POV-Ray : Newsgroups : povray.general : subtle change of semi-colon use in v3.8xx Server Time
17 Jun 2024 03:05:45 EDT (-0400)
  subtle change of semi-colon use in v3.8xx (Message 1 to 2 of 2)
Subject: subtle change of semi-colon use in v3.8xx
Date: 28 Oct 2020 00:45:00
Message: <web.5f98f65480b20801d98418910@news.povray.org>
I recently came across a subtle problem with semi-colon placement, when used in
*particular* v3.8 development versions (in Windows). It took me some time to
track down, and to figure out a simple test to reproduce it:
#version 3.8;
global_settings{assumed_gamma 1.0}
#declare VEC = <.3,.5,.7>;
#macro MY_MACRO(FOO)
#local BAR = FOO;
<BAR.x,BAR.y,BAR.z>;
#declare XYZ_POS = MY_MACRO(VEC);
In  versions 9811560+av591 and 9893777+av622, the above code works without a
problem. But in later versions 10013324+av645, 10064268+av691, and
10064738+av694 , the semi-colon after
causes a fatal error.
A macro is the only structure to be sensitive to this, that I have discovered so
far-- perhaps because it's one of the few code structures that, depending on
use, does not specifically need a semi-colon after its 'result'.
Maybe the later development versions 'tightened up' the rules of semi-colon use
in general?
In any case, there are two ways to fix this in the later versions:
1) Put a semi-colon after  <BAR.x,BAR.y,BAR.z> but NOT after
2) REVERSE that order
In the earlier versions, semi-colons can be used in both places at once-- or
like 1) or 2) as well. (I haven't yet tried any v3.7xx to see what happens
there.)
Just something to be aware of for the future.
Subject: Re: subtle change of semi-colon use in v3.8xx
Date: 30 Oct 2020 06:09:12
Message: <5f9be648$1@news.povray.org>
> #version 3.8;
> #local BAR = FOO;
> #end
> in general?
My guess is double semicolons are no longer allowed after Christoph's
parser performance changes in v3.8.
One thing done was to implement a fast scan ahead which looks for the
end of if blocks for example so they can be digested / skipped in
chunks. Here I think it scans ahead for the required trailing ; finding
the last one, but what is just prior isn't what's expected, but rather a
semicolon preceding the last found.
I suspect your test case could be just
#declare VEC = <.3,.5,.7>;;
Bill P.
