,y,z).x, FUNC(x,y,z).y, FUNC(x,y,z).z}
(untested, so this probably needs a good bit of tweaking...)
